Port Forward 80 problem
GEORGE POLYZOS
Hello
My problem is that I can't port forward 80 Port
I used the following commands
cisco123(config)#ip nat inside source static tcp 10.10.10.25 80 interface Dialer0 80
cisco123(config)#ip nat inside source static tcp 10.10.10.25 443 interface Dialer0 443
ip access-list extended 199
permit tcp any host 10.10.10.25 eq www
I want outside Internet users to access web server with address 10.10.10.25 .How is it possible?
Thank you very much
Please have a look at the running configuration.
Building configuration...
Current configuration : 6714 bytes
! Last configuration change at 22:38:31 Athens Wed Apr 22 2015
version 15.1
no service pad
hostname cisco123
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 $1$5qyB$qWoRHktpS/D3aoImKdyU21
enable password
no aaa new-model
memory-size iomem 10
clock timezone Athens 2 0
clock summer-time Athens date Mar 30 2003 3:00 Oct 26 2003 4:00
crypto pki trustpoint TP-self-signed-1627569428
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-
 revocation-check none
 rsakeypair TP-self-signed-
        quit
ip source-route
ip cef
ip name-server 193.92.150.3
ip name-server 194.219.227.2
ip port-map user-protocol--1 port tcp 26433
no ipv6 cef
license udi pid CISCO887VA-K9 sn FCZ1715948E
controller VDSL 0
class-map type inspect match-all sdm-nat-user-protocol--1-1
 match access-group 101
 match protocol user-protocol--1
class-map type inspect match-any ccp-skinny-inspect
 match protocol skinny
class-map type inspect match-any ccp-cls-insp-traffic
 match protocol dns
 match protocol ftp
 match protocol https
 match protocol icmp
 match protocol imap
 match protocol pop3
 match protocol netshow
 match protocol shell
 match protocol realmedia
 match protocol rtsp
 match protocol smtp
 match protocol sql-net
 match protocol streamworks
 match protocol tftp
 match protocol vdolive
 match protocol tcp
 match protocol udp
class-map type inspect match-all ccp-insp-traffic
 match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-h323nxg-inspect
 match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
 match protocol icmp
 match protocol tcp
 match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
 match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
 match protocol h323-annexe
class-map type inspect match-any ccp-h323-inspect
 match protocol h323
class-map type inspect match-all ccp-invalid-src
 match access-group 100
class-map type inspect match-all ccp-icmp-access
 match class-map ccp-cls-icmp-access
class-map type inspect match-any ccp-sip-inspect
 match protocol sip
class-map type inspect match-all ccp-protocol-http
 match protocol http
policy-map type inspect ccp-permit-icmpreply
 class type inspect ccp-icmp-access
  inspect
 class class-default
  pass
policy-map type inspect sdm-pol-NATOutsideToInside-1
 class type inspect sdm-nat-user-protocol--1-1
  inspect
 class class-default
  drop
policy-map type inspect ccp-inspect
 class type inspect ccp-invalid-src
  drop log
 class type inspect ccp-protocol-http
  inspect
 class type inspect ccp-insp-traffic
  inspect
 class type inspect ccp-sip-inspect
  inspect
 class type inspect ccp-h323-inspect
  inspect
 class type inspect ccp-h323annexe-inspect
  inspect
 class type inspect ccp-h225ras-inspect
  inspect
 class type inspect ccp-h323nxg-inspect
  inspect
 class type inspect ccp-skinny-inspect
  inspect
 class class-default
  drop
 class class-default
  drop
zone security in-zone
zone security out-zone
zone-pair security ccp-zp-self-out source self destination out-zone
 service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
 service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
zone-pair security sdm-zp-NATOutsideToInside-1 source out-zone destination in-zone
 service-policy type inspect sdm-pol-NATOutsideToInside-1
interface Ethernet0
 no ip address
 shutdown
 no fair-queue
interface ATM0
 no ip address
 no atm ilmi-keepalive
interface ATM0.1 point-to-point
 description FORTHNET
 pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface Vlan1
 description $FW_INSIDE$
 ip address 10.10.10.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 zone-member security in-zone
 ip tcp adjust-mss 1412
interface Dialer0
 description $FW_OUTSIDE$
 ip address negotiated
 ip mtu 1452
 ip nat outside
 zone-member security out-zone
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication pap callin
 ppp pap sent-username
 ppp ipcp dns request
ip forward-protocol nd
ip http server
ip http secure-server
ip nat inside source list 199 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 199 permit ip any any
access-list 199 permit tcp any host 10.10.10.25 eq www
dialer-list 1 protocol ip permit
line con 0
 no modem enable
line aux 0
line vty 0 4
 password
 login
 transport input all
end
Hello
Cisco recommends not to use nat acl to thats define any any
Try:
no IP access 199
ip access-list 199 permit IP 10.10.10.0 0.0.0.255 any
also your ZBF class map for nat is looking for a acl of 101 and I don't see that in your config
res
paul
Kind Regards
Paul
I followed your advice although the problem remains . I don't have access-list 101
Thank you for your help
My current running-config
Current configuration : 6812 bytes
! Last configuration change at 21:04:37 Athens Sun Apr 26 2015
version 15.1
no service pad
hostname cisco123
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5
enable password
no aaa new-model
ip source-route
ip cef
no ipv6 cef
controller VDSL 0
 match protocol dns
 match protocol ftp
 match protocol icmp
 match protocol imap
 match protocol pop3
 match protocol rtsp
 match protocol smtp
 match protocol tftp
 match protocol tcp
 match protocol udp
 match protocol icmp
 match protocol tcp
 match protocol udp
class-map type inspect match-all c1
 match access-group 199
 match protocol http
 match protocol h323
 match protocol sip
 match protocol http
  inspect
 class class-default
  pass
  inspect
 class class-default
  drop
  drop log
  inspect
  inspect
  inspect
  inspect
  inspect
  inspect
  inspect
  inspect
 class class-default
  drop
 class class-default
  drop
interface Ethernet0
 no ip address
 shutdown
 no fair-queue
interface ATM0
 no ip address
 pvc 8/35
 no ip address
 no ip address
 no ip address
 no ip address
interface Vlan1
 ip nat inside
interface Dialer0
 ip mtu 1452
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp pap sent-username ibmagd@otenet.gr password 0 exelon6*
ip http server
access-list 199 permit ip 10.10.10.0 0.0.0.255 any
line con 0
 no modem enable
line aux 0
line vty 0 4
 password
 login
 transport input all
end
Hello
Your still showing some remiance  of the 199 acl OP
please do the following:
no IP access 199
ip nat inside source static tcp 1 0.10.10.25 80  x.x.x.x  80 extendable
ip nat inside source static tcp 1 0.10.10.25 443  x.x.x.x   443 extendable
and also still your ZBW class map is still set to match on acl 101 which you dont seem to have
res
Paul
Kind Regards
Paul
I did the following
(config)#ip access-list extended 199
(config-ext-nacl)#no ip access-list extended 199
(config-ext-nacl)#permit ip 10.10.10.0 0.0.0.255 any
(config) ip nat inside source static tcp 10.10.10.25 80  x.x.x.x  80 extendable
(config) ip nat inside source static tcp 10.10.10.25 443  x.x.x.x   443 extendable
Is this right?
Thank you
