Port forward DHCP WAN interface
magginoodles
Hi, I want to port forward externally from dynamic IP WAN (interface 0) to internal ip's ports to allow/restrict access to ports. So my home box, is IP 192.168.0.10, port 22, or another entry 192.168.0.10 3389 etc.
Here is a config I am using now
At the moment I can only get to 22 on interface 0
Thanks for any help :)
Current configuration : 2043 bytes
! Last configuration change at 11:42:23 UTC Sun Oct 14 2018 by amadge
version 15.0
hostname magginoodles
boot-start-marker
boot-end-marker
enable secret 5 $1$Zb/.$0Hkr1XdjmX4Wccx7r57vo/
enable password XXXXX
no aaa new-model
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.0.1 192.168.0.10
ip dhcp pool VLAN99
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   dns-server 203.0.178.191 203.215.29.191
   lease 7
ip cef
ip domain name sodor
ip name-server 203.215.29.191
ip name-server 203.0.178.191
no ipv6 cef
license udi pid CISCO1801/K9 sn FHK112719GH
username XXXXX privilege 15 secret 5 $1$G5DV$iD/8Q0n1v68VF/.BX8gpv.
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn point-to-point-setup
interface FastEthernet0
 ip address dhcp
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
interface FastEthernet1
 switchport access vlan 99
interface FastEthernet2
interface FastEthernet3
 shutdown
interface FastEthernet4
 shutdown
interface FastEthernet5
 shutdown
interface FastEthernet6
 shutdown
interface FastEthernet7
 shutdown
interface FastEthernet8
 shutdown
interface Vlan1
 no ip address
 shutdown
interface Vlan99
 ip address 192.168.0.1 255.255.255.0
 ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map NAT interface FastEthernet0 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet0 dhcp
access-list 1 permit 192.168.0.0 0.0.0.255
route-map NAT permit 10
 match ip address 1
 match interface FastEthernet0
control-plane
line con 0
line aux 0
line vty 0 4
 password XXXXX
 login local
 transport input ssh
end
Francesco Molino
If you want to do port forwarding, the command will look like:
- for rdp:
ip nat inside source static tcp 192.168.0.10 3389 interface FastEthernet0 3389
- for ssh:
ip nat inside source static tcp 192.168.0.10 22 interface FastEthernet0 22
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
- for rdp:
- for ssh:
Francesco
Thanks @Francesco Molino! worked perfectly
You're welcome
Francesco
