04-05-2015 05:38 PM - edited 03-05-2019 01:10 AM
I have an issue with multiple routers where a port is forwarded for an internal service, that service it no longer accessible across the vpn tunnels.
Here is the part of my config in question showing one of the port forwards:
ip nat inside source list 100 interface GigabitEthernet0/1 overload
ip nat inside source static tcp 10.14.0.20 8081 interface GigabitEthernet0/1 8081
ip access-list extended From_External
deny ip host 255.255.255.255 any
deny ip 10.14.0.0 0.0.255.255 any
permit ip *.*.*.* 0.0.0.7 any
permit ip host *.*.*.* any
permit tcp any any eq 8081
permit tcp any any eq 22
permit tcp any any eq telnet
permit udp any any eq bootpc
deny ip any any
ip access-list extended VPN-TRAFFIC
permit ip 10.14.0.0 0.0.255.255 192.168.1.0 0.0.0.255
permit ip 10.14.0.0 0.0.255.255 10.27.0.0 0.0.255.255
permit ip 10.14.0.0 0.0.255.255 10.40.40.0 0.0.0.255
permit ip 10.14.0.0 0.0.255.255 10.7.0.0 0.0.0.255
permit ip 10.40.40.0 0.0.0.255 10.7.0.0 0.0.0.255
permit ip 10.7.0.0 0.0.0.255 10.40.40.0 0.0.0.255
access-list 100 remark ~ Define NAT Traffic to Gi 0/0 - WAN ~
access-list 100 deny ip 10.14.0.0 0.0.255.255 10.40.40.0 0.0.0.255
access-list 100 deny ip 10.14.0.0 0.0.255.255 10.27.0.0 0.0.255.255
access-list 100 deny ip 10.14.0.0 0.0.255.255 192.168.1.0 0.0.0.255
access-list 100 deny ip 10.14.0.0 0.0.255.255 10.7.0.0 0.0.0.255
access-list 100 deny ip 10.40.40.0 0.0.0.255 10.7.0.0 0.0.0.255
access-list 100 deny ip 10.7.0.0 0.0.0.255 10.40.40.0 0.0.0.255
access-list 100 permit ip 10.14.0.0 0.0.255.255 any
It has to do with the port forward rule:
"ip nat inside source static tcp 10.14.0.20 8081 interface GigabitEthernet0/1 8081"
With the rule in place I can access it externally but not over the vpn, without the rule access across the vpn is fine but no external access.
04-06-2015 06:09 PM
I found the answer I was looking for in another post. I needed to add a route map to the end of the port forward rule:
ip nat inside source static tcp 10.14.0.20 8081 50.81.220.129 8081 route-map 100 extendable
However it only allows for a ip address to be specified and not an interface, which make it tricky with a dynamic ip. If anyone knows of a solution please let me know.
