Port Forwarding DVR with different server and web ports.
Jon White
I am trying to configure a 2600 Router to allow viewing of the DVR over the web.
I have been able to get this to work before with an older DVR (only using port 80).
However, this new DVR must utilize a Server port of 8000 and an Http port of 80.
I have been trying different configurations with no luck, below is what I think should work, but it doesn't.
       ip nat inside source static tcp 10.0.0.7 8000 x.x.x.x 80 extendable
       ip nat inside source static udp 10.0.0.7 8000 x.x.x.x 80 extendable
Any suggestions?
kgareis
Jon,
Just curious, have you tried using:
ip nat inside source static tcp 10.0.0.7 8000 x.x.x.x 8000 extendable
