port forwarding for PASV ftp
shoebwk
hello i need to forward a range of port to my PASV ftp server. The range include 50000-50100. how do i accomplish this on my 800 series router
regards
shoeb
Hello Shoeb,
as long as you are noy blocking TCP ports >1023, your passive FTP should work. I assume the FTP server is sitting on the local network off your Cisco 800 ? Can you post the config of your router ?
GP
yes my FTP server is sitting on the local network behind the router
this is my config
Current configuration:
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname edi-ISDN
enable secret level xxxx
ip subnet-zero
ip name-server 213.42.20.20
ip name-server 195.229.241.222
isdn switch-type basic-net3
interface Ethernet0
ip address 192.168.1.254 255.255.255.0
ip nat inside
interface BRI0
no ip address
ip nat outside
encapsulation ppp
dialer pool-member 1
ppp authentication pap callin
interface Dialer1
ip address 213.12.x.x
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 500
dialer string 4004444
dialer hold-queue 10
dialer-group 1
--More--
ppp pap sent-username abc password xxx
ip nat inside source list 101 interface Dialer1 overload
ip nat inside source static tcp 192.168.1.252 21 interface Dialer1 21
ip nat inside source static tcp 192.168.1.252 20 interface Dialer1 20
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
dialer-list 1 protocol ip permit
line con 0
password xxx
login
transport input none
stopbits 1
line vty 0 4
password xxx
login
can you try and find out if your problem might be related to your FTP server trying to reply with its internal unNATed IP address, when the outside client attempts to use the passive FTP ? I think it is a software setting in the FTP server settings, to have the server reply with a specific IP address (which would be the IP address of your Dialer 1)...
GP
