Port Forwarding in case of Valid IP address limitation
ali_ebrahimi
I have only a valid IP address available. I have to make several servers accessible behind this address on a Cisco 2911 router. I was thinking of port forwarding that seems to me as an equivalent for STATIC PAT in ASAs.
Has anybody tested this before? Does it scale wall?
Pawan Raut
Level 4
Level 4
Yes this is scaleble solution
You can do Port forwarding or port redirection as below are example
ip nat inside source static tcp 1.1.1.1 80 2.2.2.2 80
ip nat inside source static tcp 1.1.1.1 443 3.3.3.3 80
Thanks Pawan
Can I have port forwarding and PAT using a single IP address at the same time?
Does this scale?
Yes you can
