port forwarding in cisco 2621 router
soorajn2011
Hello all,
I have a router 2621. I just want a port forward from public ip to local IP. Port is 8086. I use nat. I just need to forward the public ip 115.115.123.xxx 8086 to 192.168.1.130 8086 ( local ip). But I cant connect it. Here i will show the output of show run command.
Current configuration : 1452 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname RouterA
enable secret 5 $1$l/ko$sibpgYNMefNJLRWO477l70
enable password cisco12$
ip subnet-zero
ip name-server 192.168.1.1
ip name-server 208.67.222.222
ip name-server 208.67.220.220
ip name-server 192.168.1.10
ip dhcp excluded-address 192.168.1.10 192.168.1.254
ip dhcp pool LAN
   network 192.168.1.0 255.255.255.0
call rsvp-sync
interface FastEthernet0/0
description WAN
ip address 115.115.123.xxx 255.255.255.252
ip nat outside
duplex auto
speed auto
no cdp enable
interface Serial0/0
no ip address
shutdown
interface FastEthernet0/1
description LAN
ip nat inside
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
ip nat pool mjsoft 115.115.123.xxx 115.115.123.xxx netmask 255.255.255.252
ip nat inside source list 1 pool mjsoft overload
ip nat inside source static tcp 192.168.1.130 8086 115.115.123.xxx 8086 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 115.115.123.xxx
ip http server
access-list 1 permit 192.168.1.0 0.0.0.255
snmp-server community public RO
snmp-server enable traps tty
dial-peer cor custom
line con 0
password cisco
login
line aux 0
line vty 0 4
exec-timeout 30 0
password cisco
logging synchronous
login
transport input telnet ssh
line vty 5 15
password cisco
login
end
RouterA#
Any help would be appreciable
Peter Paluch
Hi Sooraj,
Is this your complete configuration? The DHCP pool configuration is missing vital settings - the default gateway and DNS server, to say the least.
In addition, is the 115.115.123.xxx always the same IP address in your entire configuration? You seem to be using the same address both in NAT, and as your default gateway - which would mean that it is in fact an address of another device, which would be a problem.
Best regards,
Peter
