Cisco 857 Bridge Mode Help
DOUGLAS DRURY
Hi All,
I've been triying to configure a cisco 857 router to be in bridge mode that will allow my ASA to dial the PPPoE connection.  However I can't seem to get my config to work.  I've tied a few veriasions to get it to work but no success.  Could somboddy have a look at my config and tell me where i'm going wrong?
I get the following error when i connect to the console.
*Dec 27 11:56:46.660: %TBRIDGE-4-NOVCFLOOD: No VC's configured for bridging on ATM0
Router#sh run
Building configuration...
Current configuration : 1005 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
enable password 1234
no aaa new-model
dot11 syslog
ip cef
archive
log config
  hidekeys
interface ATM0
no ip address
no ip route-cache cef
no ip route-cache
no atm ilmi-keepalive
pvc 0/38
  encapsulation aal5mux ppp dialer
dsl operating-mode auto
bridge-group 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
no ip address
no ip route-cache
bridge-group 1
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
bridge 1 protocol ieee
line con 0
logging synchronous
no modem enable
transport output all
line aux 0
line vty 0 4
password 1234
login
transport input all
scheduler max-task-time 5000
end
Peter Paluch
Hi Douglas,
Replace the encapsulation aal5mux ppp dialer in your PVC 0/38 with encapsulation aal5snap and try again. You may also need to add the protocol bridge broadcast along with the encapsulation command on that PVC.
Best regards,
Peter
