Port forwarding in Cisco ISR 2811
Not applicable
Hi I have a Cisco ISR2811 running advanced ip services with CME and CUE in it.
I need to Port forward from the outside to the inside port 22 for SSH.
example outside ip address 1.1.1.1 inside ip address 10.100.100.10
I know I need the command
ip nat inside source static tcp <private ip> 22 <public ip> 22
However on my ACL to permit this.
would I permit from my outside IP address or from the remote site I want to be able to access this.
and then do I apply that ACL to the FA0/0 which is the public interface as ACL 101 inbound
thank in advance
Jon Marshall
Greg
Your acl would look like
access-list 101 permit tcp host eq 22
and then yes you apply it inbound on the outside interface.
Jon
Thanks Jon I will give that a try next week.
