Port forwarding in dual WAN setup
WhateverID
Good afternoon!
I would be very thankful if someone could help me out with a simple question, that made me stuck.
I have Cisco 2910 router that have 3 interfaces:
g0/0 - LAN
g0/1 - WAN1
g0/2 - WAN2
I would like to configure port forwarding in such way that connections to both WAN interface on identical ports will be redirected to a single host in a private network. When I issue command:
ip nat inside source static tcp 10.10.10.X 8080 interface g0/1 8080
everything is fine, until I add the second command:
ip nat inside source static tcp 10.10.10.X 8080 interface g0/2 8080
After that, the first statement is just replaced by the second one, not added to configuration.
It would be great if someone could give me an advice!
Thanks in advance!
It's not that simple ...
You need two IP-adresses on your server and route-maps to control the return-traffic:
interface Gig0/0
  ip policy route-map Gig0/0-IN
You need two NAT-statements for the two IPs on the server:
ip nat inside source static tcp 10.10.10.101 8080 interface Gig0/1 8080
ip nat inside source static tcp 10.10.10.102 8080 interface Gig0/2 8080
With the help of PBR you force the return-traffic to the right link:
ip access-list extended TRAFFIC-FROM-10.10.10.101
  permit tcp host 10.10.10.101 eq 8080 any
ip access-list extended TRAFFIC-FROM-10.10.10.102
  permit tcp host 10.10.10.102 eq 8080 any
route-map Gig0/0-IN permit 10
  match ip address TRAFFIC-FROM-10.10.10.101
  set interface Gig0/1
route-map Gig0/0-IN permit 20
  match ip address TRAFFIC-FROM-10.10.10.102
  set interface Gig0/2
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
interface Gig0/0
Thanks a lot Karsten!
That's a good idea. I know about return traffic problem and actually wanted to use the second line as a "standby" configuration to use when the routing table changes and connections will flow via the second interface.
Anyway, your advice is great and I might use it.
You rock!
