Port forwarding on 2811 multipal sub interfaces
jacobwl01
Good Morning all,
i am trying to port forward ports 3389,80,443 for my internal server on my network . i get a public ip from my cable modem via dhcp . i got pat working and everything else besides the port forwarding . what am i missing . i have my static nat statements but its not working . is it something to do with my ACL for my wan interface?
version 15.1
hostname JLNS-Core-RT1
boot-start-marker
boot-end-marker
aaa new-model
aaa group server radius RAD_SERVERS
server-private 172.63.20.10 auth-port 1812 acct-port 1813 key Cisco1
aaa authentication login default group RAD_SERVERS local
aaa authorization exec default group RAD_SERVERS local if-authenticated
aaa session-id common
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 172.20.0.254
ip dhcp excluded-address 172.20.0.200
ip dhcp excluded-address 172.20.64.254
ip dhcp excluded-address 172.20.32.254
ip dhcp excluded-address 172.20.15.254
ip dhcp excluded-address 172.20.16.254
ip dhcp excluded-address 172.20.56.254
ip dhcp excluded-address 172.20.0.201
ip dhcp excluded-address 172.20.32.147
ip dhcp excluded-address 172.20.32.104
ip dhcp pool Network_Devices
   network 172.20.0.0 255.255.255.0
   dns-server 8.8.8.8
   domain-name jlns.local
   default-router 172.20.0.254
ip dhcp pool JLNS_Wired
   network 172.20.64.0 255.255.255.0
   default-router 172.20.64.254
   dns-server 8.8.8.8
ip dhcp pool MTL_Wired
   network 172.20.32.0 255.255.255.0
   default-router 172.20.32.254
   dns-server 8.8.8.8
ip dhcp pool JLNS_Wifi
   network 172.20.15.0 255.255.255.0
   default-router 172.20.15.254
   dns-server 172.20.0.201
ip dhcp pool MTL_Wifi
   network 172.20.16.0 255.255.255.0
   default-router 172.20.16.254
   dns-server 8.8.8.8
ip dhcp pool Guest-Wifi
   network 172.20.14.0 255.255.255.0
   default-router 172.20.14.254
   dns-server 8.8.8.8
ip dhcp pool KCopier
   host 172.20.32.147 255.255.255.0
   hardware-address 00c0.ee16.b714
ip dhcp pool KScanner
   host 172.20.32.104 255.255.255.0
   hardware-address 00c0.ee71.2675
ip domain name JLNS.local
ip ddns update method myupdate
DDNS
interval maximum 2 0 0 0
no ipv6 cef
voice-card 0
license udi pid CISCO2811 sn FTX1346A16X
username admin privilege 15 password 0 Willys52!
redundancy
interface Loopback0
description SSH Int
no ip address
interface FastEthernet0/0
description Link to Spectrum
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.2
description vlan2 int
encapsulation dot1Q 2
ip address 172.20.0.254 255.255.255.0
ip nat inside
interface FastEthernet0/1.3
description JLNS-Wired VLAN Int
encapsulation dot1Q 3
ip address 172.20.64.254 255.255.255.0
ip nat inside
interface FastEthernet0/1.4
description vlan4 int
encapsulation dot1Q 4
ip address 172.20.32.254 255.255.255.0
ip nat inside
interface FastEthernet0/1.5
description vlan5 int
encapsulation dot1Q 5
ip address 172.20.15.254 255.255.255.0
ip nat inside
interface FastEthernet0/1.6
description vlan6 int
encapsulation dot1Q 6
ip address 172.20.16.254 255.255.255.0
ip nat inside
interface FastEthernet0/1.7
description vlan7 int
encapsulation dot1Q 7
ip address 172.20.14.254 255.255.255.0
ip nat inside
interface FastEthernet0/1.8
description vlan8 int
encapsulation dot1Q 8
ip address 172.20.56.254 255.255.255.0
ip helper-address 172.20.56.201
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list My_LAN interface FastEthernet0/0 overload
ip nat inside source static tcp 172.20.0.200 3389 interface FastEthernet0/0 3389
ip nat inside source static tcp 172.20.0.200 443 interface FastEthernet0/0 443
ip nat inside source static tcp 172.20.0.200 80 interface FastEthernet0/0 80
ip route 0.0.0.0 0.0.0.0 dhcp
ip access-list standard My_LAN
permit any
ip access-list extended My_WAN
permit tcp any any established
deny   tcp any any
deny   ip any any
logging esm config
control-plane
mgcp profile default
line con 0
exec-timeout 5 30
logging synchronous
line aux 0
line vty 0 4
exec-timeout 5 30
logging synchronous
transport input ssh
line vty 5 15
exec-timeout 5 30
logging synchronous
transport input ssh
scheduler allocate 20000 1000
end
14 Replies 14
balaji.bandi
if all your out going working
you can remove NAT for the host as below
access-list My_LAN deny tcp host 172.20.0.200 eq 443 any
access-list My_LAN deny tcp host 172.20.0.200 eq 3389 any
access-list My_LAN deny tcp host 172.20.0.200 eq 80 any
i will also change this for good :
to
ip route 0.0.0.0 0.0.0.0  fast 0/0
BB
thanks for the reply. i tried the ip route 0.0.0.0 0.0.0.0 fa 0/0 and it wasnt working . thats why i added the dhcp
can you provide me a example config to how to configure my acls to allow rdp in from  the internet connection
try below and let us know how it goes, make sure you do this config in LAN or Console (not from outside)
no ip access-list standard My_LAN
permit any
BB
you already get how how config acl for dynamic pat,
but if it not work please show me translate NAT table.
i will get it for you when i get home . i can get out from the internal network , but i cant get in from the outside thats what i will need help with
I just let you know, the IP coming from ISP DHCP, so you need to know that IP address and connect to that IP to work.
Make sure internally the IP host is running those services? - check internally before you try outside.
Once you try from outside, if not work post the logs and NAT translation to look. (make sure end device do not have any FW built in)
BB
ok thanks ,
would this rule work in my my_Wan acl
permit tcp  any int ip of server eq 3389
deny tcp any any
deny  ip any any
please let me know if this rule would allow traffic in for rdp sessions
the high level that ACL is not used anywhere, it redundant, try advised config on the router and test and advise, rather making things complicated.
BB
Tcp establish acl
we will deny any tcp traffic from pass our router fw except the tcp with ack and rst flag,
here the tcp is initiate from inside “ your local lan”
so as you mention you have three sever inside But
server not initiate traffic it respond to client in wan which initiate traffic
that’s why you need to remove this acl and replace with
permit tcp any host port
where host is your server ip and it port
can you give me a sample acl for this so i can see how it should be setup please
which one worked ?
BB
permit ip any
permit tcp any any 3389
permit tcp any any 443
permit tcp any any 80
deny   tcp any any
deny ip any any
ip access-group My_WAN in
ip nat outside
try above config
thanks that worked without the access-group in on the outside int. should i still add it ?
you mention in your post the My_WAN acl and i modify only
it up to you config it or not.
