Port Forwarding on 881 doesn't work
Hello. I'm not into Cisco at all, but fate has decided that I ought to make some changes in my Cisco 881 router. I need to forward several ports to allow users to connect thru VPN tunnel to WinServer2019 which is behind NAT.
My public IP is x.x.171.5, router's local IP is 192.168.11.5 and destinated local server IP is 192.168.11.3.
So I guess, I needed to forward UDP 500 and UDP 4500 from x.x.171.5 leading to 192.168.11.3.
I've read whole lotta mans, managed to connect to router via Putty, made some changes according to docs (like "ip nat inside source static udp 192.168.11.3 500 x.x.171.5 500 extendable").
Now, if I execute command "show ip nat translation", I can see the changes I made, saying:
udp x.x.171.5:500 192.168.11.3:500 --- ---
udp x.x.171.5:4500 192.168.11.3:4500 --- ---
BUT, the ports are still closed and I'm unable to connect to local server from outside net. What do I do?
Thanks.
balaji.bandi
syntax look ok
other information required is :
1. can you post full configuriaton.
2. to check any other ACL stopping - traffic.
3. is the Server Listening on that ports ?
4. you can test locally telnet serverip 500 and 4500 ?
BB
6 Replies 6
balaji.bandi
syntax look ok
BB
Not sure about ACL rules. Firewall is temporarily down, but telnet ServerIp 500 says connection error. Hm...
Here is config:
cisco881#show run
Building configuration...
Current configuration : 3540 bytes
! Last configuration change at 15:00:43 UTC Wed Sep 9 2020 by admin
version 15.3
service password-encryption
hostname cisco881
boot-start-marker
boot-end-marker
aqm-register-fnf
enable secret 5 $1$zzTw$YYGpi7ieLw12hFlCy0
aaa new-model
aaa authentication login default local
aaa session-id common
ppp packet throttle 30 1 30
memory-size iomem 10
ip domain name router.domain
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip inspect name INSPECT_OUT dns
ip inspect name INSPECT_OUT ntp
ip inspect name INSPECT_OUT http
ip inspect name INSPECT_OUT https
ip inspect name INSPECT_OUT ftp
ip inspect name INSPECT_OUT icmp router-traffic
ip inspect name INSPECT_OUT tcp router-traffic
ip inspect name INSPECT_OUT udp router-traffic
ip cef
no ipv6 cef
vpdn enable
vpdn-group VPN
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
license udi pid C881-K9 sn FGL192522FB
username admin privilege 15 secret 5 $1$s/43$NBIG00LV6h9i6COe/
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
no ip redirects
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface Vlan1
description INSIDE
ip address 192.168.11.5 255.255.255.0
ip accounting output-packets
ip nat inside
interface Dialer0
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname v1830552
ppp chap password 7 0316531F52592A554A
ppp pap sent-username v18552 password 7 071D29581F121C13
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat pool FTPSRV 192.168.11.3 192.168.11.3 netmask 255.255.255.0 type rotary
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static tcp 192.168.11.2 20 x.x.171.5 20 extendable
ip nat inside source static tcp 192.168.11.2 21 x.x.171.5 21 extendable
ip nat inside source static udp 192.168.11.3 4500 x.x.171.5 4500 extendable
ip nat inside destination list FTPRULE pool FTPSRV
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended FTPRULE
permit tcp any any range ftp-data ftp
permit tcp any any range 50000 50100
ip access-list extended OUTSIDE-->IN
permit tcp any any eq ftp
permit tcp any any eq ftp-data
deny ip any any log
access-list 1 permit 192.168.11.0 0.0.0.255
access-list 1 permit 192.168.0.0 0.0.255.255
access-list 103 permit ip any any
access-list 114 permit ip any host 192.168.11.2
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
transport input telnet ssh
scheduler allocate 20000 1000
end
balaji.bandi
how you got this IP addres - x.x.171.5 ? is this static IP.
below syntax will help you to test.
ip nat inside source static udp 192.168.11.3 500 In interface Dialer0 500 extendable
ip nat inside source static udp 192.168.11.3 4500 In interface Dialer0 4500 extendable
telnet ServerIp 500  << hope you have replaced SERVERIP with IP ?)
example : telnet 192.168.11.3 500
BB
Yeah, I've just manually hidden the correct IP with x symbols. For security reasons
Telnet won't show anything, since there ain't no clients listening to port 500 or 4500.
Anyway, your first reply pushed me into re-thinking some steps and I found out what was wrong about my VPN port forwarding. I had to additionally forward UDP 1701 for L2TP/IPsec, plus some minor changes in security settings. And VPN went up. Thanks, buddy
Glad all went well, good to hear all sorted? and thanks for marking as resolved.
BB
--> I need to forward several ports to allow users to connect thru VPN tunnel to WinServer2019 which is behind NAT.
Your VPDN configuration is incomplete. How are your users trying to access the server ?
