Port Forwarding ( PAT ) issue on ASA5505
Martijn de Loos
Hello all,
I have a very weird issue concerning PAT.
I have an ASA5505 with ASA8.2(2) running. The outside interface is on "dhcp setroute" mode and receives an IP address from our ISP. The inside interface is connected to a switch with desktops connected it. I have specified a NAT rule which allows the inside network to NAT over the outside interface and I have specified an ACL on the inside interface which allows all incoming traffic to the outside world. This works perfectly so far. Every host has internet connection.
Here comes the tricky part where I'm already stuck on for a day. There is one host which runs a Teamspeak2 server on port 4444. So in ASDM, I created a static NAT rule specifying the inside adres of the host to be translated over the outside interface using PAT UDP 4444. I created an ACL on the outside interface specifying that "any" incoming to destination "outside" on UDP/4444 should be allowed. However, no one is able to access my Teamspeak2 server, including myself. I can only connect to it on the internal address, so the server is actually running!
I also tried the same with RDP. No success either. There is no (Windows) firewall running on the end hosts. Please see my config below and the attached screenshots. I hope someone can help me out.
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.254 255.255.255.0
interface Vlan10
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
interface Ethernet0/1
interface Ethernet0/2
shutdown
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
switchport access vlan 10
boot system disk0:/asa822-k8.bin
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
name-server 8.8.8.8
same-security-traffic permit intra-interface
access-list inside_access_in extended permit ip any any
access-list outside_access_in extended permit udp any interface outside eq 4444
access-list outside_access_in extended permit tcp any interface outside eq 3389
access-list outside_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 10.7.0.0 255.255.0.0
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 10.0.0.0 255.255.0.0
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 10.7.0.0 255.255.0.0
access-list outside_2_cryptomap extended permit ip 192.168.1.0 255.255.255.0 10.0.0.0 255.255.0.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-631.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0 dns
static (inside,outside) tcp interface 3389 192.168.1.101 3389 netmask 255.255.255.255
static (inside,outside) udp interface 4444 192.168.1.101 4444 netmask 255.255.255.255
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.104 255.255.255.255 inside
http 192.168.1.101 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer 85.***.***.***
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map 2 match address outside_2_cryptomap
crypto map outside_map 2 set pfs
crypto map outside_map 2 set peer 217.***.***.***
crypto map outside_map 2 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy DfltGrpPolicy attributes
tunnel-group 85.***.***.*** type ipsec-l2l
tunnel-group 85.***.***.*** ipsec-attributes
pre-shared-key *****
tunnel-group 217.***.***.*** type ipsec-l2l
tunnel-group 217.***.***.*** ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect ip-options
  inspect icmp
  inspect icmp error
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Gajendra R'
hi Friend ,
  as of i understand that you have configure same port to be translate with same port no only.. which i think should not be like this...either way you do one thing
remove below config.(its doest not make any sense where same port to going to translate with same one )
try to modify your below config which i thik in wrong direction you put it.
( access-group inside_access_in in interface outside)
Enjoy........
