Port mirroring on WAN for Cisco 851W
Daniel Perez
I have looked up the command sequence for port mirroring and it seems pretty straight forward however in my case the command will not execute.
I have a 851W with 12.4T
If I do:
#monitor session 1 source interface fa 4      (wan port)
i get the response invalid input detected however if I do the same command for fa 1, fa ,2 and fa 3 they work
Using the ? help shows the valid entries are [0-4] for fastethernet
Is the help dialogue wrong here or have I missed something?
I just want to monitor WAN traffic with WireShark, particularly DDNS requestes, with a spare PC connected to a free lan port.
I would use a hub on the Wan connection but unfortunately I do not have one at the moment.
Hi for rite this is supported on your platform but you need at least this IOS:
c850-advsecurityk9-mz.124-2.T
Regards.
Alain.
8 Replies 8
cadet alain
Hi daniel,
I Think the WAN port is a router port and so it doesn't support SPAN but you can use either one of these 2:
1) RITE
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/ht_rawip.html
2) EPC
http://www.cisco.com/en/US/docs/ios/netmgmt/configuration/guide/nm_packet_capture_ps6441_TSD_Products_Configuration_Guide_Chapter.html
Regards.
Alain.
Thank you!
Very nice solutions. I have a little reading to do but I think the included examples will help me just fine.
While your answer may be correct are you certain I can utilize these options on a 851?
There are no commands like 'monitor capture buffer' or 'ip traffic-export' that I can see in ? Help
Is it possible these features are only available on higher-end devices. The IP traffic export manual says that only 1841 , 2800 and 3800 series are supported so I then kept my fingers crossed to see if embedded capture was an option but the command set is not there either. I did not see any dialogue saying the 800 series was excluded from the embedded capture PDF.
Do I need a newer IOS? I am at 12.4T (experimental)
It woul be really disappointing to find out this device lacks such simple fetures. I have seen cheapo Best-Buy routers with some mirroring capabilty.
Thanks again.
Regards.
Alain.
This is what shows up un mine:
Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Experimental  Version 12.4(20080529:203115) [ppergame-sq51158 102]
Is that still too early a rev? I am not sure what the number in the parenthesis mean.
Thanks for your help
I'm sorry but this is the first time I see this IOS version but indeed it seems it's not a good one for RITE.
Regards.
Alain.
Scratch my last reply I loaded a newer rev and I think I have enabled some new command sets. I will get back to you if it does not work.
I tried to use IOS 12.4(15) to see if I would get 'IP Traffic Export Packet' features and I got zero. I looked further into it with the Cisco Feature Navigator and surprise, the features has been removed from the IOS on newer revisions. Seems a little silly to remove a nice feature like that huh?
At this point it may be easier for me to use a cheap $10 hub on my WAN link.
