Port range forwarding and VPN
Derdo
Hello Techs,
for our customer PBX I have to forwad ports from 9,000 to 10,999.  I tried to do it with the route-map command and an ACL, but in this case all site-to-site VPN connections are disconnected.
Public ip address: 96.76.166.76
PBX ip address: 172.16.164.1
Here is an excerpt from the configuration:
interface GigabitEthernet8
ip address 96.76.166.76 255.255.255.252
ip nat outside
interface GigabitEthernet6
switchport access vlan 75
no ip address
interface Vlan75
ip address 172.16.164.254 255.255.255.0
ip nat inside
ip nat inside source route-map SDM_RMAP_1 interface GigabitEthernet8 overload
ip nat inside source static udp 172.16.164.1 5060 96.76.166.76 5060 extendable
route-map SDM_RMAP_1 permit 1
match ip address 104
access-list 104 deny   ip 172.16.166.0 0.0.0.255 172.16.174.0 0.0.0.255
access-list 104 deny   ip 10.7.0.0 0.0.0.255 172.16.176.0 0.0.0.255
access-list 104 deny   ip 172.16.166.0 0.0.0.255 172.16.176.0 0.0.0.255
access-list 104 deny   ip 10.7.0.0 0.0.0.255 172.16.168.0 0.0.0.255
access-list 104 deny   ip 172.16.166.0 0.0.0.255 172.16.168.0 0.0.0.255
access-list 104 deny   ip 10.7.0.0 0.0.0.255 172.16.169.0 0.0.0.255
access-list 104 deny   ip 172.16.166.0 0.0.0.255 172.16.169.0 0.0.0.255
access-list 104 deny   ip 10.7.0.0 0.0.0.255 172.16.170.0 0.0.0.255
access-list 104 deny   ip 172.16.166.0 0.0.0.255 172.16.170.0 0.0.0.255
access-list 104 deny   ip 10.7.0.0 0.0.0.255 172.16.171.0 0.0.0.255
access-list 104 deny   ip 172.16.166.0 0.0.0.255 172.16.171.0 0.0.0.255
access-list 104 deny   ip 10.7.0.0 0.0.0.255 172.16.172.0 0.0.0.255
access-list 104 deny   ip 172.16.166.0 0.0.0.255 172.16.172.0 0.0.0.255
access-list 104 deny   ip 10.7.0.0 0.0.0.255 172.16.173.0 0.0.0.255
access-list 104 deny   ip 172.16.166.0 0.0.0.255 172.16.173.0 0.0.0.255
access-list 104 deny   ip 10.7.0.0 0.0.0.255 172.16.175.0 0.0.0.255
access-list 104 deny   ip 172.16.166.0 0.0.0.255 172.16.175.0 0.0.0.255
access-list 104 deny   ip 10.7.0.0 0.0.0.255 172.16.177.0 0.0.0.255
access-list 104 deny   ip 172.16.166.0 0.0.0.255 172.16.177.0 0.0.0.255
access-list 104 deny   ip 10.7.0.0 0.0.0.255 172.16.178.0 0.0.0.255
access-list 104 deny   ip 172.16.166.0 0.0.0.255 172.16.178.0 0.0.0.255
access-list 104 deny   ip 10.7.0.0 0.0.0.255 172.16.179.0 0.0.0.255
access-list 104 deny   ip 172.16.166.0 0.0.0.255 172.16.179.0 0.0.0.255
access-list 104 deny   ip 172.16.166.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 104 deny   ip 172.16.166.0 0.0.0.255 172.16.180.0 0.0.0.255
access-list 104 deny   ip 10.7.0.0 0.0.0.255 172.16.180.0 0.0.0.255
access-list 104 deny   ip 172.16.166.0 0.0.0.255 172.16.181.0 0.0.0.255
access-list 104 deny   ip 10.7.0.0 0.0.0.255 172.16.181.0 0.0.0.255
access-list 104 permit ip 172.16.165.0 0.0.0.255 any
access-list 104 permit ip 172.16.10.0 0.0.0.255 any
access-list 104 permit ip 172.16.166.0 0.0.0.255 any
access-list 104 permit ip 172.16.164.0 0.0.0.255 any
Here the attempt to implement it.
ip nat inside source static 172.16.164.1 96.76.166.76 route-map SDM_RMAP_2
route-map SDM_RMAP_2 permit 10
match ip address 106
access-list 106 permit udp 172.16.164.1 any range 9000 10999
Many thanks in advance for your contributions.
balaji.bandi
Can you post full configuration to review.
BB
Thanks for your feedback.
You can find the whole configuration in the attached file.
