Port restart automatically
iqbalkhan
I have a cisco 2950G 48 port switch.the ports of the switch restarts automatically randomly.so have any idea why this is happend??
Biplob
ankbhasi
Hi Biplob,
When you say port restarts sutomaticallt you mean the port goes down and comes back up right? In that case can you check the logs and update us what do you see there and the errors reported on that particular interface?
Ankur
ramachandran.n
first step u can check duplex & Speed & port fast settings.
ok , I check and let you know later.
Biplob
