port security and 802.1x
join_sn09
Dear All,
Please help me to advice!!
i had Cisco Switch 3560 and Cisco Switch 500 and i you like to do port security and 802.1x. Please tell me how can i configure?
Note: Switch 3560 is core switch.for 802.1x for authentication for Lan.
Best Regards,
Join
hadbou
Level 5
Level 5
Port security can be enabled by configuring port based authentication on cisco 3560 switches as you wish.
The document "Configuring IEEE 802.1x Port-Based Authentication" for 3650 located in the URL below will be of great use to you in configuring IEEE 802.1x Port-Based Authentication:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_37_se/configuration/guide/sw8021x.html#wp1270660
