Possible BGP, network unreachable issue
Athiqur Rahman
I am doing a simple BGP peering with my ISP, advertising my /23 subnet.
**** I have changed lot of the IP addresses for security reason ******
The subnet i am advertising is
217.70.60.0/23
My router IP is
49.70.40.162
my Neighbour IP is
49.70.40.161
My config is as follows
router bgp 16000
bgp router-id 217.70.60.9
network 217.70.60.0/23
neighbor 149.70.40.161 remote-as 1700
neighbor 149.70.40.161 description ISP
neighbor 149.70.40.161 weight 150
The ISP is sending me defautl route only
  Network          Next Hop            Metric LocPrf Weight Path
*> 0.0.0.0          149.70.40.161                         150 1700 i
*> 217.70.60.0/23   0.0.0.0                  0         32768 i
The BGP is established fine. I have internet connection fine. However there certain IP addresses that i can not reach from behind my router.
from my router, presenting source IP of
49.70.40.162
i am able to ping 2 IP fine
212.41.185.231, 212.41.185.237
However, if I ping from a machine A, with IP 217.70.60.75, which has its GW as 217.70.60.9, i am unable to reach the IP's
From my router, Where i can do a successful ping, the traceroute shows
Tracing the route to no-dns.as5587.net (212.41.185.231)
  1 te2-6.359.ccr01.lon03.atlas.cogentco.com (149.6.147.45) [AS 1700] 0 msec 4 msec 0 msec
  2 te0-6-0-1.ccr21.lon01.atlas.cogentco.com (154.54.72.101) [AS 1700] 0 msec 0 msec
    te0-6-0-5.ccr21.lon01.atlas.cogentco.com (154.54.72.93) [AS 1700] 0 msec
  3 ae0-1704-xcr1.lnd.cw.net (195.2.22.41) [AS 1700] 0 msec 0 msec 0 msec
  4 xe-11-2-0-xur1.lns.uk.cw.net (194.70.97.65) [AS 1700] 4 msec 0 msec 0 msec
  5 195.11.50.21 [AS 1700] 0 msec 0 msec 4 msec
  6 900.rtr1.tc9.lon.as5587.net (213.253.141.33) [AS 1700] 0 msec 4 msec 0 msec
  7 f1-0.rtr1.tck.man.as5587.net (213.253.166.33) [AS 1700] 8 msec 12 msec 12 msec
  8 fa2-0.rtr1.tcw.man.as5587.net (195.134.31.6) [AS 1700] 8 msec 12 msec 12 msec
  9 pos2-0.rtr1.167-0.brd.as5587.net (212.41.187.249) [AS 1700] 12 msec 12 msec 12 msec
10 sfs2.167-0.brd.as5587.net (212.41.191.50) [AS 1700] 12 msec 16 msec 12 msec
11 * * *
When tracing route from machine A, where ping is unsuccessful it looks like the following
traceroute to 212.41.185.231 (212.41.185.231), 30 hops max, 40 byte packets
1  rbr.telecom2.net (217.70.60.9)  0.547 ms  0.526 ms  0.516 ms
2  te2-6.359.ccr01.lon03.atlas.cogentco.com (149.6.147.45)  1.443 ms  1.479 ms  1.648 ms
3  te0-1-0-7.ccr21.lon01.atlas.cogentco.com (154.54.72.177)  1.327 ms te0-6-0-1.ccr21.lon01.atlas.cogentco.com (154.54.72.101)  1.421 ms  1.414 ms
4  ae0-1704-xcr1.lnd.cw.net (195.2.22.41)  0.938 ms  1.063 ms  1.047 ms
5  xe-11-2-0-xur1.lns.uk.cw.net (194.70.97.65)  1.045 ms  1.232 ms  1.229 ms
6  * * *
I can see on the traceroute of the successful ping that we get past the ip 194.70.97.65. On the traceroute of the failed ping i can see that it has gone past this stage.
What can i gather from this data as to why I can not ping the IP's  212.41.185.231, 212.41.185.237 from a machine behind my router?
Any, pointers or advice is appreicated.
chryan
The fact that pings and traceroutes work when sourced from the outgoing interface, that tells me that the connected network is known to the end device. Try your pings and traceroutes with a source ip address of your LAN interface (or any other connected interfaces) and see what you get.
Also, if possible, attempt the pings and traceroutes from the opposite end, back towards you. See what you get there too.
Chuck
