Possible firewall / acl issue ?
mcbosher71
Can anyone help please ?
I need my web server to be accessable and i have used >>>
ip nat inside source static tcp 80 interface fa0/0 80 but the packets are still being blocked by the access-list maybe ?
%SEC-6-IPACCESSLOGP: list 101 denied tcp 119.63.196.89(34388) -> 81.***.***.***(80)
First off .. is it safe to post your security / access list on here ?
Many thanks guys
24 Replies 24
Garry,
This would have only worked if you had a public address to map the internal web server ip too, I assumed you did have one.
Can you for testing remove CBAC and ACL's  from you interface settings
Then if you get connection reapply the acls making sure the TCP statement for port 80 isnt listed as a low priority in the acl
res
Paul
Kind Regards
Paul
Hi pdriver,
I have disabled the acl 100 in and 101 in but i dont know what you mean by CBAC ?
internet is working again now but for how long ??
this happened before ... it worked then slowly blocked and no http?
Phish#sh startup-config
Using 1818 out of 196600 bytes
version 12.4
hostname Phish
boot-start-marker
boot-end-marker
enable secret 5 $1$mUiL$Wp/m0Ciaigy4nQA77SeI0.
enable password *********
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.30
ip dhcp pool insudeDHCP
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
interface FastEthernet0/0
description WAN$FW_OUTSIDE$
mac-address 0012.1742.1fe9
ip address dhcp
ip access-group 101 in
ip nat outside
ip inspect SDM_LOW out
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description LAN$FW_INSIDE$
ip access-group 100 in
ip nat inside
speed auto
full-duplex
no mop enabled
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.1.10 80 interface FastEthernet0/0 80
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
password *******
login
scheduler allocate 20000 1000
end
this is before applying johns settings
thanks
Hi garry,
remove ip inspect SDM_LOW out from you wan interface,
Do you say that you now have connection your WEB server?
Kind Regards
Paul
hi,
yes i have internet again ? but no www routing to my server
will remove ip inspect SDM_LOW out now ... brb
thanks
ok done that ... removed ip inspect sdm low for http only
here is a port scan result
GRC Port Authority Report created on UTC: 2011-07-21 at 07:54:06
Results from scan of ports: 0, 21-23, 25, 79, 80, 110, 113,
                            119, 135, 139, 143, 389, 443, 445,
                            1002, 1024-1030, 1720, 5000
    2 Ports Open
   21 Ports Closed
    3 Ports Stealth
   26 Ports Tested
Ports found to be OPEN were: 23, 80
Ports found to be STEALTH were: 135, 139, 445
Other than what is listed above, all ports are CLOSED.
TruStealth: FAILED - NOT all tested ports were STEALTH,
                   - NO unsolicited packets were received,
                   - A PING REPLY (ICMP Echo) WAS RECEIVED.
Okay so can you now post your exisitng config:
Kind Regards
Paul
Garry,
Its looks like you have removed the acl config instead of just removing the ip access-group statements, would be good to remove all ios sec just for the time being, but if you dont wish to do that, try the following.
int fa0/1
no ip access-group 100 in
add:
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
no access-list 101
access-list 101 deny   ip 192.168.1.0 0.0.0.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 deny   ip 172.16.0.0 0.0.255.255 any
access-list 101 deny   ip 192.168.0.0 0.0.255.255 any
access-list 101 deny   ip 224.0.0.0 15.255.255.255 any
access-list 101 deny   ip any host 192.168.1.255
access-list 101 deny   ip any host 192.168.1.0
access-list 101 permit tcp any any eq www - ( or use public ip address)
access-list 101 deny   icmp any any redirect
access-list 101 deny   icmp any any mask-request
access-list 101 permit icmp any host x.x.x.x (public ip address)
res
Paul
Kind Regards
Paul
Hi Paul,
Sorry but I have been unable to make any posts from my network on the 1841 ??
And today is the first day I have been able to use my iPhone on this forum too?
I tried your setting and I lost all Internet access so I have wiped and restarted as i feel the iOS security was an issue
So I am back with a default config again and I now have Internet access yet again.
My server is accessible from my iPhone on 3G but not using Internet to my domain name on my pc that
Is on the 1841 network though I can access my server on my internal LAN?
Will try and get the basic config up for you in the next few hrs.
Thanks for your time.
I think i have found the reason for all of this not being able to call my www up from my external address.
It's an DNS issue...sort of, as well as a consumer router issue...sort of.
Essentially, most businesses are using running their own DNS server so you just need to put the appropriate entries into DNS but it probably doesn't need to be the full domain, just the name (exmaple, "mailserver" instead of "mailserver.domain.com").
Most consumer routers have a loopback style feature that will allow you to resolve back to internal devices using the external IP address or DNS name
Most consumer routers have a loopback style feature that will allow you to resolve back to internal devices using the external IP address or DNS name.
I believe that some thing like this would correct this ? correct me please if need be ...
ip dns view default
domain timeout 1
domain retry 0
domain round-robin
dns forwarder 4.2.2.2
dns forwarder 4.2.2.1
ip dns server
Then just make sure your DNS server match your routers internal IP in your DHCP scope.
ip dhcp pool insideDHCP
dns-server 192.168.1.1
Any thoughts ?
thank you
mcbosher71
Well its been a month or so now and all is pretty much ok, with a few exceptions and it is about the fact i just cant access my extrenal ip address from inside the network im hosting my server from?
I was told its due to the device not allowing it ?
So thanks again to those of you who had the time to help out.
