Power/Fan Module P0 EEPROM data is not initialized
kdsingh007
I got an alert in nnmi and looking further into it I found Cisco Bug: CSCvf75650
Traceback: "i2c fantray mux" failure
when I ran command # show diag all on cisco ASR-920-4SZ-A, I see following lines in the output
Power/Fan Module P1 EEPROM data is not initialized
Power/Fan Module P2 EEPROM data is not initialized
what information does these give me?
Mark Elsen
    - Check the LED status on the fan tray(s) , a red LED indicates a major failure
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
hi,
these routers are out in the field and have no physical access to them at this time. any other solution?
thanks
jlopezmo
FAN and PSU use I2C communication to report their status. It's possible that hardware/software issue is present in the router, did you notice any error message in the logs? Can you confirm the status of the LED on FAN Tray? What is the current software version running in the router?
