Showing results forĀ
Search instead forĀ
Did you mean:Ā
ppp auth failed with ms-chap-v2
telelvisjr
Hello, all
I'm trying to connect to ISP with PPPoE method using Cisco 861 equip. On the other side Cisco 3845 BRAS.
Session fails at authentication phase. Authentication protocol chosen by routers is ms-chap-v2. Chap supported also.
So here is a debug
Jan  3 14:27:38 MSK: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
Jan  3 14:27:38 MSK: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
22:27:40: Vi1 PPP: Sending cstate UP notification
22:27:40: Vi1 PPP: Processing CstateUp message
22:27:40: AAA/BIND(00000B0C): Bind i/f Virtual-Access1
22:27:40: PPP: Alloc Context [844DF258]
22:27:40: ppp810 PPP: Phase is ESTABLISHING
22:27:40: ppp810 PPP: Using AAA Unique Id = B0C
22:27:40: AAA/AUTHOR (00000B0C): Method list id=0 not configured. Skip author
22:27:40: Vi1 PPP: Authorization NOT required
22:27:40: Vi1 PPP: Using dialer call direction
22:27:40: Vi1 PPP: Treating connection as a callout
22:27:40: Vi1 PPP: Session handle[C300003C] Session id[810]
22:27:40: Vi1 LCP: Event[OPEN] State[Initial to Starting]
22:27:40: Vi1 LCP: O CONFREQ [Starting] id 1 len 15
22:27:40: Vi1 LCP:    AuthProto CHAP (0x0305C22305)
22:27:40: Vi1 LCP:    MagicNumber 0x981EF7EB (0x0506981EF7EB)
22:27:40: Vi1 LCP: Event[UP] State[Starting to REQsent]
22:27:40: Vi1 LCP: I CONFREQ [REQsent] id 1 len 19
22:27:40: Vi1 LCP:    MRU 1492 (0x010405D4)
22:27:40: Vi1 LCP:    AuthProto MS-CHAP-V2 (0x0305C22381)
22:27:40: Vi1 LCP:    MagicNumber 0x903962FB (0x0506903962FB)
22:27:40: Vi1 LCP: O CONFNAK [REQsent] id 1 len 8
22:27:40: Vi1 LCP:    MRU 1500 (0x010405DC)
22:27:40: Vi1 LCP: Event[Receive ConfReq-] State[REQsent to REQsent]
22:27:40: Vi1 LCP: I CONFACK [REQsent] id 1 len 15
22:27:40: Vi1 LCP: Event[Receive ConfAck] State[REQsent to ACKrcvd]
22:27:40: Vi1 LCP: I CONFREQ [ACKrcvd] id 2 len 19
22:27:40: Vi1 LCP: O CONFACK [ACKrcvd] id 2 len 19
22:27:40: Vi1 LCP: Event[Receive ConfReq+] State[ACKrcvd to Open]
22:27:40: Vi1 PPP: Queue CHAP code[1] id[1]
22:27:40: Vi1 PPP: Phase is AUTHENTICATING, by both
22:27:40: Vi1 CHAP: O CHALLENGE id 1 len 27 from "ppp009"
22:27:40: Vi1 CHAP: Redirect packet to Vi1
22:27:40: Vi1 MS-CHAP-V2: I CHALLENGE id 1 len 23 from "r1"
22:27:40: AAA/AUTHEN/PPP (00000B0C): Pick method list ' Permanent Local'
22:27:40: Vi1 PPP: Sent MSCHAP_V2 SENDAUTH Request
22:27:40: Vi1 LCP: State is Open
22:27:40: Vi1 PPP: Received SENDAUTH Response FAIL
22:27:40: Vi1 MS CHAP V2: Using hostname from interface CHAP
22:27:40: Vi1 MS CHAP V2: Using password from interface CHAP
22:27:40: Vi1 MS-CHAP-V2: O RESPONSE id 1 len 60 from "ppp009"
22:27:40: Vi1 MS-CHAP-V2: I SUCCESS id 1 len 46 msg is "S=56927B5B36EA40071200B1BE5C285D2B3F3F3E8E"
22:27:40: Vi1 MS CHAP V2 No Password found for : r1
22:27:40: Vi1 MS CHAP V2 Check AuthenticatorResponse Success for : ppp009
22:27:40: Vi1 LCP: I TERMREQ [Open] id 3 len 4
22:27:40: Vi1 PPP DISC: Received LCP TERMREQ from peer
22:27:40: Vi1 PPP: Sending Acct Event[Down] id[B0C]
22:27:40: PPP: NET STOP send to AAA.
22:27:40: Vi1 PPP: Phase is TERMINATING
22:27:40: Vi1 LCP: O TERMACK [Open] id 3 len 4
22:27:40: Vi1 LCP: Event[Receive TermReq] State[Open to Stopping]
Jan  3 14:27:38 MSK: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
22:27:40: Vi1 PPP: Block vaccess from being freed [0x10]
Jan  3 14:27:38 MSK: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
22:27:40: Vi1 PPP: Sending cstate DOWN notification
22:27:40: Vi1 PPP: Processing CstateDown message
22:27:40: Vi1 LCP: Event[CLOSE] State[Stopping to Closing]
22:27:40: Vi1 LCP: Event[DOWN] State[Closing to Initial]
22:27:40: Vi1 PPP: Clearing AAA Unique Id = B0C
22:27:40: Vi1 PPP: Unlocked by [0x10] Still Locked by [0x0]
22:27:40: Vi1 PPP: Free previously blocked vaccess
22:27:40: Vi1 PPP: Phase is DOWN
Dialer interface config
interface Dialer1
description PPPoE
ip address negotiated
ip access-group fire in
ip mtu 1492
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
ppp encrypt mppe auto
ppp authentication chap
ppp chap hostname ppp009
ppp chap password 7 XXXXXXXXXXXXXXXXXXXXXX
ppp ms-chap-v2 refuse
ppp pap sent-username ppp009 password 7 XXXXXXXXXXXXXXXXXXXXXXXXX
no cdp enable
crypto map VPNMAP
Username and password are correct, as I tried Broadband connection on nearby Win7 workstation with these credentials.
So, I have several other locations connected to this ISP, but routers, used there, manufactured by HP MSR series. They doesn't support ms-chap-v2, only chap and I think it's a root of this issue. They can negotiate chap and authenticate with it.
Cisco 861 for some reason chooses ms-chap-v2, despite  "ppp ms-chap-v2 refuse" command.
How can be chap authentication forced in this case?
Or why ms-chap-v2 fails?
I managed to get debug from ISP side:
059781: Dec 21 10:21:23.848 CET: ppp466 PPP: Using vpn set call direction
059782: Dec 21 10:21:23.848 CET: ppp466 PPP: Treating connection as a callin
059783: Dec 21 10:21:23.848 CET: ppp466 PPP: Session handle[82000AD7] Session id[466]
059784: Dec 21 10:21:23.856 CET: ppp466 PPP: Authorization required
059785: Dec 21 10:21:23.864 CET: ppp466 MS-CHAP-V2: O CHALLENGE id 1 len 23 from "r1"
059786: Dec 21 10:21:23.876 CET: ppp466 CHAP: I CHALLENGE id 1 len 27 from "ppp009"
059787: Dec 21 10:21:23.876 CET: ppp466 CHAP: Waiting for Peer to authenticate first
059788: Dec 21 10:21:23.896 CET: ppp466 MS-CHAP-V2: I RESPONSE id 1 len 60 from "ppp009"
059789: Dec 21 10:21:23.900 CET: ppp466 PPP: Sent MSCHAP_V2 LOGIN Request
059790: Dec 21 10:21:23.940 CET: ppp466 PPP: Received LOGIN Response PASS
059791: Dec 21 10:21:23.976 CET: Vi46 MS-CHAP-V2: O SUCCESS id 1 len 46 msg is "S=64EBEE1CB11DA3C76487BA5CED517D6B8EA9745D"
059792: Dec 21 10:21:23.980 CET: Vi46 CHAP: Unable to authenticate for peer
and config:
interface Virtual-Template1
mtu 1492
ip unnumbered Loopback1
no ip redirects
ip flow ingress
ip flow egress
ip virtual-reassembly max-reassemblies 512
no logging event link-status
no peer default ip address
ppp authentication ms-chap-v2 chap
end
Thank you for assistance!
Upd:
System image file is "flash:c860-universalk9-mz.151-4.M4.bin"
Peter Paluch
Can you please try removing the ppp authentication chap command from your Dialer1 interface? By this command, you are requesting the ISP to authenticate to you which is not usually done. It is possible that the ISP is not willing to authenticate to you and drops the connection as the result.
Best regards,
Peter
Peter Paluch
Best regards,
Peter
Hello, Peter
You right,
Issue solved by removing this command. Indeed, now only ISP requests auth:
3d10h: Vi1 PPP: Phase is AUTHENTICATING, by the peer
I thought, by using this command, I list supported authentication protocols, but instead, I force CE to authenticate PE.
Thank you!
