PPP Multilink does not show traffic although related Serial link shows traffic
Kaushik Ray
Hello All
I would be grateful if someone could please provide some information on the following:
I am trying to troubleshoot dropped packets issues over a Serial link using ppp multilink;
one issue i am seeing which seems strange is that althought the Serial Link is showing traffic flowing through it the Multillink shows no traffic flowing. It could be that the two issues are unrelated but I am trying to find why i am seeing this strange outcome?
Has anybody seen / faced this issue before? or can advice why i could be seeing this?
thanks a lot in advance.
Jose Bogantes
Hello Kaushik,
Can you get the following outputs:
  • show ppp multilink
  • show run
  • show interface multilink X
  • show interface serial X/X
  • show version
Thanks Jose for your reply; please find the details below also one thing - althought I am not see the input rate / output rate on the multilink but i see the input packets / output packets incrementing on the the multilink interface
RTR#sh ppp multilink
Multilink22
  Bundle name: Client_Sitename
  Remote Endpoint Discriminator: [1] Client_Sitename
  Local Endpoint Discriminator: [1] RTR
  Bundle up for 00:12:21, total bandwidth 512, load 240/255
  Receive buffer limit 12000 bytes, frag timeout 1000 ms
  Interleaving enabled
    0/0 fragments/bytes in reassembly list
    0 lost fragments, 0 reordered
    0/0 discarded fragments/bytes, 0 lost received
    0x14CEF received sequence, 0x12ED4 sent sequence
  Member links: 1 active, 0 inactive (max 255, min not set)
    Se1/1, since 00:12:21, 640 weight, 632 frag size
No inactive multilink interfaces
RTR#sh run int mu22
Building configuration...
Current configuration : 446 bytes
interface Multilink22
ip vrf forwarding Glo_VRF
ip address XXX.XXX.XXX.XXX 255.255.255.254
ip accounting output-packets
ip tcp header-compression iphc-format
load-interval 30
ppp multilink
ppp multilink interleave
ppp multilink group 22
ppp multilink fragment delay 10
no cdp enable
service-policy output GLOBAL_POLICY
ip rtp header-compression iphc-format
end
RTR#sh run int s1/1
Current configuration : 255 bytes
interface Serial1/1
bandwidth 512
bandwidth inherit
no ip address
encapsulation ppp
load-interval 30
tx-ring-limit 1
ppp multilink
no fair-queue
max-reserved-bandwidth 100
end
RTR#sh int mu22
Multilink22 is up, line protocol is up
  Hardware is multilink group interface
  Internet address is XXX.XXX.XXX.XXX/31
  MTU 1500 bytes, BW 512 Kbit/sec, DLY 20000 usec,
  Encapsulation PPP, LCP Open, multilink Open
  Open: IPCP, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 2 seconds on reset
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 01:00:22
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 25147
  Queueing strategy: Class-based queueing
  Output queue: 75/1000/0/135346 (size/max total/drops/interleaves)
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     452063 packets input, 62012949 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     1 input errors, 0 CRC, 1 frame, 0 overrun, 0 ignored, 0 abort
     462943 packets output, 193210636 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 carrier transitions
RTR#sh int s 1/1
Serial1/1 is up, line protocol is up
  Hardware is M8T-X.21
     reliability 255/255, txload 247/255, rxload 181/255
  Link is a member of Multilink bundle Multilink22, crc 16, loopback not set
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 01:00:32
  Queueing strategy: fifo
  Output queue: 1/40 (size/max)
  30 second input rate 365000 bits/sec, 244 packets/sec
  30 second output rate 496000 bits/sec, 234 packets/sec
     490280 packets input, 64912152 bytes, 0 no buffer
     13870 input errors, 13407 CRC, 0 frame, 44 overrun, 1 ignored, 419 abort
     585736 packets output, 193843866 bytes, 0 underruns
     0 output errors, 0 collisions, 18 interface resets
     18 carrier transitions     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
RTR#sh version
Cisco IOS Software, 7200 Software (C7200P-ADVIPSERVICESK9-M), Version 15.0(1)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 28-Oct-10 22:56 by prod_rel_team
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-BOOT-M), Version 12.4(4)XD10, RELEASE SOFTWARE (fc2)
RTR uptime is 1 year, 7 weeks, 5 days, 2 hours, 30 minutes
System returned to ROM by reload at 12:26:40 UTC Sat Mar 10 2012
System restarted at 12:28:24 UTC Sat Mar 10 2012
System image file is "disk2:c7200p-advipservicesk9-mz.150-1.M4.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Processor board ID 36405058
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
6 slot VXR midplane, Version 2.11
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
48 Serial interfaces
2045K bytes of NVRAM.
990864K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
Hello Kaushik,
I am not sure about a layer 1 or layer 2 issue for the "show ppp multilink" shows an active member as it is supposed to be. I guess your concern is that there are no counters related to input and output rate in the interface multilink. Is that correct?
I have some questions to isolate the issue:
  • What is the result if you send a ping towards the peer multilink?
  • Have you cleared the interface multilink? (clear interface multilink 22) Is this making a difference?
Please clear counters to make sure if the errors are still increasing or not. It is also recommended to make sure that the subnet mask is properly configured under the interface multilink.
Regards.
vmiller
Level 7
Level 7
take a look at the counters on s1/1.
you have a layer 1 or 2 problem with this.
