PPP over Frame Relay question
blue phoenix
According to this link:
http://blog.ine.com/2008/01/07/understanding-ppp-over-frame-relay-pppofr/
and this link:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/wan_frly/configuration/15-mt/wan-frly-15-mt-book/wan-pppofr.html#GUID-1CB0E01F-B4AF-4CF6-9863-D116BBD13C2B
PPP should work over frame relay.
Can anybody please check what I have done and if you see any problem?
Please see attachment
the configuration looks good. The only thing I see is the way you have configured CHAP. On all virtual templates, just configure:
ppp authentication chap
Then, on R100, try and configure:
username R200 password 0 R200
username R300 password 0 R300
On R200:
username R100 password 0 R100
On R300:
Make sure the username matches the actual router name (R1 should be named R100).
 I labbed this in GNS3,as soon as I configure CHAP authentication, everything goes down. Not sure if this is a bug in GNS3 though.
Is your network a 'real life' network ?
I removed in the virtual-template config
ppp chap hostname RXXX
ppp chap password RXXX
Then on R100
conf t
username R300 password R300
ON R300
conf t
username R100 password R300
OSPF came up :)
bug I guess in IOL...
