PPPoE and NAT on WAN link of Cisco 1801 router
thomas.russell
Does anyone know if PPPoE can be configured on the Ethernet WAN Link of my 1801 router? fa0 will obtain a IP address thru the Speedstream 5100 and the NAT overload command seems to work fine when applied to the interface. The difference is that I can't ping the SBC DNS servers from the router like I can from my workstation. I have tried moving the login to VPDN/Dialer 0 secnario as outlined in Cisco's PDF, but all of the VPDN commands are not available on my router ie "protocol pppoe" and "initiate to A.B.C.D". I'm running Version 12.3(8)YI1 IOS. Any help would be appreciated.
routeflap
Can you post your configuration?
Brian Dennis, CCIE #2210 (R&S/ISP-Dial/Security)
bdennis@internetworkexpert.com
Internetwork Expert, Inc.
http://www.InternetworkExpert.com
Toll Free: 877-224-8987
Direct: 775-745-6404 (Outside the US and Canada)
version 12.3
hostname PM1
boot-start-marker
boot-end-marker
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface BRI0
no ip address
shutdown
interface FastEthernet0
ip address dhcp
ip nat outside
duplex auto
speed auto
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface FastEthernet4
no ip address
shutdown
interface FastEthernet5
no ip address
shutdown
interface FastEthernet6
no ip address
shutdown
interface FastEthernet7
no ip address
shutdown
interface FastEthernet8
no ip address
shutdown
interface Vlan1
ip address 192.168.67.1 255.255.255.0
ip nat inside
router eigrp 100
network 192.168.67.0
auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0
no ip http server
ip nat inside source list 2 interface FastEthernet0 overload
access-list 2 permit 192.168.67.0 0.0.0.255
control-plane
line con 0
password xxxxx
login
line aux 0
line vty 0 4
password xxxxx
login
no scheduler allocate
end
