09-02-2015 04:32 AM - edited 03-05-2019 02:12 AM
I'm in the process of building a new 7600 box to replace our internet edge router. A (difficult) requirement is that we need support for 2 PPPoE client sessions to our upstream provider. The feature navigator tells me that the PPPoE client feature (IOS >= 15.0) is only supported on branch routers (and ASR1000 platform) and not on the 7600 platform.
Is the feature navigator correct? Is this not possible at all or do i need a SIP to get this working?
To clarify, this is the configuration i want on a ethernet interface:
pppoe enable group global pppoe-client dial-pool-number 1
And a dialer interface:
interface Dialer0 ppp authentication pap callin ppp pap sent-username USER password 0 PASS
09-02-2015 09:28 AM
hi there,
I checked the build parameters for the 7600 platform and the subsystem for pppoe-client is not linked in for the 7600 in most releases out there.
I noticed that the pppoe client subsys was added via CSCud04784 Missing PPPoE client feature in IPbase to the makefiles, but I am not sure if the 7600 is picking that up.
this patch went into 15.3, so you may want to give that a try to see if that works.
now the subsys is one part, the data forwarding is another piece, so while your session may establish, possibly the hw has no clue how to forward the packets, so best to test this like crazy :)
xander
09-04-2015 04:34 AM
Unfortunately i do not have a 7600 box lying around, only 6500. Any chance someone is willing to test this?
