PPPOE configuration for Cisco 851and cisco 870 router
krishan.saran
Hi Guys
I have two cisco 850 and 870 series routers i tryed alot but i am unable to configure PPOE on both of the routers there is no PPPOE enable command available I tryed VPDN s too but no luck any body have some clue
7 Replies 7
vragotha
Level 3
Level 3
     Here is a link to the configuration guide -
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/pppoenat.html
If you are still having trouble, can you post what kind of errors you get when you try to enter the configuration commands?
I already tried these steps but at step 4 where i enter the protocol command there is no PPPoE option just only l2tp option is there
Command or Action
Purpose
Step 1
vpdn enable
Example:
Router(config)# vpdn enable
Router(config)#
Enables VPDN on the router.
Step 2
vpdn-group name
Example:
Router(config)# vpdn-group 1
Router(config-vpdn)#
Creates and associates a VPDN group with a customer or VPDN profile.
Step 3
request-dialin
Example:
Router(config-vpdn)# request-dialin
Router(config-vpdn-req-in)#
Creates a request-dialin VPDN subgroup, indicating the dialing direction, and initiates the tunnel.
Step 4
protocol {l2tp | pppoe}
Example:
Router(config-vpdn-req-in)# protocol pppoe
Specifies the type of sessions the VPDN subgroup can establish.
Step 5
exit
Example:
Router(config-vpdn-req-in)# exit
Exits request-dialin VPDN group configuration.
Step 6
exit
Example:
Router(config-vpdn)# exit
Router(config)#
Exits VPDN configuration, returning to global configuration mode.
Can you post a 'show ver' and 'show run' ?
Hi  Thanks for your help
Here is the Show Version
office(config-vpdn-req-in)#do sho ver
Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(15)T13, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 07-Apr-10 20:49 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
office uptime is 8 hours, 12 minutes
System returned to ROM by reload
System restarted at 15:41:12 PCTime Sat Aug 7 2010
System image file is "flash:c850-advsecurityk9-mz.124-15.T13.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 851 (MPC8272) processor (revision 0x300) with 59392K/6144K bytes of memory.
Processor board ID FHK1426601C
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
5 FastEthernet interfaces
128K bytes of non-volatile configuration memory.
20480K bytes of processor board System flash (Intel Strataflash)
Here is the command i was entrenig
office#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
office(config)#vpdn en
office(config)#vpdn enable
office(config)#vpdn-gro
office(config)#vpdn-group 1
office(config-vpdn)#requ
office(config-vpdn)#request-dialin
office(config-vpdn-req-in)#pro
office(config-vpdn-req-in)#protocol pp
office(config-vpdn-req-in)#protocol ?
  l2tp  Use L2TP
There is no protocol PPPoE
thans what i was doing
Hello Krishan,
your router is running 12.4(15)T you don't need anymore vpdn to enable pppoe client on it
see
http://www.cisco.com/en/US/docs/ios/bbdsl/configuration/guide/bba_ppoe_client_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1070857
there is a section for newer releases
Configuring a PPPoE Client on an Ethernet Interface
Perform this task to configure a PPPoE client on an Ethernet interface.
SUMMARY STEPS
1. enable
2. configure terminal
3. interface ethernet number
4. pppoe-client dial-pool-number number
Hope to help
Giuseppe
Any body can post the the running configuration on  12.4(15)T IOS with PPPoE configuration complete
I will be rely thankful i don't have much experience of CLI i normally configure through SDM but through SDM i am getting this PPPoE enable error. but if i have the running configuration than i can program, because i have to drive 3hour for that site and i don't want to stuck there Please Please
