PPPoE configuration problem in Linux.
premavardhan
Community Member
Hi friends,
     I am configuring PPPoE on linux. While configuration the client is not able to connect.
I am using following configurations at server side.
1. /etc/ppp/options
asyncmap 0
crtscts
lock
modem
proxyarp
lcp-echo-interval 30
lcp-echo-failure 4
2. /etc/ppp/pppoe-server-options
# PPP options for the PPPoE server
# LIC: GPL
debug
plugin /etc/ppp/plugins/rp-pppoe.so
require-pap
mtu 1492
mru 1492
ktune
proxyarp
lcp-echo-interval 10
lcp-echo-failure 2
nobsdcomp
noccp
novj
noipx
3. /etc/ppp/pap-secrects
# Secrets for authentication using PAP
# client        server  secret                  IP addresses
prem            *       prem123                 *
At client side,
1.  /etc/ppp/options
asyncmap 0
crtscts
lock
modem
proxyarp
lcp-echo-failure 4
2. /etc/ppp/pppoe.conf
ETH=eth0
USER=prem
DEMAND=no
DNSTYPE=SERVER
PEERDNS=yes
DNS1=
DNS2=
DEFAULTROUTE=yes
CONNECT_TIMEOUT=30
CONNECT_POLL=2
ACNAME=
SERVICENAME=
PING="."
CF_BASE=`basename $CONFIG`
PIDFILE="/var/run/$CF_BASE-pppoe.pid"
SYNCHRONOUS=no
CLAMPMSS=1412
LCP_INTERVAL=20
LCP_FAILURE=3
PPPOE_TIMEOUT=80
FIREWALL=NONE
LINUX_PLUGIN=/etc/ppp/plugins/rp-pppoe.so
PPPOE_EXTRA=""
PPPD_EXTRA=""
3. /etc/ppp/pap-secrets
prem           *       prem123                  *
At client side, i  am getting error like  "/usr/sbin/pppoe-start:   line 215: 2584 Terminated     $CONNECT   "$@"   >
/dev/null 2>&!.
When  i saw at server side in /var/log/messages, i am getting Nov 17 14:35:48  localhost pppoe-server[15254]: Terminating on signal 2 -- killing all  PPPoE sessions
And at tcpdump side i am not getting any packets.
Can you tell me what might be the problem.
Prem.
0 Replies 0
