Bookmark
Subscribe
457
pppoe connection with other adsl modem on Netia (provider) connection with fixed ip address
p.wasilewski1
Does anybody made this type of connection on Cisco C881 router ?
Please help me, I`m absolutely green in this type of routers.
I`m logged on this and tried a lot of configurations and every of them failed :(
My connection is fine, cause it`s working with no troubles with other hardware.
Here are paramethers from provider (not needed i guess):
Netia:
Encapsulation PPPoE
VPI: 8, VCI: 35
Multiplex LLC
any help will be appreciated
regards
Piotr
Soft version:
Router#show
00:57:47: %SYS-5-CONFIG_I: Configured from console by consoleversion
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.5(3)M, RELEAS        E SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 22-Jul-15 23:59 by prod_rel_team
ROM: System Bootstrap, Version 15.4(1r)T1, RELEASE SOFTWARE (fc1)
Here`s my config with errors listed:
Router#config
Configuring from terminal, memory, or network [terminal]?
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#version 12.3
Router(config)#no parser cache
Router(config)#no service pad
Router(config)#service timestamps debug uptime
Router(config)#service timestamps log uptime
Router(config)#service password-encryption
Router(config)#no service dhcp
Router(config)#!
Router(config)#hostname Router
Router(config)#!
Router(config)#!
Router(config)#no aaa new-model
Router(config)#ip subnet-zero
Router(config)#ip cef
Router(config)#!
Router(config)#!!!!! Configure Router as PPPoE Client to the ISP
Router(config)#vpdn enable
Router(config)#!
Router(config)#vpdn-group 1
Router(config-vpdn)#request-dialin
Router(config-vpdn-req-in)#protocol pppoe
% Invalid input detected at '^' marker.
Router(config-vpdn-req-in)#!!!!!
Router(config-vpdn-req-in)#interface fastEthernet3
Router(config-if)#description My LAN Interface
Router(config-if)#ip address 10.10.10.1 255.255.255.0
% IP addresses may not be configured on L2 links.
Router(config-if)#$urs, this interface is the source candidate (inside local)
Router(config-if)#ip nat inside
Router(config-if)#!!!!
Router(config-if)#no ip mroute-cache
Router(config-if)#no cdp enable
Router(config-if)#!
Router(config-if)#interface fastEthernet4
Router(config-if)#description Physical ADSL Interface (Facing the ISP)
Router(config-if)#no ip address
The above command is deprecated. Use MFIB commands instead.
Router(config-if)#!!!! Ties this interface to the Dialer interface
Router(config-if)#pppoe enable
Router(config-if)#pppoe-client dial-pool-number 1
Router(config-if)#!
Router(config-if)#interface Dialer1
Router(config-if)#description Logical ADSL Interface
Router(config-if)#ip address negotiated
Router(config-if)#ip mtu 1492
Router(config-if)#$interface is the destination candidate (inside global)
Router(config-if)#ip nat outside
Router(config-if)#encapsulation ppp
Router(config-if)#ip tcp adjust-mss 1452
Router(config-if)#$this logical interface to the proper physical interface
Router(config-if)#dialer pool 1
Router(config-if)#!!!!!
Router(config-if)#$ng the protocol allowed by the "dialer-list" command
Router(config-if)#dialer-group 1
Router(config-if)#ppp authentication chap pap callin
Router(config-if)#ppp chap hostname RLLL2610667@dialnet.pl
Router(config-if)#ppp chap password 0 UPXELT
Router(config-if)#$t-username RLLL2610667@dialnet.pl password 0 UPXELT
Router(config-if)#!!!! Default Gateway to the ISP
Router(config-if)#ppp ipcp route default
Router(config-if)#!
Router(config-if)#ppp ipcp dns request accept
Router(config-if)#ppp ipcp address accept
Router(config-if)#!
Router(config-if)#!!!! PAT subnets allowed by the ACL 10
Router(config-if)#ip nat inside source list 10 interface Dialer1 overload
Router(config)#!!!!
Router(config)#no ip http server
Router(config)#ip classless
Router(config)#!!!!
Router(config)#!
Router(config)#!
Router(config)#!!!! ACL 10 determines which subnet to be PATed
Router(config)#access-list 10 permit 10.10.10.0 0.0.0.255
Router(config)#!!!!
Router(config)#!!!! Determine which protocol to pass through
Router(config)#dialer-list 1 protocol ip permit
Router(config)#!!!!
Router(config)#no cdp run
Router(config)#!
Router(config)#!
Router(config)#!
Router(config)#line con 0
Router(config-line)#exec-timeout 120 0
Router(config-line)#stopbits 1
Router(config-line)#line vty 0 4
Router(config-line)#exec-timeout 0 0
Router(config-line)#login local
Router(config-line)#length 0
Router(config-line)#!
Router(config-line)#scheduler max-task-time 5000
Router(config)#end
Dan Lukes
Off topic here. Use blue [ EDIT ] button to move to Network Infrastructure -> WAN, Routing and Switching
