PPPoE DSL Problems, NGI
Fabrice_xb81
I'm trying to use a cisco 887VA-SEC-K9 router for a domestic PPPoE DSL (italian NGI DSL) but it doesn't work..
No problem with my domestic router.
I have another problem: I'm installing cisco-config-pro-exp-k9-2_6-en but it doesen't work. The browser requests login but then appears a blank page.
Is there anybody can help me?
Thank you very much
Fabrice
My configuration:
version 15.2
no service pad
hostname xbRouter
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
memory-size iomem 10
clock timezone PCTime 1 0
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
crypto pki trustpoint TP-self-signed-471455566
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-471455566
revocation-check none
rsakeypair TP-self-signed-471455566
crypto pki certificate chain TP-self-signed-471455566
certificate self-signed 01
xxx
      quit
ip domain name xb81
ip name-server 192.168.186.100
ip ddns update method ccp_ddns1
HTTP
  add http://x.x.x@members.dyndns.org/nic/update?system=dyndns&hostname=//x.x.x@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
  remove http://x.x.x@members.dyndns.org/nic/update?system=dyndns&hostname=//x.x.x@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
ip cef
no ipv6 cef
license udi pid CISCO887VA-SEC-K9 sn FCZ160891N2
username ccpuser privilege 15 secret 5 $1$o0Ai$wIXcbWD4CObRNZSt.aTQA0
username fabrice privilege 15 secret 5 $1$NpO1$YvgI6Tl9rtsOV1EmfRM.v/
controller VDSL 0
no ip ftp passive
interface Ethernet0
description $ETH-WAN$
no ip address
pppoe enable group global
pppoe-client dial-pool-number 1
interface ATM0
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5snap
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address 192.168.186.191 255.255.255.0
ip access-group 100 in
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1412
interface Dialer1
ip ddns update hostname x.x.x
ip ddns update ccp_ddns1
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username xxx password 0 xxx
ip forward-protocol nd
ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 3 interface Dialer1 overload
access-list xxxxx
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
access-class 101 in
privilege level 15
login local
transport input telnet ssh
end
Peter Paluch
Hello Fabrice,
After verifying your configuration, I am not sure how is your router connected to the DSL service. Is there a separate standalone DSL modem connected to your router, or are you using the built-in DSL interface in the router?
If your router is connected to the DSL service using its own DSL interface then you should remove all the PPPoE commands from the Ethernet0 interface as they are not supposed to be placed there. In addition, the PPPoE client has to be configured under the ATM interface under the appropriate VPI/VCI, so for example:
interface ATM0
no ip address
pvc 8/35
Notice that even the ATM0 interface is not going to have any IP address itself. The IP address will be assigned only to the Dialer1 interface after the PPPoE session goes up. Also make sure that for your DSL connection, the ATM VPI/VCI combination of 8/35 is the correct one. This has to be consulted with your DSL service provider.
Please keep us informed!
Best regards,
Peter
Thanks Peter,
Unfortunately I still have problems: the connections is UP but it seems that is not properly nated.
can help me?
Thank you very much
Fabrice
Test Activity Details
ActivityStatus
Checking interface status... Up
Interface physical status :Up
Line protocol status :Up
Checking for DNS settings... Successful
DNS lookup set :Yes
Statically configured DNS servers : 192.168.186.100
Dynamically imported DNS servers :None
Checking interface IP address.. Successful
Interface IP address :81.174.***
Interface IP address Type :Negotiated
Checking exit interface... Failed
Exit interface found :Vlan1
My ISP require:
PPPoA (PPP over ATM) o PPPoE (PPP over Ethernet)
- Encapsulation: LLC/SNAP o MUX
- VPI: 8
- VCI: 35
My configuration:
version 15.2
no service pad
hostname xbRouter
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
      quit
ip domain name xb81
HTTP
  add http://***@members.dyndns.org/nic/update?system=dyndns&hostname=//***@members.dyndns.org/nic/update?system=dyndns&hostname=&myip=
  remove http://***@members.dyndns.org/nic/update?system=dyndns&hostname=//***@members.dyndns.org/nic/update?system=dyndns&hostname=&myip=
ip cef
no ipv6 cef
controller VDSL 0
no ip ftp passive
interface Ethernet0
no ip address
interface ATM0
no ip address
pvc 8/35
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip nat inside
interface Dialer1
ip ddns update hostname ***
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp pap sent-username *** password 0 ***
ip http server
ip nat inside source list 5 interface Dialer1 overload
access-list 1 permit 192.168.186.192
access-list 1 permit 192.168.186.204
access-list 1 remark Auto generated by SDM Management Access feature
access-list 1 permit 192.168.186.99
access-list 1 remark CCP_ACL Category=1
access-list 1 permit 192.168.186.100
access-list 2 remark INSIDE_IF=Vlan1
access-list 2 remark CCP_ACL Category=2
access-list 2 permit 192.168.186.0 0.0.0.255
access-list 3 remark CCP_ACL Category=2
access-list 3 permit 192.168.186.0 0.0.0.255
access-list 4 remark CCP_ACL Category=2
access-list 4 permit 192.168.186.0 0.0.0.255
access-list 5 remark CCP_ACL Category=2
access-list 5 permit 192.168.186.0 0.0.0.255
access-list 100 remark Auto generated by SDM Management Access feature
access-list 100 remark CCP_ACL Category=1
access-list 100 permit tcp host 192.168.186.100 host 192.168.186.191 eq telnet
access-list 100 permit tcp host 192.168.186.204 host 192.168.186.191 eq telnet
access-list 100 permit tcp host 192.168.186.99 host 192.168.186.191 eq telnet
access-list 100 permit tcp host 192.168.186.100 host 192.168.186.191 eq 22
access-list 100 permit tcp host 192.168.186.204 host 192.168.186.191 eq 22
access-list 100 permit tcp host 192.168.186.99 host 192.168.186.191 eq 22
access-list 100 permit tcp host 192.168.186.192 host 192.168.186.191 eq 22
access-list 100 permit tcp host 192.168.186.100 host 192.168.186.191 eq www
access-list 100 permit tcp host 192.168.186.99 host 192.168.186.191 eq www
access-list 100 permit tcp host 192.168.186.100 host 192.168.186.191 eq 443
access-list 100 permit tcp host 192.168.186.204 host 192.168.186.191 eq 443
access-list 100 permit tcp host 192.168.186.99 host 192.168.186.191 eq 443
access-list 100 permit tcp host 192.168.186.192 host 192.168.186.191 eq 443
access-list 100 permit tcp host 192.168.186.100 host 192.168.186.191 eq cmd
access-list 100 permit tcp host 192.168.186.204 host 192.168.186.191 eq cmd
access-list 100 permit tcp host 192.168.186.99 host 192.168.186.191 eq cmd
access-list 100 permit tcp host 192.168.186.192 host 192.168.186.191 eq cmd
access-list 100 deny   tcp any host 192.168.186.191 eq telnet
access-list 100 deny   tcp any host 192.168.186.191 eq 22
access-list 100 deny   tcp any host 192.168.186.191 eq www
access-list 100 deny   tcp any host 192.168.186.191 eq 443
access-list 100 deny   tcp any host 192.168.186.191 eq cmd
access-list 100 deny   udp any host 192.168.186.191 eq snmp
access-list 100 permit ip any any
access-list 101 remark Auto generated by SDM Management Access feature
access-list 101 remark CCP_ACL Category=1
access-list 101 permit ip host 192.168.186.100 any
access-list 101 permit ip host 192.168.186.204 any
access-list 101 permit ip host 192.168.186.99 any
access-list 101 permit ip host 192.168.186.192 any
control-plane
line con 0
line aux 0
line vty 0 4
access-class 101 in
privilege level 15
login local
end
Good morning,
I managed to solve the connection problem.
I changed the following parameters:
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
no ip route-cache
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
interface Dialer1
ip ddns update hostname xb81.dyndns.org
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp pap sent-username 5267835949 password 0 423G2Xrd interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
