Problem with Cisco 870 and no-ip DDNS
I have setup my cisco 870 for ddns with no-ip.com but it does not work. When i press "show ip ddns update" I get "Update Destination not available" and even i have ddns debug on no messages are showing. The config is:
ip ddns update method noip
HTTP
  add http:/YYYYYYY:XXXXXXX@dynupdate.no-ip.com/nic/update?hostname=<h>&myip=<a>
interval maximum 0 5 0 0
interval minimum 0 0 2 0
interface Dialer1
mtu 1492
ip ddns update hostname KKKKK.zapto.org
ip ddns update noip
Is anyone out there who can help me?
Sandeep Choudhary
Looking at your config, If you don't have it now, you will need
ip domain lookup
Other than that it should work.
if still now works then plz try to debug and paste the output.
please rate if it helps.
Thanks for your answer...I have this command on my config. Nothing is happening, nor debug messages are showed up...
