pppoe max sessions
hemoon123
what is the command so i can view what my pppoe max sessions are?  For some reason we cannot get more than 55.
Thank You
Kevin
6 Replies 6
hemoon123
I dont believe i worded this correctly.  is there a show command that will let me view what my pppoe max sessions is set at?  These are my router specs.
IOS (tm) 7200 Software (C7200-IS-M), Version 12.2(21a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 09-Jan-04 16:35 by kellmill
Image text-base: 0x60008940, data-base: 0x61308000
ROM: System Bootstrap, Version 12.2(4r)B2, RELEASE SOFTWARE (fc2)
cisco 7206VXR (NPE400) processor (revision B) with 245760K/16384K bytes of memory.
Processor board ID 32347585
R7000 CPU at 350Mhz, Implementation 39, Rev 3.3, 256KB L2, 4096KB L3 Cache
6 slot VXR midplane, Version 2.8 cisco 7206VXR (NPE400) processor (revision B) with 245760K/16384K bytes of memory.
Kevin
Hello
This is one i will need to look up but try
sh pppoe summary
Sent from Cisco Technical Support Android App
Kind Regards
Paul
Thanks for the response, but that command doesnt work.  The response is below
Router#sh pppoe summary
% Invalid input detected at '^' marker.
Kevin
Hello
Try these
Sh pppoe session
Sh pppoe statics
Sh vpdn session
Kind Regards
Paul
show vpdn sessions, showed me a list of many people were on, but didnt tell me what my max sessions was set at
Found it.  Thanks for all the help.  Did the show configuration command, and found what my pppoe max sessions were.
