PPPOE mikrotik to cisco converter
Qudama Khalil
Hello, i have cisco 6500 i need make it pppoe,
i have full pppoe server in mikroik i will send you the mikrotik configuration and please change it to cisco and every line write a notice for converted line ( Code )
/interface vlan
add interface=ether11 name=vlan2-For-Huth vlan-id=2
add interface=ether11 name=vlan3-For-Huth vlan-id=3
/ip pool
add name=1-Light-Pool ranges=172.16.0.2-172.16.255.254
add name=3-Economy-Pool ranges=172.18.0.2-172.18.255.254
add name=4-Standard-Pool ranges=172.19.0.2-172.19.255.254
add name=5-Active-Pool ranges=172.20.0.2-172.20.255.254
add name=6-Turbo-Pool ranges=172.21.0.2-172.21.255.254
add name=7-Business-Pool ranges=172.22.0.2-172.22.255.254
add name="10-Local Address" ranges=172.25.0.2-172.25.255.254
add name=2-Smart-Pool ranges=172.17.0.2-172.17.255.254
add name=9-Expired ranges=172.24.0.2-172.24.255.254
add name="11-Remote Address" ranges=172.26.0.2-172.26.255.254
add name=8-Family-Pool ranges=172.23.0.2-172.23.255.254
/ppp profile
set *0 dns-server=185.128.36.36,8.8.8.8 local-address="10-Local Address" \
only-one=yes use-compression=no use-encryption=no use-ipv6=no use-mpls=no
add local-address=172.16.0.1 name=1-Light remote-address=1-Light-Pool \
add local-address=172.22.0.1 name=7-Unlimited remote-address=1-Light-Pool \
set *FFFFFFFE use-compression=no use-encryption=no use-ipv6=no use-mpls=no
/queue type
set 0 kind=bfifo
set 1 kind=sfq
add kind=pcq name="1 - Light" pcq-classifier=dst-address \
pcq-dst-address6-mask=64 pcq-rate=1024k pcq-src-address6-mask=64 \
pcq-total-limit=50000KiB
add kind=pcq name="2 - Smart" pcq-classifier=dst-address \
pcq-dst-address6-mask=64 pcq-rate=2048k pcq-src-address6-mask=64 \
add kind=pcq name="3 - Economy" pcq-classifier=dst-address \
pcq-dst-address6-mask=64 pcq-rate=3072k pcq-src-address6-mask=64 \
add kind=pcq name="4 - Standard" pcq-classifier=dst-address \
pcq-dst-address6-mask=64 pcq-rate=4096k pcq-src-address6-mask=64 \
add kind=pcq name="5 - Active" pcq-classifier=dst-address \
pcq-dst-address6-mask=64 pcq-src-address6-mask=64 pcq-total-limit=\
50000KiB
add kind=pcq name="6 - Turbo" pcq-classifier=dst-address \
50000KiB
add kind=pcq name="13 - GGC" pcq-classifier=dst-address \
pcq-dst-address6-mask=64 pcq-rate=16384k pcq-src-address6-mask=64 \
add kind=pcq name="22 - Cache" pcq-classifier=dst-address \
add kind=pcq name="14 - Local-Services" pcq-classifier=dst-address \
add kind=pcq name="10 - CDN" pcq-classifier=dst-address \
50000KiB
add kind=pcq name="21 - PS4" pcq-classifier=dst-address \
pcq-dst-address6-mask=64 pcq-rate=5120k pcq-src-address6-mask=64 \
add kind=pcq name="15 - Netflix-Light" pcq-classifier=dst-address \
add kind=pcq name="16 - Netflix-Economy" pcq-classifier=dst-address \
add kind=pcq name="17 - Netflix-Standard" pcq-classifier=dst-address \
pcq-dst-address6-mask=64 pcq-rate=8192k pcq-src-address6-mask=64 \
add kind=pcq name="18 - Netflix-Active" pcq-classifier=dst-address \
pcq-dst-address6-mask=64 pcq-rate=10240k pcq-src-address6-mask=64 \
add kind=pcq name="19 - Netflix-Turbo" pcq-classifier=dst-address \
pcq-dst-address6-mask=64 pcq-rate=12288k pcq-src-address6-mask=64 \
add kind=pcq name="20 - Netflix-Business" pcq-classifier=dst-address \
add kind=pcq name="12 - Facebook" pcq-classifier=src-address \
add kind=pcq name="11 - FNA" pcq-classifier=dst-address \
add kind=pcq name="9 - UP-all" pcq-classifier=dst-address \
add kind=pcq name="7 - Business" pcq-classifier=dst-address \
50000KiB
add kind=pcq name="8 - Family" pcq-classifier=dst-address \
/queue simple
add name=1-ICMP packet-marks=ICMP queue=default/default target=""
add name=2-DNS packet-marks=DNS queue=default/default target=""
add dst=185.128.38.130/32 name=3-Reseller queue=default/default target=""
add name="4-Local Services" packet-marks=local-services queue=\
"default/14 - Local-Services" target=""
add name=5-Cache packet-marks=Cache queue="default/22 - Cache" target=""
add name=6-CDN packet-marks=CDN queue="default/10 - CDN" target=""
add name=7-GGC packet-marks=GGC queue="default/13 - GGC" target=""
add name=8-FNA packet-marks=FNA queue="default/11 - FNA" target=""
add name=9-Facebook packet-marks=Facebook queue="default/12 - Facebook" \
target=""
add name=10-Google packet-marks=Google queue="9 - UP-all/default" target=""
add name=11-PS4 packet-marks=PS4 queue="default/21 - PS4" target=""
add name=12-Light queue="9 - UP-all/1 - Light" target=172.16.0.0/16
add name=13-Smart queue="9 - UP-all/2 - Smart" target=172.17.0.0/16
add name=14-Economy queue="9 - UP-all/3 - Economy" target=172.18.0.0/16
add name=15-Standard queue="9 - UP-all/4 - Standard" target=172.19.0.0/16
add name=16-Acrive queue="9 - UP-all/5 - Active" target=172.20.0.0/16
add name=17-Turbo queue="9 - UP-all/6 - Turbo" target=172.21.0.0/16
add name=18-Business queue="9 - UP-all/7 - Business" target=172.22.0.0/16
add name=19-Family queue="9 - UP-all/8 - Family" target=172.23.0.0/16
/interface l2tp-server server
set allow-fast-path=yes authentication=pap,chap default-profile=7-Unlimited \
enabled=yes ipsec-secret=1 mrru=1500 use-ipsec=yes
/interface pppoe-server server
add authentication=pap,chap disabled=no interface=vlan2-For-Huth max-mru=1480 \
max-mtu=1480 service-name=For-Huth2
add authentication=pap,chap disabled=no interface=vlan3-For-Huth max-mru=1480 \
/interface pptp-server server
set authentication=pap,chap,mschap1,mschap2 enabled=yes
/ip address
add address=10.104.238.1/24 comment="Ahmed New Baghdad" interface=\
vlan2 network=10.104.238.0
add address=10.54.25.1/24 comment="Yousif - ZTM" interface=vlan3
network=10.54.25.0
/ip dns
set servers=185.128.36.36,8.8.8.8
/ip firewall address-list
add address=62.201.216.128/25 list=GGC
add address=62.201.204.0/27 list=GGC
add address=109.224.0.0/16 list=EarthLink
add address=192.168.222.0/24 list=EarthLink
add address=192.168.248.0/24 list=EarthLink
add address=62.201.250.0/23 list=CDN
add address=192.168.252.2 list=Local-Services
add address=192.168.252.3 list=Local-Services
add address=192.168.252.4 list=Local-Services
add address=185.128.36.35 list=DNS
add address=185.128.36.36 list=DNS
add address=62.201.201.201 list=DNS
add address=62.201.201.202 list=DNS
add address=8.8.8.8 list=DNS
add address=8.8.4.4 list=DNS
add address=4.2.2.2 list=DNS
add address=185.128.39.0/27 list=GGC
add address=2.16.0.0/13 list=PS4
add address=23.0.0.0/8 list=PS4
add address=92.122.0.0/15 list=PS4
add address=95.100.0.0/15 list=PS4
add address=96.6.0.0/15 list=PS4
add address=104.0.0.0/8 list=PS4
add address=172.224.0.0/12 list=PS4
add address=173.230.192.0/19 list=PS4
add address=184.24.0.0/13 list=PS4
add address=193.108.88.0/21 list=PS4
add address=62.201.204.192/26 comment="IQ - Networks" list=FNA
add address=192.168.252.5 list=Local-Services
add address=10.0.0.0/8 list=Local-Services
add address=185.128.37.202 list=Local-Services
add address=185.128.36.8 list=Local-Services
add address=192.168.0.1 list=Local-Services
add address=172.16.0.0/12 list=Local-IPs
add address=10.0.0.0/8 list=Local-IPs
add address=192.168.0.0/16 list=Local-IPs
add address=185.128.36.25 list=Local-IPs
add address=85.194.199.192/26 comment=FNA-SCOP list=FNA
add address=192.168.0.0/16 list=No-Route
add address=10.0.0.0/8 list=No-Route
add address=172.16.0.0/12 list=No-Route
add address=185.128.37.0/24 list=No-Route
add address=185.128.36.0/24 list=No-Route
add address=185.128.39.0/24 list=No-Route
add address=62.201.216.128/25 list=No-Route
add address=62.201.204.0/27 list=No-Route
add address=216.58.0.0/16 list=no-route
add address=74.125.0.0/16 list=no-route
add address=173.194.0.0/16 list=no-route
add address=62.201.204.192/26 list=no-route
add address=185.128.37.200/29 list=no-route
add address=185.128.37.64/29 list=no-route
add address=62.201.204.0/27 list=no-route
add address=62.201.216.128/25 list=no-route
add address=185.128.39.0/27 list=no-route
add address=192.168.0.0/16 list=no-route
add address=172.16.0.0/12 list=no-route
add address=10.0.0.0/8 list=no-route
add address=31.13.0.0/16 list=no-route
add address=157.240.0.0/17 list=no-route
add address=185.60.216.0/22 list=no-route
add address=85.194.199.0/24 list=no-route
add address=62.201.216.128/25 disabled=yes list=No-Route
add address=62.201.204.0/27 disabled=yes list=No-Route
add address=185.128.39.0/27 disabled=yes list=No-Route
add address=85.194.199.192/26 disabled=yes list=No-Route
add address=62.201.204.192/26 disabled=yes list=No-Route
add address=31.13.0.0/16 disabled=yes list=No-Route
add address=157.240.0.0/17 disabled=yes list=No-Route
add address=185.60.216.0/22 disabled=yes list=No-Route
add address=2.16.0.0/13 disabled=yes list=No-Route
add address=23.0.0.0/8 disabled=yes list=No-Route
add address=92.122.0.0/15 disabled=yes list=No-Route
add address=95.100.0.0/15 disabled=yes list=No-Route
add address=96.6.0.0/15 disabled=yes list=No-Route
add address=104.0.0.0/8 disabled=yes list=No-Route
add address=172.224.0.0/12 disabled=yes list=No-Route
add address=173.230.192.0/19 disabled=yes list=No-Route
add address=184.24.0.0/13 disabled=yes list=No-Route
add address=193.108.88.0/21 disabled=yes list=No-Route
add address=109.205.112.9 disabled=yes list=No-Route
add address=109.205.112.10 disabled=yes list=No-Route
add address=31.13.24.0/21 disabled=yes list=No-Route
add address=31.13.64.0/18 disabled=yes list=No-Route
add address=45.64.40.0/22 disabled=yes list=No-Route
add address=66.220.144.0/20 disabled=yes list=No-Route
add address=69.63.176.0/20 disabled=yes list=No-Route
add address=69.171.224.0/19 disabled=yes list=No-Route
add address=74.119.76.0/22 disabled=yes list=No-Route
add address=103.4.96.0/22 disabled=yes list=No-Route
add address=173.252.64.0/19 disabled=yes list=No-Route
add address=173.252.96.0/19 disabled=yes list=No-Route
add address=179.60.192.0/22 disabled=yes list=No-Route
add address=204.15.20.0/22 disabled=yes list=No-Route
add address=199.201.64.0/22 disabled=yes list=No-Route
add address=69.63.184.0/21 disabled=yes list=No-Route
add address=66.220.152.0/21 disabled=yes list=No-Route
add address=146.88.59.0/24 disabled=yes list=No-Route
add address=185.128.36.35 disabled=yes list=No-Route
add address=185.128.36.36 disabled=yes list=No-Route
add address=62.201.201.201 disabled=yes list=No-Route
add address=62.201.201.202 disabled=yes list=No-Route
add address=8.8.8.8 disabled=yes list=No-Route
add address=8.8.4.4 disabled=yes list=No-Route
add address=4.2.2.2 disabled=yes list=No-Route
add address=216.58.192.0/19 disabled=yes list=No-Route
add address=173.194.0.0/16 disabled=yes list=No-Route
add address=74.125.0.0/16 disabled=yes list=No-Route
add address=8.34.208.0/20 disabled=yes list=No-Route
add address=8.35.192.0/20 disabled=yes list=No-Route
add address=23.228.128.0/18 disabled=yes list=No-Route
add address=23.236.48.0/20 disabled=yes list=No-Route
add address=23.251.128.0/19 disabled=yes list=No-Route
add address=23.255.128.0/17 disabled=yes list=No-Route
add address=35.184.0.0/13 disabled=yes list=No-Route
add address=41.244.244.0/24 disabled=yes list=No-Route
add address=45.56.0.0/18 disabled=yes list=No-Route
add address=64.9.224.0/23 disabled=yes list=No-Route
add address=64.9.228.0/23 disabled=yes list=No-Route
add address=64.9.236.0/22 disabled=yes list=No-Route
add address=64.9.240.0/20 disabled=yes list=No-Route
add address=64.233.160.0/19 disabled=yes list=No-Route
add address=66.102.0.0/20 disabled=yes list=No-Route
add address=66.249.64.0/19 disabled=yes list=No-Route
add address=70.32.128.0/19 disabled=yes list=No-Route
add address=72.14.192.0/18 disabled=yes list=No-Route
add address=84.235.77.0/24 disabled=yes list=No-Route
add address=85.187.222.0/24 disabled=yes list=No-Route
add address=89.207.224.0/24 disabled=yes list=No-Route
add address=99.198.128.0/17 disabled=yes list=No-Route
add address=103.25.178.0/24 disabled=yes list=No-Route
add address=104.132.0.0/14 disabled=yes list=No-Route
add address=104.154.0.0/15 disabled=yes list=No-Route
add address=104.196.0.0/14 disabled=yes list=No-Route
add address=107.167.160.0/19 disabled=yes list=No-Route
add address=107.178.192.0/18 disabled=yes list=No-Route
add address=107.188.128.0/17 disabled=yes list=No-Route
add address=108.59.80.0/20 disabled=yes list=No-Route
add address=108.170.192.0/18 disabled=yes list=No-Route
add address=108.177.0.0/17 disabled=yes list=No-Route
add address=111.92.162.0/24 disabled=yes list=No-Route
add address=130.211.0.0/16 disabled=yes list=No-Route
add address=136.22.0.0/23 disabled=yes list=No-Route
add address=136.32.0.0/11 disabled=yes list=No-Route
add address=142.250.0.0/15 disabled=yes list=No-Route
add address=146.88.60.0/24 disabled=yes list=No-Route
add address=146.148.0.0/17 disabled=yes list=No-Route
add address=162.216.148.0/22 disabled=yes list=No-Route
add address=162.222.176.0/21 disabled=yes list=No-Route
add address=164.40.244.0/24 disabled=yes list=No-Route
add address=172.102.8.0/21 disabled=yes list=No-Route
add address=172.217.0.0/16 disabled=yes list=No-Route
add address=172.253.0.0/16 disabled=yes list=No-Route
add address=173.255.112.0/20 disabled=yes list=No-Route
add address=185.25.28.0/23 disabled=yes list=No-Route
add address=185.150.148.0/22 disabled=yes list=No-Route
add address=192.104.160.0/23 disabled=yes list=No-Route
add address=192.119.16.0/20 disabled=yes list=No-Route
add address=192.119.28.0/24 disabled=yes list=No-Route
add address=192.158.28.0/22 disabled=yes list=No-Route
add address=192.178.0.0/15 disabled=yes list=No-Route
add address=192.200.224.0/19 disabled=yes list=No-Route
add address=193.200.222.0/24 disabled=yes list=No-Route
add address=197.199.253.0/24 disabled=yes list=No-Route
add address=197.199.254.0/24 disabled=yes list=No-Route
add address=199.192.112.0/22 disabled=yes list=No-Route
add address=199.223.232.0/21 disabled=yes list=No-Route
add address=207.223.160.0/20 disabled=yes list=No-Route
add address=208.68.108.0/22 disabled=yes list=No-Route
add address=209.85.128.0/17 disabled=yes list=No-Route
add address=209.107.176.0/20 disabled=yes list=No-Route
add address=216.21.160.0/20 disabled=yes list=No-Route
add address=223.27.237.0/24 disabled=yes list=No-Route
add address=216.58.0.0/16 disabled=yes list=No-Route
add address=216.239.32.0/19 disabled=yes list=No-Route
add address=216.252.220.0/22 disabled=yes list=No-Route
add address=5.149.103.0/26 disabled=yes list=No-Route
add address=185.52.116.192/26 disabled=yes list=No-Route
add address=185.194.8.224/27 disabled=yes list=No-Route
add address=185.104.158.0/27 disabled=yes list=No-Route
add address=62.201.250.0/23 disabled=yes list=No-Route
add address=172.16.0.0/12 list=No-Cache
add address=192.168.0.0/16 list=No-Cache
add address=10.0.0.0/8 list=No-Cache
add address=62.201.0.0/16 list=No-Cache
add address=185.128.37.202 list=No-Cache
add address=185.128.36.8 list=No-Cache
add address=185.128.36.25 list=No-Cache
add address=212.126.120.192/26 comment=SARD list=FNA
add address=8.0.0.0/9 list=Google
add address=74.125.0.0/16 list=Google
add address=74.114.24.0/21 list=Google
add address=72.14.192.0/18 list=Google
add address=70.32.128.0/19 list=Google
add address=66.249.64.0/19 list=Google
add address=66.102.0.0/20 list=Google
add address=64.9.252.0/22 list=Google
add address=64.9.248.0/22 list=Google
add address=64.9.243.0/24 list=Google
add address=64.9.242.0/24 list=Google
add address=64.9.241.0/24 list=Google
add address=64.9.240.0/24 list=Google
add address=64.9.236.0/22 list=Google
add address=64.9.232.0/22 list=Google
add address=64.9.228.0/23 list=Google
add address=64.9.227.0/24 list=Google
add address=64.9.224.0/23 list=Google
add address=64.233.160.0/19 list=Google
add address=35.244.0.0/14 list=Google
add address=35.240.0.0/14 list=Google
add address=35.236.0.0/14 list=Google
add address=35.232.0.0/14 list=Google
add address=35.228.0.0/14 list=Google
add address=35.224.0.0/14 list=Google
add address=35.220.0.0/14 list=Google
add address=35.216.0.0/14 list=Google
add address=35.212.0.0/14 list=Google
add address=35.208.0.0/14 list=Google
add address=35.206.0.0/15 list=Google
add address=35.204.0.0/15 list=Google
add address=35.200.0.0/14 list=Google
add address=35.192.0.0/13 list=Google
add address=35.190.0.0/16 list=Google
add address=35.184.0.0/13 list=Google
add address=35.186.0.0/16 list=Google
add address=23.251.128.0/19 list=Google
add address=23.236.48.0/20 list=Google
add address=216.58.192.0/19 list=Google
add address=216.252.220.0/22 list=Google
add address=216.239.32.0/19 list=Google
add address=209.85.128.0/17 list=Google
add address=209.107.184.0/23 list=Google
add address=209.107.176.0/20 list=Google
add address=208.81.188.0/22 list=Google
add address=207.223.160.0/20 list=Google
add address=199.223.232.0/21 list=Google
add address=199.192.112.0/22 list=Google
add address=192.178.0.0/15 list=Google
add address=192.158.28.0/22 list=Google
add address=192.104.160.0/23 list=Google
add address=173.255.112.0/20 list=Google
add address=173.194.0.0/16 list=Google
add address=172.253.0.0/16 list=Google
add address=172.217.0.0/16 list=Google
add address=172.102.8.0/21 list=Google
add address=162.222.176.0/21 list=Google
add address=162.216.148.0/22 list=Google
add address=146.148.0.0/17 list=Google
add address=142.250.0.0/15 list=Google
add address=136.22.88.0/22 list=Google
add address=136.22.86.0/23 list=Google
add address=136.22.84.0/24 list=Google
add address=136.22.80.0/22 list=Google
add address=136.22.76.0/22 list=Google
add address=136.22.72.0/22 list=Google
add address=136.22.71.0/24 list=Google
add address=136.22.70.0/24 list=Google
add address=136.22.69.0/24 list=Google
add address=136.22.68.0/24 list=Google
add address=136.22.66.0/24 list=Google
add address=136.22.64.0/23 list=Google
add address=136.22.124.0/22 list=Google
add address=136.22.116.0/22 list=Google
add address=136.22.0.0/23 list=Google
add address=130.211.0.0/16 list=Google
add address=108.59.80.0/20 list=Google
add address=108.177.0.0/17 list=Google
add address=108.170.192.0/18 list=Google
add address=107.178.192.0/18 list=Google
add address=107.167.160.0/19 list=Google
add address=104.196.0.0/14 list=Google
add address=104.154.0.0/15 list=Google
add address=104.132.0.0/14 list=Google
add address=74.119.76.0/22 list=Facebook
add address=69.63.176.0/20 list=Facebook
add address=69.171.240.0/20 list=Facebook
add address=69.171.224.0/19 list=Facebook
add address=66.220.144.0/20 list=Facebook
add address=45.64.40.0/22 list=Facebook
add address=31.13.64.0/18 list=Facebook
add address=31.13.24.0/21 list=Facebook
add address=204.15.20.0/22 list=Facebook
add address=199.201.64.0/22 list=Facebook
add address=185.60.216.0/22 list=Facebook
add address=173.252.96.0/19 list=Facebook
add address=173.252.64.0/19 list=Facebook
add address=157.240.0.0/17 list=Facebook
add address=157.240.192.0/24 list=Facebook
add address=157.240.191.0/24 list=Facebook
add address=157.240.190.0/24 list=Facebook
add address=157.240.189.0/24 list=Facebook
add address=157.240.188.0/24 list=Facebook
add address=157.240.187.0/24 list=Facebook
add address=157.240.186.0/24 list=Facebook
add address=157.240.185.0/24 list=Facebook
add address=157.240.184.0/24 list=Facebook
add address=157.240.183.0/24 list=Facebook
add address=157.240.182.0/24 list=Facebook
add address=157.240.178.0/24 list=Facebook
add address=157.240.177.0/24 list=Facebook
add address=157.240.173.0/24 list=Facebook
add address=157.240.172.0/24 list=Facebook
add address=157.240.171.0/24 list=Facebook
add address=157.240.170.0/24 list=Facebook
add address=157.240.168.0/24 list=Facebook
add address=157.240.167.0/24 list=Facebook
add address=157.240.166.0/24 list=Facebook
add address=157.240.165.0/24 list=Facebook
add address=157.240.164.0/24 list=Facebook
add address=157.240.163.0/24 list=Facebook
add address=157.240.162.0/24 list=Facebook
add address=157.240.161.0/24 list=Facebook
add address=157.240.148.0/24 list=Facebook
add address=157.240.146.0/24 list=Facebook
add address=157.240.145.0/24 list=Facebook
add address=157.240.144.0/24 list=Facebook
add address=157.240.143.0/24 list=Facebook
add address=157.240.142.0/24 list=Facebook
add address=157.240.140.0/24 list=Facebook
add address=157.240.139.0/24 list=Facebook
add address=157.240.138.0/24 list=Facebook
add address=157.240.137.0/24 list=Facebook
add address=157.240.136.0/24 list=Facebook
add address=157.240.135.0/24 list=Facebook
add address=157.240.134.0/24 list=Facebook
add address=157.240.133.0/24 list=Facebook
add address=157.240.132.0/24 list=Facebook
add address=157.240.131.0/24 list=Facebook
add address=157.240.130.0/24 list=Facebook
add address=157.240.129.0/24 list=Facebook
add address=146.88.59.0/24 list=Facebook
add address=129.134.0.0/17 list=Facebook
add address=23.246.0.0/18 list=Netflix
add address=37.77.184.0/21 list=Netflix
add address=45.57.0.0/17 list=Netflix
add address=64.120.128.0/17 list=Netflix
add address=66.197.128.0/17 list=Netflix
add address=69.53.224.0/19 list=Netflix
add address=108.175.32.0/20 list=Netflix
add address=185.2.220.0/22 list=Netflix
add address=185.9.188.0/22 list=Netflix
add address=192.173.64.0/18 list=Netflix
add address=198.38.96.0/19 list=Netflix
add address=198.45.48.0/20 list=Netflix
add address=185.112.234.192/26 comment="FNA Orient" list=FNA
add address=185.112.234.64/26 comment="FNA Orient" list=FNA
add address=172.16.0.0/16 list=Light
add address=172.17.0.0/16 list=Economy
add address=172.18.0.0/16 list=Standard
add address=172.19.0.0/16 list=Active
add address=172.20.0.0/16 list=Turbo
add address=172.21.0.0/16 list=Business
add address=172.22.0.0/16 list=Unlimited
add address=192.168.0.0/16 list=except
add address=172.16.0.0/12 list=except
add address=10.0.0.0/8 list=except
add address=185.128.36.0/22 list=except
add address=62.201.192.0/24 list=except
add address=62.201.193.0/24 list=except
add address=62.201.194.0/24 list=except
add address=62.201.195.0/24 list=except
add address=62.201.200.0/24 list=except
add address=62.201.201.0/24 list=except
add address=62.201.202.0/24 list=except
add address=62.201.203.0/24 list=except
add address=62.201.204.0/24 list=except
add address=62.201.205.0/24 list=except
add address=62.201.206.0/24 list=except
add address=62.201.207.0/24 list=except
add address=62.201.208.0/24 list=except
add address=62.201.209.0/24 list=except
add address=62.201.210.0/24 list=except
add address=62.201.211.0/24 list=except
add address=62.201.212.0/22 list=except
add address=62.201.215.0/24 list=except
add address=62.201.216.0/24 list=except
add address=62.201.217.0/24 list=except
add address=62.201.218.0/24 list=except
add address=62.201.219.0/24 list=except
add address=62.201.220.0/22 list=except
add address=62.201.220.0/24 list=except
add address=62.201.222.0/24 list=except
add address=62.201.224.0/22 list=except
add address=62.201.226.0/24 list=except
add address=62.201.228.0/22 list=except
add address=62.201.229.0/24 list=except
add address=62.201.230.0/24 list=except
add address=62.201.232.0/22 list=except
add address=62.201.237.0/24 list=except
add address=62.201.238.0/24 list=except
add address=62.201.239.0/24 list=except
add address=62.201.240.0/21 list=except
add address=62.201.249.0/24 list=except
add address=62.201.250.0/24 list=except
add address=62.201.251.0/24 list=except
add address=62.201.252.0/22 list=except
add address=89.33.66.0/23 list=except
add address=185.112.189.202 list=No-Cache
add address=45.40.192.0/29 comment=PUBG list=PS4
add address=45.113.68.0/22 comment=PUBG list=PS4
add address=49.51.0.0/16 comment=PUBG list=PS4
add address=87.245.192.0/18 comment=PUBG list=PS4
add address=103.7.28.0/22 comment=PUBG list=PS4
add address=103.52.216.0/22 comment=PUBG list=PS4
add address=103.238.16.0/23 comment=PUBG list=PS4
add address=119.28.0.0/16 comment=PUBG list=PS4
add address=119.29.29.0/24 comment=PUBG list=PS4
add address=124.156.0.0/19 comment=PUBG list=PS4
add address=129.226.0.0/16 comment=PUBG list=PS4
add address=150.109.0.0/16 comment=PUBG list=PS4
add address=162.62.0.0/16 comment=PUBG list=PS4
add address=170.106.0.0/16 comment=PUBG list=PS4
add address=182.254.116.0/22 comment=PUBG list=PS4
add address=203.205.0.0/16 comment=PUBG list=PS4
add address=212.126.122.146 comment=SAS list=except
add address=87.245.224.0/19 list=Netflix
add address=185.88.181.2 comment=Xvideos.com list=FamilyShield
add address=185.88.181.6 comment=Xvideos.com list=FamilyShield
add address=185.88.181.7 comment=Xvideos.com list=FamilyShield
add address=185.88.181.8 comment=Xvideos.com list=FamilyShield
add address=185.88.181.3 comment=Xvideos.com list=FamilyShield
add address=185.88.181.4 comment=Xvideos.com list=FamilyShield
add address=185.88.181.10 comment=Xvideos.com list=FamilyShield
add address=185.88.181.5 comment=Xvideos.com list=FamilyShield
add address=185.88.181.11 comment=Xvideos.com list=FamilyShield
add address=185.88.181.9 comment=Xvideos.com list=FamilyShield
add address=216.18.168.16 comment=PornHub.com list=FamilyShield
add address=88.208.29.24 comment=xhamster.com list=FamilyShield
add address=185.88.181.57 comment=xnxx.com list=FamilyShield
add address=185.88.181.59 comment=xnxx.com list=FamilyShield
add address=185.88.181.60 comment=xnxx.com list=FamilyShield
add address=185.88.181.54 comment=xnxx.com list=FamilyShield
add address=185.88.181.58 comment=xnxx.com list=FamilyShield
add address=185.88.181.56 comment=xnxx.com list=FamilyShield
add address=185.88.181.55 comment=xnxx.com list=FamilyShield
add address=216.18.168.116 comment=youporn.com list=FamilyShield
add address=216.18.168.162 comment=youjizz.com list=FamilyShield
add address=104.23.104.173 comment=hclips.com list=FamilyShield
add address=94.199.252.153 comment=porn.com list=FamilyShield
add address=77.249.179.76 comment=tnaflix.com list=FamilyShield
add address=216.18.168.66 comment=tube8.com list=FamilyShield
add address=104.20.41.98 comment=spankbang.com list=FamilyShield
add address=78.140.183.138 comment=drtuber.com list=FamilyShield
add address=204.155.151.79 comment=vporn.com list=FamilyShield
add address=66.254.124.162 comment=spankwire.com list=FamilyShield
add address=31.192.166.179 comment=keezmovies.com list=FamilyShield
add address=88.208.39.131 comment=nuvid.com list=FamilyShield
add address=46.229.171.171 comment=sunporno.com list=FamilyShield
add address=212.32.248.100 comment=pornhd.com list=FamilyShield
add address=172.64.173.4 comment=porn300.com list=FamilyShield
add address=172.64.172.4 comment=porn300.com list=FamilyShield
add address=162.251.108.60 comment=sexvid.xxx list=FamilyShield
add address=88.208.3.148 comment=zbporn.com list=FamilyShield
add address=77.247.181.42 comment=xxxbunker.com list=FamilyShield
add address=94.199.254.244 comment=mofosex.com list=FamilyShield
add address=188.164.249.36 comment=xbabe.com list=FamilyShield
add address=163.172.8.241 comment=porndroids.com list=FamilyShield
add address=163.172.77.78 comment=porndroids.com list=FamilyShield
add address=62.210.101.34 comment=porndroids.com list=FamilyShield
add address=195.154.154.120 comment=porndroids.com list=FamilyShield
add address=208.94.232.218 comment=updatetube.com list=FamilyShield
add address=208.88.225.92 comment=be**bleep**.com list=FamilyShield
add address=104.28.7.58 list=FamilyShield
add address=162.251.110.33 comment=hdmovz.com list=FamilyShield
add address=80.249.162.1 comment=pornrox.com list=FamilyShield
add address=66.254.109.96 comment=pornmaki.com list=FamilyShield
add address=162.251.110.28 comment=pornid.xxx list=FamilyShield
add address=51.158.20.159 comment=inxporn.com list=FamilyShield
add address=104.31.94.209 comment=slutload.com list=FamilyShield
add address=104.31.95.209 comment=slutload.com list=FamilyShield
add address=78.140.142.220 comment=proporn.com list=FamilyShield
add address=162.251.110.111 comment=fakeporn.tv list=FamilyShield
add address=209.239.162.220 comment=pornhost.com list=FamilyShield
add address=216.177.153.88 comment=handjobhub.com list=FamilyShield
add address=185.73.221.197 comment=tubev.sex list=FamilyShield
add address=31.192.122.246 comment=dansmovies.com list=FamilyShield
add address=209.239.172.196 comment=fapdu.com list=FamilyShield
add address=185.73.221.172 comment=porn7.xxx list=FamilyShield
add address=198.7.62.1 comment=rude.com list=FamilyShield
add address=188.72.203.144 comment=24porn.com list=FamilyShield
add address=206.54.164.24 comment=freudbox.com list=FamilyShield
add address=176.31.126.156 comment=pornheed.com list=FamilyShield
add address=162.245.237.74 comment=hdporn.net list=FamilyShield
add address=216.105.87.130 comment=orgasm.com list=FamilyShield
add address=209.239.162.222 comment=pornrabbit.com list=FamilyShield
add address=208.78.95.230 comment=madthumbs.com list=FamilyShield
add address=104.28.6.58 comment=masseurporn.com list=FamilyShield
add address=3.80.0.0/12 comment=PUBG-QQQ list=PS4
add address=18.204.0.0/14 comment=PUBG-QQQ list=PS4
add address=18.208.0.0/13 comment=PUBG-QQQ list=PS4
add address=18.232.0.0/14 comment=PUBG-QQQ list=PS4
add address=23.20.0.0/15 comment=PUBG-QQQ list=PS4
add address=23.22.0.0/15 comment=PUBG-QQQ list=PS4
add address=34.192.0.0/12 comment=PUBG-QQQ list=PS4
add address=34.224.0.0/12 comment=PUBG-QQQ list=PS4
add address=35.153.0.0/16 comment=PUBG-QQQ list=PS4
add address=35.168.0.0/13 comment=PUBG-QQQ list=PS4
add address=50.16.0.0/16 comment=PUBG-QQQ list=PS4
add address=50.17.0.0/16 comment=PUBG-QQQ list=PS4
add address=50.19.0.0/17 comment=PUBG-QQQ list=PS4
add address=50.19.128.0/17 comment=PUBG-QQQ list=PS4
add address=52.0.0.0/15 comment=PUBG-QQQ list=PS4
add address=52.2.0.0/15 comment=PUBG-QQQ list=PS4
add address=52.4.0.0/14 comment=PUBG-QQQ list=PS4
add address=52.20.0.0/14 comment=PUBG-QQQ list=PS4
add address=52.44.0.0/15 comment=PUBG-QQQ list=PS4
add address=52.54.0.0/15 comment=PUBG-QQQ list=PS4
add address=52.70.0.0/15 comment=PUBG-QQQ list=PS4
add address=52.72.0.0/15 comment=PUBG-QQQ list=PS4
add address=52.86.0.0/15 comment=PUBG-QQQ list=PS4
add address=52.90.0.0/15 comment=PUBG-QQQ list=PS4
add address=52.95.245.0/24 comment=PUBG-QQQ list=PS4
add address=216.182.238.0/23 comment=PUBG-QQQ list=PS4
add address=54.80.0.0/14 comment=PUBG-QQQ list=PS4
add address=54.84.0.0/15 comment=PUBG-QQQ list=PS4
add address=54.86.0.0/16 comment=PUBG-QQQ list=PS4
add address=54.87.0.0/16 comment=PUBG-QQQ list=PS4
add address=54.88.0.0/16 comment=PUBG-QQQ list=PS4
add address=54.89.0.0/16 comment=PUBG-QQQ list=PS4
add address=54.90.0.0/15 comment=PUBG-QQQ list=PS4
add address=54.92.128.0/17 comment=PUBG-QQQ list=PS4
add address=54.144.0.0/14 comment=PUBG-QQQ list=PS4
add address=54.152.0.0/16 comment=PUBG-QQQ list=PS4
add address=54.156.0.0/14 comment=PUBG-QQQ list=PS4
add address=54.160.0.0/14 comment=PUBG-QQQ list=PS4
add address=54.164.0.0/15 comment=PUBG-QQQ list=PS4
add address=54.166.0.0/15 comment=PUBG-QQQ list=PS4
add address=54.172.0.0/15 comment=PUBG-QQQ list=PS4
add address=54.174.0.0/15 comment=PUBG-QQQ list=PS4
add address=54.196.0.0/15 comment=PUBG-QQQ list=PS4
add address=54.198.0.0/16 comment=PUBG-QQQ list=PS4
add address=54.204.0.0/15 comment=PUBG-QQQ list=PS4
add address=54.208.0.0/15 comment=PUBG-QQQ list=PS4
add address=54.210.0.0/16 comment=PUBG-QQQ list=PS4
add address=54.211.0.0/16 comment=PUBG-QQQ list=PS4
add address=54.221.0.0/16 comment=PUBG-QQQ list=PS4
add address=54.224.0.0/15 comment=PUBG-QQQ list=PS4
add address=54.226.0.0/15 comment=PUBG-QQQ list=PS4
add address=54.234.0.0/15 comment=PUBG-QQQ list=PS4
add address=54.236.0.0/18 comment=PUBG-QQQ list=PS4
add address=54.236.64.0/18 comment=PUBG-QQQ list=PS4
add address=54.236.128.0/17 comment=PUBG-QQQ list=PS4
add address=54.237.0.0/16 comment=PUBG-QQQ list=PS4
add address=54.240.8.0/21 comment=PUBG-QQQ list=PS4
add address=54.240.30.0/23 comment=PUBG-QQQ list=PS4
add address=54.240.32.0/20 comment=PUBG-QQQ list=PS4
add address=54.240.48.0/23 comment=PUBG-QQQ list=PS4
add address=54.242.0.0/15 comment=PUBG-QQQ list=PS4
add address=67.202.0.0/18 comment=PUBG-QQQ list=PS4
add address=72.44.32.0/19 comment=PUBG-QQQ list=PS4
add address=75.101.128.0/17 comment=PUBG-QQQ list=PS4
add address=76.223.191.0/24 comment=PUBG-QQQ list=PS4
add address=100.24.0.0/13 comment=PUBG-QQQ list=PS4
add address=107.20.0.0/16 comment=PUBG-QQQ list=PS4
add address=107.21.0.0/18 comment=PUBG-QQQ list=PS4
add address=107.21.64.0/18 comment=PUBG-QQQ list=PS4
add address=107.21.128.0/17 comment=PUBG-QQQ list=PS4
add address=107.22.0.0/16 comment=PUBG-QQQ list=PS4
add address=107.23.0.0/17 comment=PUBG-QQQ list=PS4
add address=107.23.128.0/17 comment=PUBG-QQQ list=PS4
add address=174.129.0.0/16 comment=PUBG-QQQ list=PS4
add address=184.72.64.0/19 comment=PUBG-QQQ list=PS4
add address=184.72.96.0/19 comment=PUBG-QQQ list=PS4
add address=184.72.128.0/17 comment=PUBG-QQQ list=PS4
add address=184.73.0.0/16 comment=PUBG-QQQ list=PS4
add address=204.236.192.0/18 comment=PUBG-QQQ list=PS4
add address=204.236.192.0/19 comment=PUBG-QQQ list=PS4
add address=204.236.224.0/19 comment=PUBG-QQQ list=PS4
add address=216.182.224.0/21 comment=PUBG-QQQ list=PS4
add address=216.182.232.0/21 comment=PUBG-QQQ list=PS4
add address=216.182.232.0/22 comment=PUBG-QQQ list=PS4
/ip firewall filter
add action=drop chain=forward comment=FamilyShield dst-address-list=\
FamilyShield src-address=172.23.0.0/16
add action=drop chain=forward comment="drop invalid connections" \
connection-state=invalid disabled=yes protocol=tcp
add action=accept chain=forward connection-state=established disabled=yes
add action=accept chain=forward comment="allow related connections" \
connection-state=related disabled=yes
add action=drop chain=forward disabled=yes src-address=0.0.0.0/8
add action=drop chain=forward disabled=yes dst-address=0.0.0.0/8
add action=drop chain=forward disabled=yes src-address=127.0.0.0/8
add action=drop chain=forward disabled=yes dst-address=127.0.0.0/8
add action=drop chain=forward disabled=yes src-address=224.0.0.0/3
add action=drop chain=forward disabled=yes dst-address=224.0.0.0/3
/ip firewall mangle
add action=mark-packet chain=prerouting comment=ICMP new-packet-mark=ICMP \
passthrough=no protocol=icmp
add action=mark-packet chain=forward comment=ICMP new-packet-mark=ICMP \
add action=mark-packet chain=postrouting comment=ICMP new-packet-mark=ICMP \
add action=mark-packet chain=forward comment=DNS dst-port=53 new-packet-mark=\
DNS passthrough=no protocol=udp
add action=mark-packet chain=prerouting comment=DNS dst-port=53 \
new-packet-mark=DNS passthrough=no protocol=udp
add action=mark-packet chain=postrouting comment=DNS dst-port=53 \
add action=mark-packet chain=forward comment="Local Services" \
new-packet-mark=local-services passthrough=no src-address=\
192.168.252.0/24
add action=mark-packet chain=forward comment=Cache dscp=12 dst-address=\
172.16.0.0/12 new-packet-mark=Cache passthrough=no
add action=mark-packet chain=forward comment=CDN new-packet-mark=CDN \
passthrough=no src-address=62.201.250.0/23
add action=mark-packet chain=forward comment=GGC dst-address=172.16.0.0/12 \
new-packet-mark=GGC passthrough=no src-address-list=GGC
add action=mark-packet chain=forward comment=PS4 dst-address=172.16.0.0/12 \
new-packet-mark=PS4 passthrough=no src-address-list=PS4
add action=mark-packet chain=forward comment=FNA dst-address=172.16.0.0/12 \
new-packet-mark=FNA passthrough=no src-address-list=FNA
add action=mark-packet chain=forward comment=Facebook dst-address=\
172.16.0.0/12 new-packet-mark=Facebook passthrough=no src-address-list=\
Facebook
add action=mark-packet chain=forward comment=Google dst-address=172.16.0.0/12 \
new-packet-mark=Google passthrough=no src-address-list=Google
/ip firewall nat
add action=dst-nat chain=dstnat comment=DNS dst-port=53 protocol=udp \
to-addresses=185.128.36.41
add action=masquerade chain=srcnat comment="Expired Open SAS Only" \
dst-address=185.128.38.130 src-address=172.24.0.0/16
add action=masquerade chain=srcnat comment=Light src-address=172.16.0.0/16
add action=masquerade chain=srcnat comment=Smart src-address=172.17.0.0/16
add action=masquerade chain=srcnat comment=Economy src-address=172.18.0.0/16
add action=masquerade chain=srcnat comment=Standard src-address=172.19.0.0/16
add action=masquerade chain=srcnat comment=Active src-address=172.20.0.0/16
add action=masquerade chain=srcnat comment=Turbo src-address=172.21.0.0/16
add action=masquerade chain=srcnat comment=Business src-address=172.22.0.0/16
add action=masquerade chain=srcnat comment=Family src-address=172.23.0.0/16
/ip route
add comment=GT distance=1 gateway=212.126.122.145
add comment=GT distance=2 gateway=185.128.38.129
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www port=8090
set ssh disabled=yes
set api-ssl disabled=yes
/ppp aaa
set interim-update=1m use-radius=yes
/ppp secret
add local-address=172.21.0.9 name=1 password=1 remote-address=172.21.0.10
add local-address=172.22.0.12 name=goba@galaxynet password=12345 \
remote-address=172.22.0.13
add local-address=10.22.22.2 name=test password=test remote-address=\
212.126.122.150
/radius
add address=185.137.14.140 comment=ByPass disabled=yes secret=testing123 \
service=ppp timeout=3s
add address=185.128.38.130 comment=SAS secret=1@galaxynet service=ppp \
timeout=3s
/radius incoming
set accept=yes port=1700
/system clock
set time-zone-name=Asia/Baghdad
/system identity
set name=Ghadeer-GT
6 Replies 6
post the output of 'show ver' of your 6500. First we need to know what IOS version you are running and if everything required for configuring a PPPoE server on that platform is available,
CNC-GW#show ver
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9-M), Version 15.1(2)SY7, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Sun 13-Mar-16 07:31 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9-M), Version 15.1(2)SY7, RELEASE SOFTWARE (fc4)
CNC-GW uptime is 22 weeks, 1 day, 20 hours, 53 minutes
Uptime for this control processor is 22 weeks, 1 day, 20 hours, 36 minutes
System returned to ROM by reload at 10:47:00 UTC Tue May 15 2018 (SP by reload)
System image file is "disk0:s72033-adventerprisek9-mz.151-2.SY7.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.4) with 983008K/65536K bytes of memory.
Processor board ID SMC130100HR
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
12 Virtual Ethernet interfaces
171 Gigabit Ethernet interfaces
14 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
check if anything 'vpdn' related is available on your 6500:
6500(config)#vpdn-group ?
no sir there is no !
I don't think the 6500 can terminate PPPoE sessions at all. Do you have a router available ? Even the lower end routers such as the 1800/2800 routers support PPPoE session termination..
mmmmm i dont have yet,
but i can buy the 2800 or highest can we continue on configuration ?
dose the mikrotik conf is clear ? do you want me simplify more ?
thanks
