10-24-2013 01:31 AM - edited 03-04-2019 09:24 PM
We have a 2811 router and we are to connect an ADSL service to its Fast Ethernet port using PPPoE. Carrier already supplied username and password but I'm having a hard time to make it work. I'm not sure if the PPPoE configuration of the carrier is already correct as they usually have issues with this but is there someone who can share a working config for a 2811 using Fast Ethernet for PPPoE?
If I configure PPPoE on the FE interface then I'm not getting any IP address and I'm not sure if I have done it right. But using IP address DHCP config, I'm just getting a regular private IP address from them.
I cannot find a really good document on how to make this work.
Thanks in advance.
John
10-24-2013 02:33 AM
Dear John,
Do a "debug ppp authentication" and "debug ppp negotataion" to find out any credential issue, but if you are getting an ip address means authentication is fine and connection is ok. also make sure you have default route to dialer interface,
find the below example config for ppp0e for fa interface
interface FastEthernet0/0
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no sh
interface Dialer1
bandwidth 100000
ip mtu 1492
ip address negotiated
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp chap hostname xxx
ppp chap password yyy
ppp pap sent-username xxx password yyy
Shanil
*** Please rate Helpful Posts***
10-24-2013 03:23 AM
Thanks. Here's my current configuration. I can only get an IP address if I do a "ip address dhcp" on Fa0/0 which is not the dialer interface. Still doesn't work. I would probably need to contact the carrier again.
description dsl_interface_to_adsl
no ip address
no ip proxy-arp
ip virtual-reassembly
duplex auto
speed auto
interface Dialer1
mtu 1492
ip nat outside
zone-member security outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxx
ppp chap password xxxxxxx
ppp pap sent-username xxxxxxxx password 7 xxxxxxx
ip nat inside source list inside_net interface Dialer1 overload
ip access-list extended inside_net
deny ip 10.0.0.0 0.255.255.255 10.0.0.0 0.255.255.255
permit ip 10.199.67.0 0.0.0.63 any
ip route 0.0.0.0 0.0.0.0 Dialer1
10-24-2013 03:36 AM
Yes. Also you can directly connect the adsl line to a laptop/PC and create a dialup connection and check to confirm the line and credentials are fine.
Shanil
10-24-2013 04:36 AM
Thanks. I was too lazy to do that but I'll do it. lol
11-17-2013 10:18 AM
All configurations are correct. It was the carrier's fault. Thanks guys!
