pppoe over adsl is slow
wjimenez
I have a 2801 with 2 interfaces Fastethernet, one interface is connected to ADSL bridge, the session is up but the PC's connect to internet very slow.
Please help
Wilber Jimenez
5 Replies 5
m-haddad
Level 5
Level 5
Try to set the MTU to 1492.
Please let me know how it goes,
hello
iam having the same scenario, just you need to check the modem ,and before that ajust the MTU in by using Dr.TCP
Hope to help
Alaa
usslindstrom
I honestly don't mean to thread-jack... But were you ever able to find a solution to this problem?
I'm experiencing the exact same issue on an 1841 w/PPPoE to an ADSL Bridge.
I've tried everything I can think of at the moment, but no-go on all counts. If we compare configs or so, we might be able to come up with a viable solution.
I have the same issue on 1811 (12.4(15)T7) w/PPPoE to an ADSL Bridge modem. From the Cisco router itself, even pinging the Dialer IP is "very" slow i.e 105 ms. I "pinged extended" the router IP loopback from IP source "inside" interface and it's okay (1 ms). I tried disabled CEF and Inspect on Dialer interface, just in case, and still the same problem when pinging the Dialer IP i.e 105ms. Any idea?
Here the interfaces config:
interface FastEthernet0
description OUTSIDE Zone (To Modem ADSL)
no ip address
ip mtu 1492
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
end
ST-LO#
ST-LO#
ST-LO#sh run int dialer0
interface Dialer0
description PPPoE (linked to Fa0)
mtu 1492
ip address negotiated
ip access-group acl-outside in
no ip unreachables
ip nat outside
ip inspect france-fw out
no ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp chap hostname xxxxxxxx
ppp chap password 0 xxxxxxx
end
Well, going over our 2 config's - they're almost 100% identical.
I've played with the MTU settings, and even gone as low as 800, but nothing seems to affect it.
Here is the config, and some output commands:
Here are the router specs:
Cisco 1841 (revision 7.0) with 354304K/38912K bytes of memory
Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
flash: c1841-adventerprisek9-mz.124-15.T3.bin
Running Config:
interface FastEthernet0/1
description USS_WAN
no ip address
speed 100
full-duplex
no cdp enable
interface Dialer1
ip mtu 1452
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname -----
ppp chap password -----
ppp pap sent-username ----- password -----
ppp ipcp route default
The solution that I've had to use as of current - is the have the original ISPs craptastic equipment in place, and drop the cisco router into a DMZ of their equipment.
Doing it that way allows me to get the speed up to par with what it should be, and also use most/all of the features that the Cisco router gives me (VPN, etc.)
Unfortunately - it's very sad that my very expensive Cisco Router and very expensive Cisco modules - can't do the basic things that a $20 over-the-counter router can do. (cough* train itself on vpi/vci etc. cough*)
And thus, a using a combination of the two (Cisco Router and ISPs) is pretty much mandatory at this point in the game.
