PPPOE Setup - Cisco 10008
bcramer04
Working on setting up a Cisco 10008 with PPPOE and it seems like we kind of have it working but only one user can get on.
Here is part of the config:
Cisco-10008#show run
Building configuration...
Current configuration : 4134 bytes
version 12.2
no service pad
service password-encryption
hostname Cisco-10008
boot-start-marker
boot system flash disk0:c10k4-p11-mz.122-33.SB11.bin
boot bootldr bootflash:c10k4-eboot-mz.122-33.SB11.bin
boot-end-marker
aaa new-model
aaa authentication ppp default group radius
aaa authorization network default group radius
aaa accounting delay-start
aaa accounting network default start-stop group radius
aaa session-id common
facility-alarm outlet-temperature major 58
facility-alarm outlet-temperature minor 48
facility-alarm intake-temperature major 51
facility-alarm intake-temperature minor 41
card 1 4jacket-1
card 1/0 SPA-5X1GE-V2
card 1/1 SPA-5X1GE-V2
card 1/2 SPA-5X1GE-V2
card 1/3 SPA-5X1GE-V2
qos match statistics per-match
ip subnet-zero
no ip routing
subscriber access pppoe pre-authorize nas-port-id default
redundancy
mode sso
bba-group pppoe global
virtual-template 1
sessions max limit 8000
sessions per-vc limit 8
sessions per-mac limit 2
bba-group pppoe DSL
virtual-template 1
sessions per-vlan limit 30
sessions pre-auth limit ignore
interface GigabitEthernet1/2/0
no ip address
no ip route-cache
negotiation auto
pppoe enable group DSL
interface Virtual-Template1
mtu 1492
ip unnumbered Loopback0
peer default ip address pool pool1
ppp authentication chap
ip local pool pool1 192.168.0.1 192.168.0.100
ip classless
Cisco-10008#
Also is there a way to show a specific user once they are connected with PPPOE? I'm currently using "show aaa sessions", but was thinking it would be "show pppoe something"
Thanks!
9 Replies 9
Peter Paluch
A couple of observations/suggestions:
  1. You have no ip routing configured - why? Your device should definitely be configured with ip routing as it terminates the PPPoE sessions and will be routing the encapsulated IP packets
  2. Add the ppp mtu adaptive on the Virtual-Template1 interface. It has been my observation that specifically Windows PPPoE clients like to dictate their own MTU/MRU and disconnect themselves if the PPPoE concentrator does not comply to their own idea of MTU/MRU.
  3. Would you mind running debug pppoe events and debug pppoe packets when the second PPPoE client tries to log in and gets kicked out?
To my knowledge, IOSes indeed display the user in the show pppoe session command output.
Best regards,
Peter
1. We have no routing setup yet. We are currently running a Redback SE800 and will be moving to the Cisco 10008. Once we are ready to move over, we will add the ip routing.
2. I added the ppp mtu adaptive command on the Virtual- Template 1 interface.
3. Here is the debug output:
Cisco-10008#ter mon
Cisco-10008#debug pppoe events
PPPoE protocol events debugging is on
Cisco-10008#debug pppoe packets
PPPoE control packets debugging is on
Cisco-10008#
*Dec 18 12:18:47.744: [859]PPPoE 859: Segement (SSS class): UPDATED
*Dec 18 12:18:47.744: [922]PPPoE 922: Segement (SSS class): UPDATED
*Dec 18 12:19:35.320: PPPoE 0: I PADI  R:20aa.4b7d.7744 L:ffff.ffff.ffff Gi1/2/0
contiguous pak, size 60
         FF FF FF FF FF FF 20 AA 4B 7D 77 44 88 63 11 09
         00 00 00 0C 01 01 00 00 01 03 00 04 A4 0F 00 00
         00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
*Dec 18 12:19:35.320:  Service tag: NULL Tag
*Dec 18 12:19:35.320: PPPoE 0: O PADO, R:0009.b68b.f430 L:20aa.4b7d.7744 Gi1/2/0
contiguous pak, size 67
         20 AA 4B 7D 77 44 00 09 B6 8B F4 30 88 63 11 07
         00 00 00 2F 01 01 00 00 01 03 00 04 A4 0F 00 00
         01 02 00 0B 43 69 73 63 6F 2D 31 30 30 30 38 01
         04 00 10 D9 56 A7 49 99 CD 2C DD 20 7C 6B 9B 94
         63 EE 2A
*Dec 18 12:19:35.332: PPPoE 0: I PADR  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         00 09 B6 8B F4 30 20 AA 4B 7D 77 44 88 63 11 19
         00 00 00 20 01 01 00 00 01 03 00 04 A4 0F 00 00
         01 04 00 10 D9 56 A7 49 99 CD 2C DD 20 7C 6B 9B
         94 63 EE 2A 00 00 00 00 00 00 00 00
*Dec 18 12:19:35.332:  Service tag: NULL Tag
*Dec 18 12:19:35.332: PPPoE : encap string prepared
*Dec 18 12:19:35.332: [923]PPPoE 923: Access IE handle allocated
*Dec 18 12:19:35.332: [923]PPPoE 923: AAA get retrieved attrs
*Dec 18 12:19:35.332: [923]PPPoE 923: AAA get nas port details
*Dec 18 12:19:35.332: [923]PPPoE 923: AAA get dynamic attrs
*Dec 18 12:19:35.332: [923]PPPoE 923: AAA unique ID allocated
*Dec 18 12:19:35.332: [923]PPPoE 923: AAA method list  set
*Dec 18 12:19:35.332: [923]PPPoE 923: Service request sent to SSS
*Dec 18 12:19:35.332: [923]PPPoE 923: Created, Service: None R:0009.b68b.f430 L:20aa.4b7d.7744 Gi1/2/0
*Dec 18 12:19:35.332: [923]PPPoE 923: State NAS_PORT_POLICY_INQUIRY    Event SSS MORE KEYS
*Dec 18 12:19:35.332: [923]PPPoE 923: data path set to PPP
*Dec 18 12:19:35.332: [923]PPPoE 923: Segement (SSS class): PROVISION
*Dec 18 12:19:35.332: [923]PPPoE 923: State PROVISION_PPP    Event SSM PROVISIONED
*Dec 18 12:19:35.332: [923]PPPoE 923: O PADS  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         20 AA 4B 7D 77 44 00 09 B6 8B F4 30 88 63 11 65
         03 9B 00 20 01 01 00 00 01 03 00 04 A4 0F 00 00
*Dec 18 12:19:35.388: [923]PPPoE 923: State LCP_NEGOTIATION    Event SSS CONNECT LOCAL
*Dec 18 12:19:35.388: [923]PPPoE 923: Segement (SSS class): UPDATED
*Dec 18 12:19:35.388: [923]PPPoE 923: Segment (SSS class): BOUND
*Dec 18 12:19:35.388: [923]PPPoE 923: data path set to Virtual Acess
*Dec 18 12:19:35.388: [923]PPPoE 923: State LCP_NEGOTIATION    Event SSM UPDATED
*Dec 18 12:19:35.388: [923]PPPoE 923: AAA get dynamic attrs
*Dec 18 12:19:35.388: [923]PPPoE 923: State PTA_BINDING    Event STATIC BIND RESPONSE
*Dec 18 12:19:35.388: [923]PPPoE 923: Connected PTA
*Dec 18 12:19:35.392: %LINK-3-UPDOWN: Interface Virtual-Access3, changed state to up
*Dec 18 12:19:36.392: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access3, changed state to up
*Dec 18 12:19:40.688: [922]PPPoE 922: AAA get dynamic attrs
*Dec 18 12:19:40.688: [922]PPPoE 922: State LOCALLY_TERMINATED    Event PPP DISCONNECT
*Dec 18 12:19:40.688: [922]PPPoE 922: O PADT  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         20 AA 4B 7D 77 44 00 09 B6 8B F4 30 88 63 11 A7
         03 9A 00 00 00 00 00 00 00 00 00 00 00 00 00 00
*Dec 18 12:19:40.688: [922]PPPoE 922: Destroying  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
*Dec 18 12:19:40.688: PPPoE: Returning Vaccess Virtual-Access5
*Dec 18 12:19:40.688: [922]PPPoE 922: AAA account stopped
*Dec 18 12:19:40.688: [922]PPPoE 922: Segement (SSS class): UNBOUND
*Dec 18 12:19:40.688: [922]PPPoE 922: Segement (SSS class): UNPROVISION
*Dec 18 12:19:40.692: %LINK-3-UPDOWN: Interface Virtual-Access5, changed state to down
*Dec 18 12:19:41.688: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access5, changed state to down
*Dec 18 12:20:34.280: [923]PPPoE 923: AAA get dynamic attrs
*Dec 18 12:20:34.540: PPPoE 0: I PADI  R:20aa.4b7d.7744 L:ffff.ffff.ffff Gi1/2/0
         00 00 00 0C 01 01 00 00 01 03 00 04 12 12 00 00
*Dec 18 12:20:34.540:  Service tag: NULL Tag
*Dec 18 12:20:34.540: PPPoE 0: O PADO, R:0009.b68b.f430 L:20aa.4b7d.7744 Gi1/2/0
         00 00 00 2F 01 01 00 00 01 03 00 04 12 12 00 00
         63 EE 2A
*Dec 18 12:20:34.552: PPPoE 0: I PADR  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         00 00 00 20 01 01 00 00 01 03 00 04 12 12 00 00
*Dec 18 12:20:34.552:  Service tag: NULL Tag
*Dec 18 12:20:34.552: PPPoE : encap string prepared
*Dec 18 12:20:34.552: [924]PPPoE 924: Access IE handle allocated
*Dec 18 12:20:34.552: [924]PPPoE 924: AAA get retrieved attrs
*Dec 18 12:20:34.552: [924]PPPoE 924: AAA get nas port details
*Dec 18 12:20:34.552: [924]PPPoE 924: AAA get dynamic attrs
*Dec 18 12:20:34.552: [924]PPPoE 924: AAA unique ID allocated
*Dec 18 12:20:34.552: [924]PPPoE 924: AAA method list  set
*Dec 18 12:20:34.552: [924]PPPoE 924: Service request sent to SSS
*Dec 18 12:20:34.552: [924]PPPoE 924: Created, Service: None R:0009.b68b.f430 L:20aa.4b7d.7744 Gi1/2/0
*Dec 18 12:20:34.552: [924]PPPoE 924: State NAS_PORT_POLICY_INQUIRY    Event SSS MORE KEYS
*Dec 18 12:20:34.552: [924]PPPoE 924: data path set to PPP
*Dec 18 12:20:34.552: [924]PPPoE 924: Segement (SSS class): PROVISION
*Dec 18 12:20:34.552: [924]PPPoE 924: State PROVISION_PPP    Event SSM PROVISIONED
*Dec 18 12:20:34.552: [924]PPPoE 924: O PADS  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         03 9C 00 20 01 01 00 00 01 03 00 04 12 12 00 00
*Dec 18 12:20:34.624: [924]PPPoE 924: State LCP_NEGOTIATION    Event SSS CONNECT LOCAL
*Dec 18 12:20:34.624: [924]PPPoE 924: Segement (SSS class): UPDATED
*Dec 18 12:20:34.624: [924]PPPoE 924: Segment (SSS class): BOUND
*Dec 18 12:20:34.624: [924]PPPoE 924: data path set to Virtual Acess
*Dec 18 12:20:34.624: [924]PPPoE 924: State LCP_NEGOTIATION    Event SSM UPDATED
*Dec 18 12:20:34.624: [924]PPPoE 924: AAA get dynamic attrs
*Dec 18 12:20:34.624: [924]PPPoE 924: State PTA_BINDING    Event STATIC BIND RESPONSE
*Dec 18 12:20:34.624: [924]PPPoE 924: Connected PTA
*Dec 18 12:20:34.628: %LINK-3-UPDOWN: Interface Virtual-Access5, changed state to up
*Dec 18 12:20:35.628: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access5, changed state to up
*Dec 18 12:20:36.272: [923]PPPoE 923: AAA get dynamic attrs
*Dec 18 12:20:36.272: [923]PPPoE 923: State LOCALLY_TERMINATED    Event PPP DISCONNECT
*Dec 18 12:20:36.272: [923]PPPoE 923: O PADT  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         03 9B 00 00 00 00 00 00 00 00 00 00 00 00 00 00
*Dec 18 12:20:36.272: [923]PPPoE 923: Destroying  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
*Dec 18 12:20:36.272: PPPoE: Returning Vaccess Virtual-Access3
*Dec 18 12:20:36.272: [923]PPPoE 923: AAA account stopped
*Dec 18 12:20:36.272: [923]PPPoE 923: Segement (SSS class): UNBOUND
*Dec 18 12:20:36.272: [923]PPPoE 923: Segement (SSS class): UNPROVISION
*Dec 18 12:20:36.276: %LINK-3-UPDOWN: Interface Virtual-Access3, changed state to down
*Dec 18 12:20:37.272: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access3, changed state to down
Brandon
Hi Brandon,
Are you creating multiple PPPoE sessions from the same MAC address? If so, can you perhaps add the sessions per-mac limit 2 command into your bba-group pppoe DSL configuration? Alternatively, can you try creating two or more PPPoE sessions from different MAC addresses? Is it also possible that the AAA (the Radius) somehow requires that only a single login per MAC is allowed?
Best regards,
Peter
I had 2 DSL modems/routers setup. For now, I have disconnected the other modem.
After about 60 Idle Time seconds it drops:
Cisco-10008#show aaa sessions
Total sessions since last reload: 966
Session Id: 1356
   Unique Id: 951
   User Name: admin
   IP Address: 192.168.7.170
   Idle Time: 0
   CT Call Handle: 0
Session Id: 1391
   Unique Id: 976
   User Name: brandon@molalla.net
   IP Address: 192.168.0.40
   Idle Time: 59
   CT Call Handle: 0
Session Id: 1356
   Unique Id: 951
   User Name: admin
   Idle Time: 0
   CT Call Handle: 0
Session Id: 1391
   Unique Id: 976
   Idle Time: 59
   CT Call Handle: 0
Session Id: 1356
   Unique Id: 951
   User Name: admin
   Idle Time: 0
   CT Call Handle: 0
Session Id: 1391
   Unique Id: 976
   Idle Time: 60
   CT Call Handle: 0
Cisco-10008#
*Dec 18 12:46:46.800: [946]PPPoE 946: AAA get dynamic attrs
*Dec 18 12:46:47.056: PPPoE 0: I PADI  R:20aa.4b7d.7744 L:ffff.ffff.ffff Gi1/2/0
         00 00 00 0C 01 01 00 00 01 03 00 04 2B 16 00 00
*Dec 18 12:46:47.056:  Service tag: NULL Tag
*Dec 18 12:46:47.056: PPPoE 0: O PADO, R:0009.b68b.f430 L:20aa.4b7d.7744 Gi1/2/0
         00 00 00 2F 01 01 00 00 01 03 00 04 2B 16 00 00
         63 EE 2A
*Dec 18 12:46:47.064: PPPoE 0: I PADR  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         00 00 00 20 01 01 00 00 01 03 00 04 2B 16 00 00
*Dec 18 12:46:47.064:  Service tag: NULL Tag
*Dec 18 12:46:47.064: PPPoE : encap string prepared
*Dec 18 12:46:47.068: [947]PPPoE 947: Access IE handle allocated
*Dec 18 12:46:47.068: [947]PPPoE 947: AAA get retrieved attrs
*Dec 18 12:46:47.068: [947]PPPoE 947: AAA get nas port details
*Dec 18 12:46:47.068: [947]PPPoE 947: AAA get dynamic attrs
*Dec 18 12:46:47.068: [947]PPPoE 947: AAA unique ID allocated
*Dec 18 12:46:47.068: [947]PPPoE 947: AAA method list  set
*Dec 18 12:46:47.068: [947]PPPoE 947: Service request sent to SSS
*Dec 18 12:46:47.068: [947]PPPoE 947: Created, Service: None R:0009.b68b.f430 L:20aa.4b7d.7744 Gi1/2/0
*Dec 18 12:46:47.068: [947]PPPoE 947: State NAS_PORT_POLICY_INQUIRY    Event SSS MORE KEYS
*Dec 18 12:46:47.068: [947]PPPoE 947: data path set to PPP
*Dec 18 12:46:47.068: [947]PPPoE 947: Segement (SSS class): PROVISION
*Dec 18 12:46:47.068: [947]PPPoE 947: State PROVISION_PPP    Event SSM PROVISIONED
*Dec 18 12:46:47.068: [947]PPPoE 947: O PADS  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         03 B3 00 20 01 01 00 00 01 03 00 04 2B 16 00 00
*Dec 18 12:46:47.228: [947]PPPoE 947: State LCP_NEGOTIATION    Event SSS CONNECT LOCAL
*Dec 18 12:46:47.228: [947]PPPoE 947: Segement (SSS class): UPDATED
*Dec 18 12:46:47.228: [947]PPPoE 947: Segment (SSS class): BOUND
*Dec 18 12:46:47.228: [947]PPPoE 947: data path set to Virtual Acess
*Dec 18 12:46:47.228: [947]PPPoE 947: State LCP_NEGOTIATION    Event SSM UPDATED
*Dec 18 12:46:47.228: [947]PPPoE 947: AAA get dynamic attrs
*Dec 18 12:46:47.228: [947]PPPoE 947: State PTA_BINDING    Event STATIC BIND RESPONSE
*Dec 18 12:46:47.228: [947]PPPoE 947: Connected PTA
*Dec 18 12:46:47.232: %LINK-3-UPDOWN: Interface Virtual-Access3, changed state to up
*Dec 18 12:46:48.232: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access3, changed state to up
*Dec 18 12:46:48.816: [946]PPPoE 946: AAA get dynamic attrs
*Dec 18 12:46:48.816: [946]PPPoE 946: State LOCALLY_TERMINATED    Event PPP DISCONNECT
*Dec 18 12:46:48.816: [946]PPPoE 946: O PADT  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         03 B2 00 00 00 00 00 00 00 00 00 00 00 00 00 00
*Dec 18 12:46:48.816: [946]PPPoE 946: Destroying  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
*Dec 18 12:46:48.816: PPPoE: Returning Vaccess Virtual-Access4
*Dec 18 12:46:48.816: [946]PPPoE 946: AAA account stopped
*Dec 18 12:46:48.816: [946]PPPoE 946: Segement (SSS class): UNBOUND
*Dec 18 12:46:48.816: [946]PPPoE 946: Segement (SSS class): UNPROVISION
*Dec 18 12:46:48.820: %LINK-3-UPDOWN: Interface Virtual-Access4, changed state to down
*Dec 18 12:46:49.816: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access4, changed state to down
Cisco-10008#
*Dec 18 12:47:48.100: [947]PPPoE 947: AAA get dynamic attrs
*Dec 18 12:47:48.296: PPPoE 0: I PADI  R:20aa.4b7d.7744 L:ffff.ffff.ffff Gi1/2/0
         00 00 00 0C 01 01 00 00 01 03 00 04 51 17 00 00
*Dec 18 12:47:48.296:  Service tag: NULL Tag
*Dec 18 12:47:48.296: PPPoE 0: O PADO, R:0009.b68b.f430 L:20aa.4b7d.7744 Gi1/2/0
         00 00 00 2F 01 01 00 00 01 03 00 04 51 17 00 00
         63 EE 2A
*Dec 18 12:47:48.308: PPPoE 0: I PADR  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         00 00 00 20 01 01 00 00 01 03 00 04 51 17 00 00
*Dec 18 12:47:48.308:  Service tag: NULL Tag
*Dec 18 12:47:48.308: PPPoE : encap string prepared
*Dec 18 12:47:48.308: [948]PPPoE 948: Access IE handle allocated
*Dec 18 12:47:48.308: [948]PPPoE 948: AAA get retrieved attrs
*Dec 18 12:47:48.308: [948]PPPoE 948: AAA get nas port details
*Dec 18 12:47:48.308: [948]PPPoE 948: AAA get dynamic attrs
*Dec 18 12:47:48.308: [948]PPPoE 948: AAA unique ID allocated
*Dec 18 12:47:48.308: [948]PPPoE 948: AAA method list  set
*Dec 18 12:47:48.308: [948]PPPoE 948: Service request sent to SSS
*Dec 18 12:47:48.308: [948]PPPoE 948: Created, Service: None R:0009.b68b.f430 L:20aa.4b7d.7744 Gi1/2/0
*Dec 18 12:47:48.308: [948]PPPoE 948: State NAS_PORT_POLICY_INQUIRY    Event SSS MORE KEYS
*Dec 18 12:47:48.308: [948]PPPoE 948: data path set to PPP
*Dec 18 12:47:48.308: [948]PPPoE 948: Segement (SSS class): PROVISION
*Dec 18 12:47:48.308: [948]PPPoE 948: State PROVISION_PPP    Event SSM PROVISIONED
*Dec 18 12:47:48.308: [948]PPPoE 948: O PADS  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         03 B4 00 20 01 01 00 00 01 03 00 04 51 17 00 00
*Dec 18 12:47:48.444: [948]PPPoE 948: State LCP_NEGOTIATION    Event SSS CONNECT LOCAL
*Dec 18 12:47:48.444: [948]PPPoE 948: Segement (SSS class): UPDATED
*Dec 18 12:47:48.444: [948]PPPoE 948: Segment (SSS class): BOUND
*Dec 18 12:47:48.444: [948]PPPoE 948: data path set to Virtual Acess
*Dec 18 12:47:48.444: [948]PPPoE 948: State LCP_NEGOTIATION    Event SSM UPDATED
*Dec 18 12:47:48.444: [948]PPPoE 948: AAA get dynamic attrs
*Dec 18 12:47:48.444: [948]PPPoE 948: State PTA_BINDING    Event STATIC BIND RESPONSE
*Dec 18 12:47:48.444: [948]PPPoE 948: Connected PTA
*Dec 18 12:47:48.448: %LINK-3-UPDOWN: Interface Virtual-Access5, changed state to up
*Dec 18 12:47:49.448: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access5, changed state to up
*Dec 18 12:47:50.096: [947]PPPoE 947: AAA get dynamic attrs
*Dec 18 12:47:50.096: [947]PPPoE 947: State LOCALLY_TERMINATED    Event PPP DISCONNECT
*Dec 18 12:47:50.096: [947]PPPoE 947: O PADT  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         03 B3 00 00 00 00 00 00 00 00 00 00 00 00 00 00
*Dec 18 12:47:50.096: [947]PPPoE 947: Destroying  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
*Dec 18 12:47:50.096: PPPoE: Returning Vaccess Virtual-Access3
*Dec 18 12:47:50.096: [947]PPPoE 947: AAA account stopped
*Dec 18 12:47:50.096: [947]PPPoE 947: Segement (SSS class): UNBOUND
*Dec 18 12:47:50.096: [947]PPPoE 947: Segement (SSS class): UNPROVISION
*Dec 18 12:47:50.100: %LINK-3-UPDOWN: Interface Virtual-Access3, changed state to down
*Dec 18 12:47:51.096: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access3, changed state to down
Brandon,
This is strange. Could you modify your AAA configuration a bit as follows? I am trying to isolate whether the problem lies in the AAA or somewhere in the PPP/PPPoE configuration.
no aaa authentication ppp default group radius
no aaa authorization network default group radius
aaa authentication ppp default local
username user1 password user1
username user2 password user2
This should force the router to authenticate the PPPoE sessions using the local database. Use the user1 and user2 logins/passwords to authenticate the PPPoE to the router. Let's see if this can make the session more stable.
Best regards,
Peter
Here is the current running config:
Current configuration : 4054 bytes
version 12.2
no service pad
boot-start-marker
boot-end-marker
aaa new-model
card 1 4jacket-1
ip subnet-zero
no ip routing
username user1 password 7 105B1A1C1746
username user2 password 7 150718091678
redundancy
mode sso
bba-group pppoe DSL
virtual-template 1
interface Loopback0
no ip address
interface FastEthernet0/0/0
ip address 192.168.7.27 255.255.254.0
no ip route-cache
media-type rj45
speed auto
full-duplex
interface GigabitEthernet1/0/0
no ip address
no ip route-cache
shutdown
negotiation auto
interface GigabitEthernet1/0/1
no ip address
no ip route-cache
shutdown
negotiation auto
interface GigabitEthernet1/0/2
no ip address
no ip route-cache
shutdown
negotiation auto
interface GigabitEthernet1/0/3
no ip address
no ip route-cache
shutdown
negotiation auto
interface GigabitEthernet1/0/4
no ip address
no ip route-cache
shutdown
negotiation auto
interface GigabitEthernet1/1/0
no ip address
no ip route-cache
shutdown
negotiation auto
interface GigabitEthernet1/1/1
no ip address
no ip route-cache
shutdown
negotiation auto
interface GigabitEthernet1/1/2
no ip address
no ip route-cache
shutdown
negotiation auto
interface GigabitEthernet1/1/3
no ip address
no ip route-cache
shutdown
negotiation auto
interface GigabitEthernet1/1/4
no ip address
no ip route-cache
shutdown
negotiation auto
no ip address
no ip route-cache
negotiation auto
interface GigabitEthernet1/2/1
no ip address
no ip route-cache
shutdown
negotiation auto
interface GigabitEthernet1/2/2
no ip address
no ip route-cache
shutdown
negotiation auto
interface GigabitEthernet1/2/3
no ip address
no ip route-cache
shutdown
negotiation auto
interface GigabitEthernet1/2/4
no ip address
no ip route-cache
shutdown
negotiation auto
interface GigabitEthernet1/3/0
no ip address
no ip route-cache
shutdown
negotiation auto
interface GigabitEthernet1/3/1
no ip address
no ip route-cache
shutdown
negotiation auto
interface GigabitEthernet1/3/2
no ip address
no ip route-cache
shutdown
negotiation auto
interface GigabitEthernet1/3/3
no ip address
no ip route-cache
shutdown
negotiation auto
interface GigabitEthernet1/3/4
no ip address
no ip route-cache
shutdown
negotiation auto
mtu 1492
ppp mtu adaptive
ppp ipcp dns 216.134.160.6 216.134.160.13
ip classless
no ip http server
snmp-server community  RO
radius-server host 192.168.7.153 auth-port 1812 acct-port 1813 key 7 095F45101D0C0117
radius-server unique-ident 3
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
session-timeout 1200
line vty 5 15
session-timeout 120
end
Cisco-10008#
Debug:
Total sessions since last reload: 1005
Session Id: 1356
   Unique Id: 951
   User Name: admin
   Idle Time: 0
   CT Call Handle: 0
Session Id: 1416
   Unique Id: 997
   User Name: admin
   Idle Time: 0
   CT Call Handle: 0
Cisco-10008#
*Dec 18 13:13:31.332: PPPoE 0: I PADI  R:20aa.4b7d.7744 L:ffff.ffff.ffff Gi1/2/0
         00 00 00 0C 01 01 00 00 01 03 00 04 EB 18 00 00
*Dec 18 13:13:31.332:  Service tag: NULL Tag
*Dec 18 13:13:31.332: PPPoE 0: O PADO, R:0009.b68b.f430 L:20aa.4b7d.7744 Gi1/2/0
         00 00 00 2F 01 01 00 00 01 03 00 04 EB 18 00 00
         63 EE 2A
*Dec 18 13:13:31.340: PPPoE 0: I PADR  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         00 00 00 20 01 01 00 00 01 03 00 04 EB 18 00 00
*Dec 18 13:13:31.340:  Service tag: NULL Tag
*Dec 18 13:13:31.340: PPPoE : encap string prepared
*Dec 18 13:13:31.340: [985]PPPoE 985: Access IE handle allocated
*Dec 18 13:13:31.340: [985]PPPoE 985: AAA get retrieved attrs
*Dec 18 13:13:31.340: [985]PPPoE 985: AAA get nas port details
*Dec 18 13:13:31.340: [985]PPPoE 985: AAA get dynamic attrs
*Dec 18 13:13:31.340: [985]PPPoE 985: AAA unique ID allocated
*Dec 18 13:13:31.340: [985]PPPoE 985: AAA method list  set
*Dec 18 13:13:31.340: [985]PPPoE 985: Service request sent to SSS
*Dec 18 13:13:31.340: [985]PPPoE 985: Created, Service: None R:0009.b68b.f430 L:20aa.4b7d.7744 Gi1/2/0
*Dec 18 13:13:31.340: [985]PPPoE 985: State NAS_PORT_POLICY_INQUIRY    Event SSS MORE KEYS
*Dec 18 13:13:31.340: [985]PPPoE 985: data path set to PPP
*Dec 18 13:13:31.340: [985]PPPoE 985: Segement (SSS class): PROVISION
*Dec 18 13:13:31.340: [985]PPPoE 985: State PROVISION_PPP    Event SSM PROVISIONED
*Dec 18 13:13:31.340: [985]PPPoE 985: O PADS  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         03 D9 00 20 01 01 00 00 01 03 00 04 EB 18 00 00
*Dec 18 13:13:31.380: [985]PPPoE 985: AAA get dynamic attrs
*Dec 18 13:13:31.392: [985]PPPoE 985: State LCP_NEGOTIATION    Event PPP DISCONNECT
*Dec 18 13:13:31.392: [985]PPPoE 985: O PADT  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         03 D9 00 00 00 00 00 00 00 00 00 00 00 00 00 00
*Dec 18 13:13:31.392: [985]PPPoE 985: Destroying  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
*Dec 18 13:13:31.392: [985]PPPoE 985: AAA get dynamic attrs
*Dec 18 13:13:31.392: [985]PPPoE 985: AAA account stopped
*Dec 18 13:13:31.392: [985]PPPoE 985: Segement (SSS class): UNPROVISION
*Dec 18 13:13:31.816: PPPoE 0: I PADI  R:20aa.4b7d.7744 L:ffff.ffff.ffff Gi1/2/0
         00 00 00 0C 01 01 00 00 01 03 00 04 77 1A 00 00
*Dec 18 13:13:31.816:  Service tag: NULL Tag
*Dec 18 13:13:31.816: PPPoE 0: O PADO, R:0009.b68b.f430 L:20aa.4b7d.7744 Gi1/2/0
         00 00 00 2F 01 01 00 00 01 03 00 04 77 1A 00 00
         63 EE 2A
*Dec 18 13:13:31.820: PPPoE 0: I PADR  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         00 00 00 20 01 01 00 00 01 03 00 04 77 1A 00 00
*Dec 18 13:13:31.820:  Service tag: NULL Tag
*Dec 18 13:13:31.820: PPPoE : encap string prepared
*Dec 18 13:13:31.820: [986]PPPoE 986: Access IE handle allocated
*Dec 18 13:13:31.820: [986]PPPoE 986: AAA get retrieved attrs
*Dec 18 13:13:31.820: [986]PPPoE 986: AAA get nas port details
*Dec 18 13:13:31.820: [986]PPPoE 986: AAA get dynamic attrs
*Dec 18 13:13:31.820: [986]PPPoE 986: AAA unique ID allocated
*Dec 18 13:13:31.820: [986]PPPoE 986: AAA method list  set
*Dec 18 13:13:31.820: [986]PPPoE 986: Service request sent to SSS
*Dec 18 13:13:31.820: [986]PPPoE 986: Created, Service: None R:0009.b68b.f430 L:20aa.4b7d.7744 Gi1/2/0
*Dec 18 13:13:31.820: [986]PPPoE 986: State NAS_PORT_POLICY_INQUIRY    Event SSS MORE KEYS
*Dec 18 13:13:31.824: [986]PPPoE 986: data path set to PPP
*Dec 18 13:13:31.824: [986]PPPoE 986: Segement (SSS class): PROVISION
*Dec 18 13:13:31.824: [986]PPPoE 986: State PROVISION_PPP    Event SSM PROVISIONED
*Dec 18 13:13:31.824: [986]PPPoE 986: O PADS  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         03 DA 00 20 01 01 00 00 01 03 00 04 77 1A 00 00
*Dec 18 13:13:31.860: [986]PPPoE 986: AAA get dynamic attrs
*Dec 18 13:13:31.872: [986]PPPoE 986: State LCP_NEGOTIATION    Event PPP DISCONNECT
*Dec 18 13:13:31.872: [986]PPPoE 986: O PADT  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         03 DA 00 00 00 00 00 00 00 00 00 00 00 00 00 00
*Dec 18 13:13:31.872: [986]PPPoE 986: Destroying  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
*Dec 18 13:13:31.872: [986]PPPoE 986: AAA get dynamic attrs
*Dec 18 13:13:31.872: [986]PPPoE 986: AAA account stopped
*Dec 18 13:13:31.872: [986]PPPoE 986: Segement (SSS class): UNPROVISION
I dont see the user1 under show aaa sessions anymore.
Total sessions since last reload: 1010
Session Id: 1356
   Unique Id: 951
   User Name: admin
   Idle Time: 0
   CT Call Handle: 0
Session Id: 1416
   Unique Id: 997
   User Name: admin
   Idle Time: 0
   CT Call Handle: 0
Cisco-10008#
Hello Brandon,
Interesting. Let's try to focus on what is happening inside the PPP session itself. Can you please leave the existing debugs in place, and in addition, add the next two?
debug ppp negotiation
debug ppp authentication
Sorry for delays in responding...
Best regards,
Peter
I added that user1 to my router, but I forgot to remove the @molalla.net part.
Here is the debug with just user1:
Cisco-10008#
*Dec 19 04:08:21.184: Vi2.1 LCP: I TERMREQ [Open] id 2 len 16
*Dec 19 04:08:21.184: Vi2.1 LCP: (0x557365722072657175657374)
*Dec 19 04:08:21.184: Vi2.1 IPCP: Event[DOWN] State[Stopped to Starting]
*Dec 19 04:08:21.184: Vi2.1 IPCP: Event[CLOSE] State[Starting to Initial]
*Dec 19 04:08:21.184: Vi2.1 LCP: O TERMACK [Open] id 2 len 4
*Dec 19 04:08:21.184: Vi2.1 LCP: Event[Receive TermReq] State[Open to Stopping]
*Dec 19 04:08:21.184: Vi2.1 PPP DISC: Received LCP TERMREQ from peer
*Dec 19 04:08:21.184: Vi2.1 PPP: Sending Acct Event[Down] id[E26]
*Dec 19 04:08:21.184: [582]PPPoE 3587: AAA get dynamic attrs
*Dec 19 04:08:21.184: Vi2.1 PPP: Phase is TERMINATING
*Dec 19 04:08:21.368: PPPoE 0: I PADI  R:20aa.4b7d.7744 L:ffff.ffff.ffff Gi1/2/0
         00 00 00 0C 01 01 00 00 01 03 00 04 6F 17 00 00
*Dec 19 04:08:21.368:  Service tag: NULL Tag
*Dec 19 04:08:21.368: PPPoE 0: O PADO, R:0009.b68b.f430 L:20aa.4b7d.7744 Gi1/2/0
         00 00 00 2F 01 01 00 00 01 03 00 04 6F 17 00 00
         63 EE 2A
*Dec 19 04:08:21.372: PPPoE 0: I PADR  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         00 00 00 20 01 01 00 00 01 03 00 04 6F 17 00 00
*Dec 19 04:08:21.372:  Service tag: NULL Tag
*Dec 19 04:08:21.372: PPPoE : encap string prepared
*Dec 19 04:08:21.372: [583]PPPoE 3588: Access IE handle allocated
*Dec 19 04:08:21.372: [583]PPPoE 3588: AAA get retrieved attrs
*Dec 19 04:08:21.372: [583]PPPoE 3588: AAA get nas port details
*Dec 19 04:08:21.372: [583]PPPoE 3588: AAA get dynamic attrs
*Dec 19 04:08:21.372: [583]PPPoE 3588: AAA unique ID allocated
*Dec 19 04:08:21.372: [583]PPPoE 3588: AAA method list  set
*Dec 19 04:08:21.372: [583]PPPoE 3588: Service request sent to SSS
*Dec 19 04:08:21.372: [583]PPPoE 3588: Created, Service: None R:0009.b68b.f430 L:20aa.4b7d.7744 Gi1/2/0
*Dec 19 04:08:21.376: [583]PPPoE 3588: State NAS_PORT_POLICY_INQUIRY    Event SSS MORE KEYS
*Dec 19 04:08:21.376: PPP: Alloc Context [5107314C]
*Dec 19 04:08:21.376: ppp583 PPP: Phase is ESTABLISHING
*Dec 19 04:08:21.376: [583]PPPoE 3588: data path set to PPP
*Dec 19 04:08:21.376: [583]PPPoE 3588: Segement (SSS class): PROVISION
*Dec 19 04:08:21.376: [583]PPPoE 3588: State PROVISION_PPP    Event SSM PROVISIONED
*Dec 19 04:08:21.376: [583]PPPoE 3588: O PADS  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         0E 04 00 20 01 01 00 00 01 03 00 04 6F 17 00 00
*Dec 19 04:08:21.376: ppp583 PPP: Using vpn set call direction
*Dec 19 04:08:21.376: ppp583 PPP: Treating connection as a callin
*Dec 19 04:08:21.376: ppp583 PPP: Session handle[E2000DFC] Session id[583]
*Dec 19 04:08:21.376: ppp583 LCP: Event[OPEN] State[Initial to Starting]
*Dec 19 04:08:21.376: ppp583 PPP LCP: Enter passive mode, state[Stopped]
*Dec 19 04:08:21.456: ppp583 LCP: I CONFREQ [Stopped] id 1 len 14
*Dec 19 04:08:21.456: ppp583 LCP:    MRU 1492 (0x010405D4)
*Dec 19 04:08:21.456: ppp583 LCP:    MagicNumber 0x437EAB7A (0x0506437EAB7A)
*Dec 19 04:08:21.456: ppp583 LCP: O CONFREQ [Stopped] id 1 len 19
*Dec 19 04:08:21.456: ppp583 LCP:    AuthProto CHAP (0x0305C22305)
*Dec 19 04:08:21.456: ppp583 LCP:    MagicNumber 0x1384888F (0x05061384888F)
*Dec 19 04:08:21.456: ppp583 LCP: O CONFACK [Stopped] id 1 len 14
*Dec 19 04:08:21.456: ppp583 LCP: Event[Receive ConfReq+] State[Stopped to ACKsent]
*Dec 19 04:08:21.464: ppp583 LCP: I CONFACK [ACKsent] id 1 len 19
*Dec 19 04:08:21.464: ppp583 LCP:    MRU 1492 (0x010405D4)
*Dec 19 04:08:21.464: ppp583 LCP:    AuthProto CHAP (0x0305C22305)
*Dec 19 04:08:21.464: ppp583 LCP:    MagicNumber 0x1384888F (0x05061384888F)
*Dec 19 04:08:21.464: ppp583 LCP: Event[Receive ConfAck] State[ACKsent to Open]
*Dec 19 04:08:21.484: ppp583 PPP: Phase is AUTHENTICATING, by this end
*Dec 19 04:08:21.484: ppp583 CHAP: O CHALLENGE id 1 len 32 from "Cisco-10008"
*Dec 19 04:08:21.484: ppp583 LCP: State is Open
*Dec 19 04:08:21.488: ppp583 CHAP: I RESPONSE id 1 len 26 from "user1"
*Dec 19 04:08:21.488: ppp583 PPP: Phase is FORWARDING, Attempting Forward
*Dec 19 04:08:21.488: ppp583 PPP: Phase is AUTHENTICATING, Unauthenticated User
*Dec 19 04:08:21.488: ppp583 PPP: Sent CHAP LOGIN Request
*Dec 19 04:08:21.488: ppp583 PPP: Received LOGIN Response PASS
*Dec 19 04:08:21.492: [583]PPPoE 3588: State LCP_NEGOTIATION    Event SSS CONNECT LOCAL
*Dec 19 04:08:21.492: [583]PPPoE 3588: Segement (SSS class): UPDATED
*Dec 19 04:08:21.492: [583]PPPoE 3588: Segment (SSS class): BOUND
*Dec 19 04:08:21.492: [583]PPPoE 3588: data path set to Virtual Acess
*Dec 19 04:08:21.492: [583]PPPoE 3588: State LCP_NEGOTIATION    Event SSM UPDATED
*Dec 19 04:08:21.492: Vi2.2 PPP: Phase is AUTHENTICATING, Authenticated User
*Dec 19 04:08:21.492: Vi2.2 CHAP: O SUCCESS id 1 len 4
*Dec 19 04:08:21.492: [583]PPPoE 3588: AAA get dynamic attrs
*Dec 19 04:08:21.492: Vi2.2 PPP: Phase is UP
*Dec 19 04:08:21.492: Vi2.2 IPCP: Protocol configured, start CP. state[Initial]
*Dec 19 04:08:21.492: Vi2.2 IPCP: Event[OPEN] State[Initial to Starting]
*Dec 19 04:08:21.492: Vi2.2 IPCP: O CONFREQ [Starting] id 1 len 10
*Dec 19 04:08:21.492: Vi2.2 IPCP:    Address 127.0.0.254 (0x03067F0000FE)
*Dec 19 04:08:21.492: Vi2.2 IPCP: Event[UP] State[Starting to REQsent]
*Dec 19 04:08:21.492: [583]PPPoE 3588: State PTA_BINDING    Event STATIC BIND RESPONSE
*Dec 19 04:08:21.492: [583]PPPoE 3588: Connected PTA
*Dec 19 04:08:21.500: Vi2.2 IPCP: I CONFREQ [REQsent] id 1 len 22
*Dec 19 04:08:21.500: Vi2.2 IPCP:    Address 0.0.0.0 (0x030600000000)
*Dec 19 04:08:21.500: Vi2.2 IPCP:    PrimaryDNS 0.0.0.0 (0x810600000000)
*Dec 19 04:08:21.500: Vi2.2 IPCP:    SecondaryDNS 0.0.0.0 (0x830600000000)
*Dec 19 04:08:21.500: Vi2.2 IPCP AUTHOR: Done.  Her address 0.0.0.0, we want 0.0.0.0
*Dec 19 04:08:21.500: Vi2.2 IPCP: Pool returned 192.168.0.64
*Dec 19 04:08:21.500: Vi2.2 IPCP: O CONFNAK [REQsent] id 1 len 22
*Dec 19 04:08:21.500: Vi2.2 IPCP:    Address 192.168.0.64 (0x0306C0A80040)
*Dec 19 04:08:21.500: Vi2.2 IPCP:    PrimaryDNS 216.134.160.6 (0x8106D886A006)
*Dec 19 04:08:21.500: Vi2.2 IPCP:    SecondaryDNS 216.134.160.13 (0x8306D886A00D)
*Dec 19 04:08:21.500: Vi2.2 IPCP: Event[Receive ConfReq-] State[REQsent to REQsent]
*Dec 19 04:08:21.500: Vi2.2 IPV6CP: I CONFREQ [UNKNOWN] id 1 len 14
*Dec 19 04:08:21.500: Vi2.2 IPV6CP:    Interface-Id 190B:5AB0:FDF3:9E21 (0x010A190B5AB0FDF39E21)
*Dec 19 04:08:21.500: Vi2.2 LCP: O PROTREJ [Open] id 2 len 20 protocol IPV6CP (0x01010010010A190B5AB0FDF39E21)
*Dec 19 04:08:21.500: Vi2.2 IPCP: I CONFACK [REQsent] id 1 len 10
*Dec 19 04:08:21.500: Vi2.2 IPCP:    Address 127.0.0.254 (0x03067F0000FE)
*Dec 19 04:08:21.500: Vi2.2 IPCP: Event[Receive ConfAck] State[REQsent to ACKrcvd]
*Dec 19 04:08:21.508: Vi2.2 IPCP: I CONFREQ [ACKrcvd] id 2 len 22
*Dec 19 04:08:21.508: Vi2.2 IPCP:    Address 192.168.0.64 (0x0306C0A80040)
*Dec 19 04:08:21.508: Vi2.2 IPCP:    PrimaryDNS 216.134.160.6 (0x8106D886A006)
*Dec 19 04:08:21.508: Vi2.2 IPCP:    SecondaryDNS 216.134.160.13 (0x8306D886A00D)
*Dec 19 04:08:21.508: Vi2.2 IPCP: O CONFACK [ACKrcvd] id 2 len 22
*Dec 19 04:08:21.508: Vi2.2 IPCP: Event[Receive ConfReq+] State[ACKrcvd to Open]
*Dec 19 04:08:21.516: Vi2.2 IPCP: State is Open
*Dec 19 04:08:21.516: Vi2.2 IPCP: Add link info for cef entry 192.168.0.64
*Dec 19 04:08:21.516: Vi2.2 Added to neighbor route AVL tree: topoid 0, address 192.168.0.64
*Dec 19 04:08:21.516: Vi2.2 IPCP: Route not installed to 192.168.0.64
*Dec 19 04:08:21.520: Vi2.2 IPCP: I TERMREQ [Open] id 3 len 34
*Dec 19 04:08:21.520: Vi2.2 IPCP: (0x556E617574686F72697A65642072656D)
*Dec 19 04:08:21.520: Vi2.2 IPCP: (0x6F74652049502061646472657373)
*Dec 19 04:08:21.520: Vi2.2 IPCP: Remove link info for cef entry 192.168.0.64
*Dec 19 04:08:21.520: Vi2.2 IPCP: O TERMACK [Open] id 3 len 4
*Dec 19 04:08:21.520: Vi2.2 IPCP: Event[Receive TermReq] State[Open to Stopping]
*Dec 19 04:08:21.520: Vi2.2 Deleted neighbor route from AVL tree: topoid 0, address 192.168.0.64
*Dec 19 04:08:21.520: Vi2.2 IPCP: Remove route to 192.168.0.64
*Dec 19 04:08:23.180: Vi2.1 LCP: Event[Timeout-] State[Stopping to Stopped]
*Dec 19 04:08:23.180: Vi2.1 LCP: Event[DOWN] State[Stopped to Starting]
*Dec 19 04:08:23.180: Vi2.1 PPP: Phase is DOWN
*Dec 19 04:08:23.180: [582]PPPoE 3587: State LOCALLY_TERMINATED    Event PPP DISCONNECT
*Dec 19 04:08:23.180: [582]PPPoE 3587: O PADT  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
         0E 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00
*Dec 19 04:08:23.180: [582]PPPoE 3587: Destroying  R:20aa.4b7d.7744 L:0009.b68b.f430 Gi1/2/0
*Dec 19 04:08:23.180: PPPoE: Returning Vaccess Virtual-Access2.1
*Dec 19 04:08:23.180: [582]PPPoE 3587: AAA get dynamic attrs
*Dec 19 04:08:23.180: [582]PPPoE 3587: AAA account stopped
*Dec 19 04:08:23.180: [582]PPPoE 3587: Segement (SSS class): UNBOUND
*Dec 19 04:08:23.180: [582]PPPoE 3587: Segement (SSS class): UNPROVISION
*Dec 19 04:08:23.436: Vi2.1 PPP: Free Context [51072F9C]
*Dec 19 04:08:23.532: Vi2.2 IPCP: Event[Timeout-] State[Stopping to Stopped]
Total sessions since last reload: 3613
Session Id: 4022
   Unique Id: 3603
   User Name: admin
   Idle Time: 0
   CT Call Handle: 0
Session Id: 4047
   Unique Id: 3623
   User Name: user1
   IP Address: 192.168.0.64
   Idle Time: 0
   CT Call Handle: 0
Cisco-10008#
Still dropping the session from what it looks like:
Total sessions since last reload: 3615
Session Id: 4022
   Unique Id: 3603
   User Name: admin
   Idle Time: 0
   CT Call Handle: 0
Session Id: 4051
   Unique Id: 3625
   User Name: user1
   IP Address: 0.0.0.0
   Idle Time: 0
   CT Call Handle: 0
Cisco-10008#
Brandon
Hello Brandon,
There is a series of puzzling facts depicted in this debug and preceding configuration.
  1. Your Loopback0 interface has no IP address configured, yet you are using that on the Virtual-Template1 in the ip unnumbered command. Assign an IP address to the Lo0 interface please.
  2. Your router appears to announce its own IP address of 127.0.0.254 to the PPPoE client. However, 127.0.0.254 is an internal loopback address that should never, ever, be used on a physical link. This may be related either to the missing IP address on the Lo0 interface, or to the fact that you have the IP routing deactivated. I strongly suggest activating the IP routing using the ip routing command - having an access concentrator for PPPoE sessions without IP routing enabled is highly irregular.
  3. The PPP link termination is caused by your router receiving the TERMREQ LCP command from the client. In essence, it is your client who requests the termination of the session, not your router. This may be related to you advertising the 127.0.0.254 address as your own address.
Can you implement the suggested changes and retest the behavior please? Thank you!
Best regards,
Peter
