PPPOE with multiple internal networks
KAZIM NAIM
Dear All
I need some support on following scenario
Cisco 1900 Router
eth0 as PPPOE - Nat and few port forwarding...
eth1 as LAN - 192.168.1.1 - Dhcp enabled
Above working currently
I have additional interface HWIC-2FE card
I want to setup as a separate internal network with dhcp nat and
port forward. internet will be eth0 PPPOE only
Kindly advise
kcnajaf
Level 7
Level 7
Hi Kazim,
This should be fine as far as I know. All you have to do is to enable ip nat inside on the new interface and include the new ip subnet on the NAT ACL.
Hope that helps.
Najaf
Please rate when applicable or helpful !!!
Thanks Najaf
can you brief a little bit please
