PPTP Clients unable to access the internet and Internal Network Resources
Robert Chan
Hey guys good afternoon need some assistance about this issue.
Trying to set up a PPTP Server, clients are able to authenticate to this network but unable to gain Internet Access and unable to reach internal network resources.
Please assist.
Configurations are below:
Building configuration...
Current configuration : 3668 bytes
! Last configuration change at 19:52:42 UTC Thu May 23 2019 by robert
version 15.3
hostname OGLE
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
vpdn enable
vpdn-group PPTP_SER
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
license udi pid CISCO1921/K9 sn FTX1703853R
license accept end user agreement
license boot module c1900 technology-package securityk9
license boot module c1900 technology-package datak9
license boot module c1900 technology-package NtwkEssSuitek9
username cisco password 0 cisco
redundancy
ip ssh version 2
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.4.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description INTERNET
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Virtual-Template1
ip unnumbered GigabitEthernet0/0
peer default ip address pool PPTP_Clients
no keepalive
ppp ipcp dns 8.8.4.4
ppp ipcp route default
interface Dialer1
ip address negotiated
ip mtu 1400
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1360
load-interval 30
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
ppp chap hostname XXXX
ppp chap password 0 XXXX
ip local pool PPTP_Clients 192.168.4.20 192.168.4.35
no ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 192.168.4.10 22 interface Dialer1 22
ip nat inside source static tcp 192.168.4.10 25 interface Dialer1 25
ip nat inside source static tcp 192.168.4.10 110 interface Dialer1 110
ip nat inside source static tcp 192.168.4.10 143 interface Dialer1 143
ip nat inside source static tcp 192.168.4.10 587 interface Dialer1 587
ip nat inside source static tcp 192.168.4.10 993 interface Dialer1 993
ip nat inside source static tcp 192.168.4.10 8081 interface Dialer1 8081
ip nat inside source static tcp 192.168.4.10 27015 interface Dialer1 27015
ip nat inside source static tcp 192.168.4.10 27018 interface Dialer1 27018
ip nat inside source static tcp 192.168.4.10 27020 interface Dialer1 27020
ip nat inside source static tcp 192.168.4.10 443 interface Dialer1 443
ip nat inside source list 10 pool PPTP_Clients overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit 192.168.4.0 0.0.0.255
access-list 110 permit ip any any
control-plane
line con 0
exec-timeout 0 0
logging synchronous
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 0 0
logging synchronous
login local
transport preferred ssh
transport input all
transport output all
line vty 5 15
exec-timeout 0 0
logging synchronous
login local
transport input all
scheduler allocate 20000 1000
end
5 Replies 5
make the changes marked in bold and check if that makes a difference:
no keepalive
--> no ppp ipcp route default
interface Dialer1
ip mtu 1400
ip nat outside
encapsulation ppp
load-interval 30
dialer pool 1
dialer persistent
dialer-group 1
-> no ip nat inside source list 10 pool PPTP_Clients overload
dialer-list 1 protocol ip permit
--> no access-list 110 permit ip any any
ok sure no problem i will configure make the changes and see if it will work
Please see these are the Debugs i am getting when i connect to the VPN router but still no internet access ?
OGLE(config)#
May 24 01:25:05.323: PPP: Alloc Context [27049BF4]
May 24 01:25:05.323: ppp3 PPP: Phase is ESTABLISHING
May 24 01:25:05.323: ppp3 PPP: Using AAA Unique Id = F
May 24 01:25:05.323: ppp3 PPP: Authorization required
May 24 01:25:05.323: ppp3 PPP: Using vpn set call direction
May 24 01:25:05.323: ppp3 PPP: Treating connection as a callin
May 24 01:25:05.323: ppp3 PPP: Session handle[FA000003] Session id[3]
May 24 01:25:05.323: ppp3 LCP: Event[OPEN] State[Initial to Starting]
OGLE(config)# PPP: No remote authentication for call-in
May 24 01:25:05.323: ppp3 PPP LCP: Enter passive mode, state[Stopped]
May 24 01:25:05.327: ppp3 LCP: I CONFREQ [Stopped] id 0 len 21
May 24 01:25:05.327: ppp3 LCP: MRU 1400 (0x01040578)
May 24 01:25:05.327: ppp3 LCP: MagicNumber 0x03C63476 (0x050603C63476)
May 24 01:25:05.327: ppp3 LCP: PFC (0x0702)
May 24 01:25:05.327: ppp3 LCP: ACFC (0x0802)
May 24 01:25:05.327: ppp3 LCP: Callback 6 (0x0D0306)
May 24 01:25:05.327: ppp3 LCP: O CONFREQ [Stop
OGLE(config)#ped] id 1 len 10
May 24 01:25:05.327: ppp3 LCP: MagicNumber 0xB7620A20 (0x0506B7620A20)
May 24 01:25:05.327: ppp3 LCP: O CONFREJ [Stopped] id 0 len 7
May 24 01:25:05.327: ppp3 LCP: Event[Receive ConfReq-] State[Stopped to REQsent]
May 24 01:25:05.331: ppp3 LCP: I CONFACK [REQsent] id 1 len 10
May 24 01:25:05.331: ppp3 LCP: MagicNumber 0xB7620A20 (0x0506B7620A20)
May 24 01:25:05.331: ppp3 LCP: Event[Receive ConfAck] State[REQsent to ACKrcv
OGLE(config)#d]
May 24 01:25:05.331: ppp3 LCP: I CONFREQ [ACKrcvd] id 1 len 18
May 24 01:25:05.331: ppp3 LCP: MRU 1400 (0x01040578)
May 24 01:25:05.331: ppp3 LCP: MagicNumber 0x03C63476 (0x050603C63476)
May 24 01:25:05.331: ppp3 LCP: PFC (0x0702)
May 24 01:25:05.331: ppp3 LCP: ACFC (0x0802)
May 24 01:25:05.331: ppp3 LCP: O CONFNAK [ACKrcvd] id 1 len 8
May 24 01:25:05.331: ppp3 LCP: MRU 1500 (0x010405DC)
May 24 01:25:05.331: ppp3 LCP: Event[Receive ConfReq-] State[ACKrcvd to ACKrcvd]
May 24 01:25
OGLE(config)#:05.331: ppp3 LCP: I CONFREQ [ACKrcvd] id 2 len 18
May 24 01:25:05.331: ppp3 LCP: O CONFNAK [ACKrcvd] id 2 len 8
OGLE(config)#P: I CONFREQ [ACKrcvd] id 3 len 18
May 24 01:25:05.335: ppp3 LCP: MRU 1500 (0x010405DC)
May 24 01:25:05.335: ppp3 LCP: MagicNumber 0x03C63476 (0x050603C63476)
May 24 01:25:05.335: ppp3 LCP: PFC (0x0702)
May 24 01:25:05.335: ppp3 LCP: ACFC (0x0802)
May 24 01:25:05.335: ppp3 LCP: O CONFACK [ACKrcvd] id 3 len 18
Ma
OGLE(config)#y 24 01:25:05.335: ppp3 LCP: ACFC (0x0802)
May 24 01:25:05.335: ppp3 LCP: Event[Receive ConfReq+] State[ACKrcvd to Open]
May 24 01:25:05.335: ppp3 LCP: I IDENTIFY [Open] id 4 len 18 magic 0x03C63476MSRASV5.20
May 24 01:25:05.335: ppp3 LCP: I IDENTIFY [Open] id 5 len 24 magic 0x03C63476MSRAS-0-RCKID-PC
May 24 01:25:05.335: ppp3 LCP: I IDENTIFY [Open] id 6 len 24 magic 0x03C63476\x-uA#xE')OA^-^b
May 24 01:25:05.335: ppp3 PPP: Queue IPV6CP code[1] id[7]
May 24 01:25:05.335: ppp3 PPP: Queue IPCP code[
OGLE(config)#1] id[8]
May 24 01:25:05.339: ppp3 PPP: No authorization without authentication
May 24 01:25:05.339: ppp3 PPP: Phase is FORWARDING, Attempting Forward
May 24 01:25:05.339: ppp3 LCP: State is Open
May 24 01:25:05.343: Vi2.1 PPP: Phase is ESTABLISHING, Finish LCP
May 24 01:25:05.343: Vi2.1 PPP: Phase is UP
May 24 01:25:05.343: Vi2.1 IPCP: Protocol configured, start CP. state[Initial]
May 24 01:25:05.343: Vi2.1 IPCP: Event[OPEN] State[Initial to Starting]
May 24 01:25:05.343: Vi2.1 IPCP: O CONFREQ [St
OGLE(config)#arting] id 1 len 10
May 24 01:25:05.343: Vi2.1 IPCP: Address 192.168.4.1 (0x0306C0A80401)
May 24 01:25:05.343: Vi2.1 IPCP: Event[UP] State[Starting to REQsent]
May 24 01:25:05.343: Vi2.1 PPP: Process pending ncp packets
May 24 01:25:05.343: Vi2.1 IPCP: Redirect packet to Vi2.1
May 24 01:25:05.343: Vi2.1 IPCP: I CONFREQ [REQsent] id 8 len 34
May 24 01:25:05.343: Vi2.1 IPCP: Address 0.0.0.0 (0x030600000000)
May 24 01:25:05.343: Vi2.1 IPCP: PrimaryDNS 0.0.0.0 (0x810600000000)
May 24 01:25:05.
OGLE(config)#343: Vi2.1 IPCP: PrimaryWINS 0.0.0.0 (0x820600000000)
May 24 01:25:05.343: Vi2.1 IPCP: SecondaryDNS 0.0.0.0 (0x830600000000)
May 24 01:25:05.343: Vi2.1 IPCP: SecondaryWINS 0.0.0.0 (0x840600000000)
May 24 01:25:05.343: Vi2.1 IPCP AUTHOR: Done. Her address 0.0.0.0, we want 0.0.0.0
May 24 01:25:05.343: Vi2.1 IPCP: Pool returned 192.168.4.11
May 24 01:25:05.343: Vi2.1 IPCP AUTHOR: no author-info for primary dns
May 24 01:25:05.343: Vi2.1 IPCP AUTHOR: no author-info for primary wins
May 24 01:25
OGLE(config)#:05.343: Vi2.1 IPCP AUTHOR: no author-info for seconday dns
May 24 01:25:05.343: Vi2.1 IPCP AUTHOR: no author-info for seconday wins
May 24 01:25:05.343: Vi2.1 IPCP: O CONFREJ [REQsent] id 8 len 16
May 24 01:25:05.343: Vi2.1 IPCP: PrimaryWINS 0.0.0.0 (0x820600000000)
May 24 01:25:05.343: Vi2.1 IPCP: Event[Receive ConfReq-] State[REQsent to REQsent]
May 24 01:25:05.343: Vi2.1 IPV6CP: Redirect packet to Vi2.1
May 24 01:25:05
OGLE(config)#.343: Vi2.1 IPV6CP: I CONFREQ [UNKNOWN] id 7 len 14
May 24 01:25:05.343: Vi2.1 IPV6CP: Interface-Id C451:720F:2FBF:A3BF (0x010AC451720F2FBFA3BF)
May 24 01:25:05.343: Vi2.1 LCP: O PROTREJ [Open] id 2 len 20 protocol IPV6CP (0x01070010010AC451720F2FBFA3BF)
May 24 01:25:05.347: Vi2.1 IPCP: I CONFACK [REQsent] id 1 len 10
May 24 01:25:05.347: Vi2.1 IPCP: Address 192.168.4.1 (0x0306C0A80401)
May 24 01:25:05.347: Vi2.1 IPCP: Event[Receive ConfAck] State[REQsent to ACKrcvd]
OGLE(config)#IPCP: I CONFREQ [ACKrcvd] id 9 len 22
May 24 01:25:05.347: Vi2.1 IPCP: Address 0.0.0.0 (0x030600000000)
May 24 01:25:05.347: Vi2.1 IPCP: PrimaryDNS 0.0.0.0 (0x810600000000)
May 24 01:25:05.347: Vi2.1 IPCP: SecondaryDNS 0.0.0.0 (0x830600000000)
May 24 01:25:05.347: Vi2.1 IPCP AUTHOR: no author-info for primary dns
May 24 01:25:05.347: Vi2.1 IPCP AUTHOR: no author-info for seconday dns
May 24 01:25:05.347: Vi2.1 IPCP: O CONFNAK [ACKrcvd] id 9 len 22
OGLE(config)# 192.168.4.11 (0x0306C0A8040B)
May 24 01:25:05.347: Vi2.1 IPCP: PrimaryDNS 8.8.4.4 (0x810608080404)
May 24 01:25:05.347: Vi2.1 IPCP: SecondaryDNS 190.80.2.125 (0x8306BE50027D)
May 24 01:25:05.347: Vi2.1 IPCP: Event[Receive ConfReq-] State[ACKrcvd to ACKrcvd]
May 24 01:25:05.351: Vi2.1 IPCP: I CONFREQ [ACKrcvd] id 10 len 22
May 24 01:25:05.351: Vi2.1 IPCP: Address 192.168.4.11 (0x0306C0A8040B)
May 24 01:25:05.351: Vi2.1 IPCP: PrimaryDNS 8.8.4.4 (0x810608080404)
OGLE(config)#IPCP: SecondaryDNS 190.80.2.125 (0x8306BE50027D)
May 24 01:25:05.351: Vi2.1 IPCP AUTHOR: no author-info for primary dns
May 24 01:25:05.351: Vi2.1 IPCP AUTHOR: no author-info for seconday dns
May 24 01:25:05.351: Vi2.1 IPCP: O CONFACK [ACKrcvd] id 10 len 22
May 24 01:25:05.351: Vi2.1 IPCP: SecondaryDNS 190.80.2.125 (0x8306BE50027D)
May 24 01:25:05.35
OGLE(config)#1: Vi2.1 IPCP: Event[Receive ConfReq+] State[ACKrcvd to Open]
May 24 01:25:05.371: Vi2.1 IPCP: State is Open
May 24 01:25:05.371: Vi2.1 IPCP: Install default route thru 192.168.4.11
May 24 01:25:05.371: Vi2.1 IPCP: Install route to 192.168.4.11
Please see i have made some additional changes to my configuration at my home network but no luck, i tested it out to see if this would work on a LAN with a regular client PC trying to authenticate to it.
Please see below, Please let me know if any additional information of changes is needed.
Current configuration : 2324 bytes
! Last configuration change at 01:32:30 UTC Fri May 24 2019
! NVRAM config last updated at 01:32:34 UTC Fri May 24 2019
version 15.0
hostname OGLE
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.4.1 192.168.4.5
ip dhcp pool LAN
network 192.168.4.0 255.255.255.0
default-router 192.168.4.1
dns-server 8.8.8.8
domain-name XXX
ip domain name XXX
vpdn enable
vpdn-group PPTP_SERVER
accept-dialin
protocol pptp
virtual-template 1
l2tp tunnel timeout no-session 15
license udi pid CISCO1921/K9 sn FGL152524WJ
redundancy
interface Loopback1
description LAN
ip nat inside
ip address dhcp
ip nat outside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
description PPTP_CLIENTS D/GATEWAY
ip unnumbered Loopback1
ip nat inside
no keepalive
ppp ipcp address accept
ip local pool PPTP_Clients 192.168.4.10 192.168.4.35
no ip http server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
control-plane
line con 0
exec-timeout 0 0
logging synchronous
login local
line aux 0
line vty 0 4
exec-timeout 0 0
logging synchronous
login local
transport input all
line vty 5 15
exec-timeout 0 0
logging synchronous
login local
transport input all
end
try and bind a 'real' interface to the Virtual Template rather than the loopback:
ip nat inside
duplex auto
speed auto
ip unnumbered GigabitEthernet0/1
ip nat inside
no keepalive
