Preemption in HSRP
vishweswaran
Can anyone brief me about how preemption works in HSRP ???
Thanks in advance :-)
The basic behavior in HSRP is that once a router has become the active HSRP device it will continue as active even if some other device obtains a priority that is higher than the currently active device. Use of preemtion allows a device whose priority has become higher to take over the role as the active router in HSRP.
Rick
Rick
andrew.prince
Level 10
Level 10
read the below web page
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_q_and_a_item09186a00800a9679.shtml#q6
Rick
Rick
