LEDs for a DSL interface on a cisco 2921 router
I'm dealing with a 2921 router, a VDSL2 HWIC card, and a DSL line. Currently the line is connected to a modem which is connected to the router via ethernet and it all works fine.
I'm trying to use the HWIC card to connect directly with the service provider avoiding the modem.
The configuration on the router is ready but I think that's not the issue right now.
Just to clarify this: I did use the "no shutdown" command at the interface, and it works fine while connected to the modem so the line is powered on for sure.
First I connect the line to the router.
Then wait for a while (even more than 2 minutes).
Run the "show ip interface brief" command, and the interface still shows with the Status = Down; Line protocol = Down.
I'm thinking may be there is something wrong with the card, the LEDs at any time are:
  • EN = solid green.
  • CD = blinking green.
  • LP = turned off.
It doesn't matter wheter I connect or disconnect the line, turn on or off the interface, these LEDs remain that way.
Is there something wrong with the interface? or it might be possible that the line turns off when connect it to my router and then detect when I re-connect it to the modem so it turns on again (Highly doubt it).
Thanks in advanced for any help.
Regards.
12 Replies 12
paolo bevilacqua
You can not connect a VDSL2 HWIC to an ADSL circuit. it will not work, and there is no way or configuration that will make it work.
http://www.cisco.com/en/US/prod/collateral/routers/ps10536/data_sheet_c78-584157_ps10536_Products_Data_Sheet.html
You need HWIC-1ADSL for ADSL or ADSL2 or ADSL2+ circuit.
Sorry, I'm not really sure what type of interface I have, but I have a similar card already working with another ISP line.
How can I look in the router the type of interface I have?
I found only this info, not sure if it helps:
Router#show version
2 DSL controllers
2 ATM interfaces
Router#show controllers atm0/1/0
Interface: ATM0/1/0, Hardware: MPC ATMSAR, State: administratively down
IDB: 0x2ABBD09C  Instance: 0x30842D1C  PHY Inst: 0x00000000  us_bwidth: 1024
Slot:    0         Unit:     1         pkt Size: 4528
Sar ctrl queue: max depth = 0, current queue depth = 0,
                drops = 0, urun cnt = 0, total cnt = 0
VC TX ring stats:
VCD  VPI  VCI  High_Watermark  Low_Watermark  Queue_Depth
VC QoS Summary
  Active            Scheduled
VCD VPI VCI  COS ST     COS       PCR  SCR/MCR
OAM statistics (vcd/count/drop)
1/0/0  2/0/0  3/0/0  4/0/0
Misc Oam Drops: 0
ATM Encap Mapping
                                                Tx Congestion
Entry MAC address    VPI/VCI   VCD sts       set        clr     fastsend   safestart    drops
Router#show ip interface brief
ATM0/0/0                   unassigned      YES NVRAM up                    up
ATM0/0/0.1                 unassigned      YES unset  up                    up
ATM0/1/0                   unassigned      YES NVRAM  down down
ATM0/1/0.1                     YES manual down down
The last command shows that atm0/0/0 is already working (with an ISP1) while atm0/1/0 (with ISP2) doesn't.
Thanks.
You can known what you have reading the interface label, or doing "show diag"
Please post the output to the command "sh inventory".
Router# show diag
WIC Slot 1:
HWIC MULTI VDSL over POTS
Hardware Revision        : 1.0
Top Assy. Part Number    : 800-34635-01
Part Number              : 73-13372-02
Board Revision           : A0
Deviation Number         : 0
Fab Version              : 02
PCB Serial Number        : FOC15263F4N
RMA Test History         : 00
RMA Number               : 0-0-0-0
RMA History              : 00
Product (FRU) Number     : EHWIC-VA-DSL-A
Version Identifier       : V01
CLEI Code                : COUIA8YCAA
EEPROM format version 4
EEPROM contents (hex):
  0x00: 04 FF 40 07 1B 41 01 00 C0 46 03 20 00 87 4B 01
  0x10: 82 49 34 3C 02 42 41 30 88 00 00 00 00 02 02 C1
  0x20: 8B 46 4F 43 31 35 32 36 33 46 34 4E 03 00 81 00
  0x30: 00 00 00 04 00 CB 92 45 48 57 49 43 2D 56 41 2D
  0x40: 44 53 4C 2D 41 00 00 00 00 89 56 30 31 20 D9 02
  0x50: 40 C1 C6 8A 43 4F 55 49 41 38 59 43 41 41 FF FF
  0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Router# show inventory
NAME: "ADSL/VDSL over POTS supporting ADSL1, ADSL2, ADSL2+ and VDSL2 on Slot 0 SubSlot 1", DESCR: "ADSL/VDSL over POTS supporting ADSL1, ADSL2, ADSL2+ and VDSL2"
PID: EHWIC-VA-DSL-A    , VID: V01 , SN: FOC15263F4N
I hope that can help you to help me
Regards.
Ok, can you please post relevant configuration now.
Router# show run interface a0/1/0.1
interface ATM0/1/0.1 point-to-point
ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
pvc 0/33
  encapsulation aal5snap
end
That was working with another line weeks ago, I understand it doesn't necessarily means it has to work now. However, as I said before, the interface is showing a "Status = down" (no shutdown command already set), so I don't think the interface configuration is relevant since the problem should be still at layer 1.
Could it be possible that the interface card is damaged? how could I check that?
Can you please post all the relevant configuration, that includes
controller vdsl 1
and
interface atm0/1/0
Router#sh controllers a0/1/0
Interface: ATM0/1/0, Hardware: MPC ATMSAR, State: down
VC TX ring stats:
VC QoS Summary
  Active            Scheduled
Misc Oam Drops: 0
ATM Encap Mapping
                                                Tx Congestion
Router# sh int a0/1/0
ATM0/1/0 is down, line protocol is down
  Hardware is MPC ATMSAR, address is 2c3f.382f.13f6 (bia 2c3f.382f.13f6)
  MTU 1600 bytes, sub MTU 1600, BW 1024 Kbit/sec, DLY 360 usec,
  Encapsulation ATM, loopback not set
  Keepalive not supported
  Encapsulation(s): AAL5
  4 maximum active VCs, 1024 VCs per VP, 0 current VCCs
  VC Auto Creation Disabled.
  VC idle disconnect time: 300 seconds
  Last input never, output 1w0d, output hang never
  Queueing strategy: Per VC Queueing
     3 packets input, 584 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     767 packets output, 51375 bytes, 0 underruns
     0 output errors, 0 collisions, 16 interface resets
     0 unknown protocol drops
Router#sh int a0/1/0.1
ATM0/1/0.1 is down, line protocol is down
  Internet address is
  MTU 1600 bytes, BW 1024 Kbit/sec, DLY 360 usec,
  Encapsulation ATM
     3 packets input, 572 bytes
     0 OAM cells input, 0 OAM cells output
  AAL5 CRC errors : 0
  AAL5 SAR Timeouts : 0
  AAL5 Oversized SDUs : 0
I forgot the VDSL controller:
Router# show controllers VDSL0/1/0
Controller VDSL 0/1/0 is DOWN
Daemon Status:           Establishing Link
                        XTU-R (DS)              XTU-C (US)
Chip Vendor ID:         'BDCM'                   'IFTN'
Chip Vendor Specific:   0x0000                   0x71B9
Chip Vendor Country:    0xB500                   0xB500
Modem Vendor ID:        'CSCO'                   '    '
Modem Vendor Specific:  0x4602                   0x0000
Modem Vendor Country:   0xB500                   0x0000
Serial Number Near:    FOC15263F4N 2921/K9  15.1(4)M
Serial Number Far:
Modem Version Near:    15.1(4)M
Modem Version Far:     0x71b9
Modem Status:            Idle
DSL Config Mode:         AUTO
Trained Mode:
TC Mode:                 ATM
Selftest Result:         0x00
DELT configuration:      enabled
DELT state:              successful
Trellis:                 ON                       ON
Full inits:             1
Failed full inits:      1
Short inits:            0
Failed short inits:     0
Firmware        Source          File Name (version)
VDSL            embedded        VDSL_LINUX_DEV_01212008 (1)
Modem FW  Version:      110506_1916-4.02L.03.A2pv6C032b.d23i
Modem PHY Version:      A2pv6C032b.d23i
Training Log :  Stopped
Training Log Filename : flash:vdsllog.bin
Can you try
controller vdsl 1
mode adsl
or adsl2, adsl2+ depending from your circuit.
Also, can you try updating DSL firmware to
vdsl.bin-A2pv6C035d_d23j
that is available under downloads for 887VA. Note you may need to contact the TAC to obtain this file.
Thank you very much for the help, it may take a while to try this (a few days) but I'll be comming back here, hopefully to confirm that was the solution.
Thanks again and see you soon,
Ricardo.
