Prefer Default Route over OSPF
himanshudwivedi
Consider below topology, in which there are 3 Routers.
1. R1 and R2 are connected and default router is configured on both the routers towards each other.
2. R1 and R3 are connected and OSPF is configured on both the routers and
3. R2 and R3 are connected to each other. Static route for R3 Subnet are configured on R2 and Default router is configured on R3 towards R2.
When I am checking the tracroute from Users connected to R3 it is going directly via OSPF. Means Directly going R3 - > R1, but customer wants that Traffic should routed like R3 -> R2 -> R1 and vice versa, means it should prefer default Route from R3->R2 and OSPF R3->R1 will be the backup path. How can I achieve.
All the configuration are attached.
Jon Marshall
The most specific prefix in the routing table is always used so you either need to run OSPF between R2 and R3 and manipulate the metrics or you need to use PBR.
Note you would probably need PBR both ways to ensure the return traffic went the same way.
Jon
Jon Marshall
Jon
Applied PBR and it working fine now.
