Prefix-list question
acbennyma
Hi expert,
How can I count the actual IP range of below prefix list
ip prefix-list abc seq 10 deny 10.100.64.0/18 ge 24
ip prefix-list abc seq 20 permit 10.100.0.0/16 ge 24
ip prefix-list abc seq 30 deny 10.100.0.0/14 ge 16
ip prefix-list abc seq 40 deny 10.104.0.0/13 ge 16
ip prefix-list abc seq 50 deny 10.112.0.0/13 ge 16
ip prefix-list abc seq 100 permit 0.0.0.0/0 le 32
5 Replies 5
Not sure what your question is.
You have a list of prefix lists each one with different instructions.
You want to know which IP ranges are matched by the permit statements? Please clarify.
Federico.
Yes, you are right
Thank you!
ip prefix-list abc seq 10 deny 10.100.64.0/18 ge 24 is matching any prefix within 10.100.64.0/18 (=10.100.64.0 - 10.100.127.255) but the prefix mask length must be greater or equal /24. Which means 10.100.66.0/24 is matched, but 10.100.66.0/23 is not, e.g.
The deny keyword is inverting the prefix acceptance logic though, i.e., the matching prefixes are being dropped by the router.
ip prefix-list abc seq 20 permit 10.100.0.0/16 ge 24 is matching any prefix within 10.100.0.0/16 (=10.100.0.0 - 10.100.255.255) but the prefix mask length must be greater or equal /24.
For
the logic is similar to the first line.
ip prefix-list abc seq 100 permit 0.0.0.0/0 le 32 is matching any prefix.
BR,
Milan
Hi ,
For ip prefix-list abc seq 10 deny 10.100.64.0/18 ge 24, is it means that
Within the IP range  10.100.64.0 - 10.100.127.255
if route is 10.100.64.0 /24, then is match and will be dropped
if route is 10.100.65.0/ 24, then is match and will be dropped
if route is 10.100.67.0/ 26, then is match and will be dropped
if route is 10.100.64.0/ 22, then is not match and will not dropped
if route is 10.100.72.0/ 22, then is not match and will not dropped
yes, correct.
This line does not match it.
The final dropping/accepting depends on the following prefix-list lines finally.
BR,
Milan
