Prepending specific subnets
jradke
I am trying to prepend specific subnets that I am advertising. What is the best method to do this with these 3 options? Basic route-maps, route-maps with continue statements, or route-map with policy lists. What other valid options do I have?
Will this work with basic route-maps?
Route-map continue command? It is only supported on a few versions of IOS all of which I?m not currently running.
http://tinyurl.com/ybwh9a
Policy list? Kinda confusing with Cisco?s statement that ?Policy lists support only match clauses and do not support set clauses. However, policy lists can coexist, within the same route map entry, with match and set clauses that are configured separately from the policy lists.?
http://tinyurl.com/yyt2on
Any suggestions are appreciated, thanks!
-JGR
network.king
Level 4
Level 4
If you want to have a simple and clear configuration , then it would be better to go with a route-map .
As we have many features available with the route-map and your requirement is only for matching some specific subnets , it would be better to use the route-map , so that during troubleshooting time also you will not have mcuh to check.
Hope this helps
regards
vanesh k
Route map is the best option here as it offers you lot of features.
sample config in which u advertise one subnet with prepend
router bgp 100
network 10.10.10.0 mask 255.255.255.0
network 20.20.20.0 mask 255.255.255.0
neighbor 1.1.1.1 remote-as 200
neighbor 1.1.1.1 route-map map1 out
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 2 permit 20.20.20.0 0.0.0.255
route-map map1 permit 10
match ip address 2
set as-path prepend 100 100 100 100 100
route-map map1 permit 20
match ip address 1
HTH, rate if it does
Narayan
