Preventing 2 different NAT instances from hopping across public interfaces
packetfish
PROBLEM:
A subnet NAT'ing out DSL occasionally ends up going across another public and then out on the internet in a
set up with 2 differing private subnets that each NAT out each of their own public interfaces.
DETAILS:
For sake of example:
Outside Interfaces:
DSL: 1.1.1.1, next-hop indicated in route table 5.5.5.5
Bonded Multilink: 2.2.2.2, next-hop 3.3.3.3
Inside Interfaces:
Eth1: 6.6.6.6/24 (Hardwired LAN)
Eth2: 7.7.7.7/24 (Wifi)
CONFIG:
ip route 0.0.0.0 0.0.0.0 Multilink1
ip route 0.0.0.0 0.0.0.0 Dialer0
ip nat inside source route-map nonat Multilink 1 overload
ip nat inside source list 1 Dialer0 overload
route-map nonnat = 6.6.6.6/24 (Hardwired LAN) permited to NAT, and a VPN subnet (not listed excluded from NAT) that is excluded from NAT
list 1 = 7.7.7.7/24 (Wifi)
Things I've tried that didn't work to effectively fully segment the NAT instances...
- setting next-hop in a route-map
- inserting Null routes so the proper route gets picked up out of the translation table and doesn't get to
its NAT interface only to hop over and out another public interface.
*I think setting next-hop on my DSL doesn't work because of the setup bridging-wise on the ISP side
Appreciate any help. I'm sure its some minor little oversight, but my main issue is simply to just have
wifi NAT out DSL only, no hopping over and out via another public and vice-versa.
12 Replies 12
Edison Ortiz
Configure PBR (Policy Based Routing):
ip access-list standard wifi
permit [wifi subnet]
ip access-list standard dsl
permit [everyone else]
route-map internet permit 10
match ip address wifi
set interface dialer0
route-map internet permit 20
match ip address dsl
set interface Multilink 1
at the ingress interface on the router
interface fx/x
ip policy route-map internet
HTH,
__
Edison.
Thanks much Edison. I will try this towards the end of the day when the office thins out. Good to know I wasn't too far off base. I was setting next-hop which didn't seem to want to work.
I will report back on how things turned out.
It worked beautifully to stop my hopping across public but with one caveat. It more or less broke my VPN. For some reason I could not pass about every other packet in a ping.
So I added a route for the VPN network to get it to work and it seemed like it did, but now its not again. Its very random in terms of passing packets reliably.
Suggestions appreciated.
Please post config.
I will as soon as I have 5 seconds.... I'm sure it will help to see the 'actual' config.
Thanks for your patience and assistance.
The config below works as far as keeping NAT instances from hopping over and out another public once
they get to their NAT outside interface, however it breaks access to other local subnets connected the
router for ANY interface with ip policy applied. It also causes about 50% or more packet loss across my VPN tunnel.
Hopefully I didn't leave anything out that is applicable to review, which I sincerely appreciate.
Assume for my example, our subnet we hit via VPN is 8.8.0.0/16, and again 2.2.2.2 is my Multilink IP which
my tunnel is set up on.
It might be as simple as adding a few routes or some minor ACL tweaks but have not been able to do
much more testing since I have a full office of people using the network.
ip dhcp pool LAN-USERS
network 6.6.6.0 255.255.255.0
dns-server 6.6.6.1
default-router 6.6.6.1
ip dhcp pool WIRELESS-USERS
network 7.7.7.0 255.255.255.0
dns-server 7.7.7.1
default-router 7.7.7.1
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key address
crypto ipsec transform-set MY-transform-set esp-3des esp-md5-hmac
crypto map MY-tunnel-515e 10 ipsec-isakmp
set peer
set transform-set MY-transform-set
match address 110
interface Multilink1
description BONDED 2xT1
ip address 2.2.2.2 255.255.255.252
ip access-group 120 in <-to block port scans
ip nat outside
ip virtual-reassembly
rate-limit input access-group 105 256000 65536 65536 conform-action set-prec-transmit 5 exceed-action set-prec-continue 5
ip route-cache flow
no ip mroute-cache
ppp multilink
ppp multilink fragment disable
ppp multilink group 1
service-policy output policy1
interface FastEthernet0/0
description LAN-USERS
ip address 6.6.6.1 255.255.255.0
ip nat inside
no ip route-cache cef
ip route-cache flow
ip policy route-map NAT-CNTRL
no ip mroute-cache
duplex full
speed 100
interface Dialer0
description DSL
bandwidth inherit
ip address negotiated
ip nat outside
no ip virtual-reassembly
encapsulation ppp
ip route-cache flow
no ip mroute-cache
dialer pool 1
ppp pap sent-username password 0
interface FastEthernet0/1
description WIRELESS-USERS
ip address 7.7.7.1 255.255.255.0
ip nat inside
ip route-cache flow
no ip mroute-cache
duplex full
speed 100
!! VOIP/PBX COMES IN VIA HERE FROM
!! A 16 PORT PoE module
interface GigabitEthernet1/0
description RTR-to-SW-Interconnect
ip address 255.255.255.252
ip nat inside
ip route-cache flow
no ip mroute-cache
ip classless
ip route 6.6.6.0 255.255.255.0 FastEthernet0/0
ip route 7.7.7.0 255.255.255.0 FastEthernet0/1
ip route 255.255.255.0
ip nat inside source list LAN-MULTI interface Multilink1 overload
ip nat inside source list WIFI-DSL interface Dialer0 overload
ip nat inside source static udp 5060 interface Loopback66 5060
ip nat inside source static tcp 5060 interface Loopback66 5060
ip access-list standard WIFI-DSL
permit 7.7.7.0 0.0.0.255
ip access-list extended LAN-MULTI
deny ip 6.6.6.0 0.0.0.255 8.8.0.0 0.0.255.255
permit ip 6.6.6.0 0.0.0.255 any
permit ip host any
deny ip any any
access-list 110 remark CRYPTO-list for VPN-office-tunnel-Serial
access-list 110 permit ip host 2.2.2.2 host
access-list 110 permit ip 6.6.6.0 0.0.0.255 8.8.0.0 0.0.255.255
route-map NAT-CNTRL permit 10
match ip address WIFI-DSL
set interface Dialer0
route-map NAT-CNTRL permit 20
match ip address LAN-MULTI
set interface Multilink1
If you have other networks in addition to 6.6.6.0/24 sitting behind this router, you need to add then in the LAN-MULTI ACL with a deny statement similar to deny ip 6.6.6.0 0.0.0.255 8.8.0.0 0.0.255.255
__
Edison.
Edison:
You are a gentleman and a scholar. I got everything working exactly as planned this weekend based on your initial post. Just was a little rusty on policy routing, and a few things gave me grief in terms of the right combo of routes and policy statements.
Thanks for your help!
Glad to be of help and remember to rate helpful posts :)
__
Edison.
By setting interface I now also effectively break routing between my internal subnets. My goal was only to isolate the NAT instances so one inside subnet doesn't get to its public only to hop over to the other public out the other link, not make it so internal subnets can't reach each other.
Is it impossible for me to isolate 2 NAT instances and still be able to do that?
Thanks again.
You can add the internal src/dst networks in the route-map as a deny hence they won't be affected by the PBR.
Posting the config will also help.
Mohamed Sobair
Level 7
Level 7
As Edison pointed out, Denying the Crybto-list in the access-list of the route-map should prevent your VPN from going through The PBR process twards the internet or being droped.
Route-map name
match ip add 100
set int dialer 0
route-map name
match ip add 101
set int multilink1
access-list 100 deny (Your Local VPN subnet) (Your Remote VPN subnet)
access-list 100 permit ip (Desired 1st Lan subnet any)
access-list 101 deny (Your Local VPN subnet) (Your Remote VPN subnet)
access-list 101 permit ip (Desired 2nd lan any).
Mohamed
