priority of hsrp
anitachoi3
I enable the HSRP on two switches. the config are
!switch1
hostname hkgw01
interface GE 1/0/23
switchport mode trunk
interface vlan10
ip address 192.168.10.1 255.255.255.0
standby 1 ip address 192.168.10.10
standby 1 priority 300
standby 1 preempt
standby 1 track GE 1/0/23 5
!switch2
hostname hkgw02
interface GE 1/0/23
interface vlan10
ip address 192.168.10.2 255.255.255.0
standby 1 priority 290
standby 1 preempt
For normal condition, the hkgw01 is active for vlan 10. If the interface GE 1/0/23 of hkgw01 is down. the priority of hkgw01 should be 300 - 5 = 295. hkgw01 is still the active router.
I have two approaches to solve it, not sure which one is better. please advice.
first approach
- change the config of hkgw01 to "standby 1 track GE 1/0/23"
second approach
- change the config of hkgw01 to "standby 1 track GE 1/0/23 30"
rdgs
2 Accepted Solutions
mahmoodmkl
Level 7
Level 7
The second approach will be fine and work.
Mahmood
Giuseppe Larosa
Hello Anita,
to take advantage of tracking is enough to have a difference in HSRP priorities less then the tracking decrement.
To be noted that maximum configurable priority should be 255.
Hope to help
Giuseppe
mahmoodmkl
Level 7
Level 7
Mahmood
Giuseppe Larosa
Hello Anita,
Hope to help
Giuseppe
