Bookmark
Subscribe
1310
Priority QoS
gaurav.prakash
1. In absence of congestion on interface , does the queueing works or not, evening bandwitdh & priority command is used ?
2. Can the default traffic classes (other than Priority class) use the unused bandwidth of Priority class any any situation..
policy-map TESTKING
class Management
bandwidth percent 5
set ip dscp af41
class Premium
priority percent 50
set ip dscp ef
class class-default
bandwidth percent 45
random-detect
set ip dscp default
int s0/0
max-resv band 100
servicepolicy output TESTKING
Gaurav Prakash
5 Replies 5
pkhatri
Level 11
Level 11
1. No, there is no need for queueing and so, the bandwidth and priority commands do not come into play.
2. Yes. You can assign a bandwidth statement to the default-class but you cannot assign a priority statement. If there is spare bandwidth available, the default class can certainly use it.
Pls do remember to rate posts.
Paresh
Then whats the difference between priority command & bandwidth command. I know many people speak the same thing as u. This is the line from ciscopress BCRAN CCNP EXAM Certf guide
Here is the link plz go through it. Its short..
http://www.ciscopress.com/articles/article.asp?p=102233&seqNum=5
Please reply after investigation..
Thanks friend
Gaurav
both commands will create software queues in a router. The software queueing is only involved, if the hardware queue on an interface is full. In other words: unless you overload an interface there is NO software queueing involved at all. This includes "priority" and "bandwidth".
The priority command will create a strict priority queue. This means packets classified into this queue are serviced immediately before all other packets - thus low latency. There is however an upper limit established through a policer that is automatically enabled with the priority command.
The "bandwidth" command will create a software queue, which will be serviced at least with the configured bandwidth.
So in brief with an example:
priority 30 => low latency queue with a policer at 30 kbps
bandwidth 30 => normal queue with a minimum guaranteed bandwidth of 30 kbps
Hope this helps! Please rate all posts.
Regards, Martin
Then it looks the lines from CIsco book the link given above is not correct bcoz it says even if interface is not busy "Priority" command reserves the bandwidth.
Do you have any document whcih explains your point
just one remark: "reserves the bandwidth" does not mean "blocks the bandwidth". It means once the traffic requests the bandwidth, it will get it. However other traffic can use the bandwidth if it is not needed by the priority class.
You might want to read through: "Comparing the bandwidth and priority Commands of a QoS Service Policy" at
http://www.cisco.com/en/US/tech/tk543/tk757/technologies_tech_note09186a0080103eae.shtml
Hope this helps! PLease rate all posts!
Reagrds, Martin
