priority queue packet varification
muhammad ismail
hi,
can any one tell me any command that shows this much traffic has entered the priority queue on a router. i have done following configuration and used following portion but i am not able to see packets incrementing if i ping with the source allowed in the ACL 1.
class-map match-all out
match access-group 1
policy-map out
class out
priority percent 20
int fa0/0
service policy output out
sh polict-map output out
6 Replies 6
John Blakley
Muhammad,
Try changing your class map to match-any and see if that helps. You'll have to remove the class from the policy and delete and reconfigure the class:
policy-map out
no class out
no class-map out
class-map match-any out
policy-map out
class out
priority percent 20
Also, please post the acl 1....
HTH,
John
* Edit * I labbed this the way that you have it and it's matching packets....so, no need to change your match statement. In the acl I used though, I only put "permit ip any any" to see if I would get counters at all. If you're sourcing from an address and your acl points to a specific port, your ping won't register the hit on the policy. I'm speculating, of course...
HTH, John *** Please rate all useful posts ***
Hi muhammad,
Locally generated packets are always process-switched and are delivered first to the L3 queue before they are passed on to the interface driver.
Please read the next link, provides exactly the answer that you need
http://www.cisco.com/en/US/tech/tk543/tk760/technologies_tech_note09186a0080108e2d.shtml
You should check the  line with the 2812 packets (second line)
The line provides the number of packets which match the criteria of the class.
This counter increments whether or not the interface is congested.
The highlited two lines refer to the next
The number of packets which match the criteria of the class when the interface was congested.
In other words, the interface transmit ring was full, and the driver and the L3 processor system
worked together to queue the excess packets in the L3 queues, where the service policy applies.
Takei into consideration also the next in order to increase the accurassy of the counters.
Use the load-interval command to change this value and make it a more instantaneous value. The lowest value is 30 seconds; however, statistics displayed in the show policy-map interface output are updated every 10 second
Finally, the name of the service policy that you apply is output but the name of the policy in the config is out.
You should correct this in your config.
I hope that this answered your question.
Vasilis
i have ammeded the configuration and added the acl for reference but issue not resolved. Here is the topolgy i ping from R1 to R3 Loopback. QOS applied to R2 int fa0/1
R2#
access-list 1 permit 172.16.1.1
class-map class-map out
policy-map out
class out
priority percent 20
int fa0/0
sh polict-map int fa0/1
Hi again,
If you read the previous link this counter shows the number of packets which match the criteria of the class when the interface is congested.
Is your interface congested in order to show the packets generated by R1?
Vasilis
well Vasileios is right the interface is not congested how can we make one in this scenario.
You can flood the link with traffic if you can use applications such as WAN killer of Solarwind.
If this is not possible, you can generate high volume of traffic by pinging on the same time via an other terminal the same destination IP with timeout zero or with large packet size.
Then check again the policy interface.
Pay atention, these actions may increase the CPU of the router.
I recommend to decrease the allocated bandwidth to the interface in order to congest it easier.
Vasilis
