Privilege issue on "show running-config" on Cisco 3925
vkhorasani
hi guys
I've recently encounter a problem in defining privilege level on Cisco 3925 router.
I have defined a root user before with full permission(privilege level 15) but now I wanna define a new user with more restricted permission, but I'wanna let the new user to check the running-config.
here is my configuration:
R3925(config)#username admin privilege 10 secret 4 04CP9hzO5lEnKMbmI1Hi/2DbIkLZMrIH/BfUOrdBL62
R3925(config)#privilege exec level 10 show running-config
R3925(config)#privilege exec all level 10 show running-config
But everytime I login with "admin" user I can not check running-config, the CLI doesn't turn back any error but I can not see anything.
R3925#show running-config
R3925#
16 Replies 16
antilope1
Only to say you that Cisco IOS privileges are configured in such a way that a user with no permission to configure, any with level below 15, cannot see the configuration. I mean, if you cannot configure sthing, you cannot see it. This document explains it:
http://www.cisco.com/en/US/partner/tech/tk59/technologies_tech_note09186a00800949d5.shtml
There are a lot of cases like this one:
https://supportforums.cisco.com/discussion/9865061/privilege-command-show-run-does-not-show-running-config
and more.
Bye.
nspasov
There isn't an easy way to get "show run" to work on any other privilege level. An easier way is to go this route:
ciscorouter(config)# privilege exec all level 3 show running-config
ciscorouter# show running-config view full
Thank you for rating helpful posts!
Hello Neno,
Thank you for your answer but I have tried what you have said and it does not run. I only have been able to configure:
ciscorouter(config)# privilege exec level 3 show running-config
In fact, I can create views, but if I access any view different from root view, I cant execute next command:
So the result is I cannot see the configuration without permission from level 15.
Thank you anyway!
Hello Aurora. I just tested this again and it works just fine. In your configuration example though you are missing a key word "all" from your syntax.
You have:
But you need:
Give that a try and let me know if it is still not working.
Hi Neno,
Thank you for answer me again and trying it. I can't introduce "all" in the command and I can't execute
from any view except from the root view.
In conclusion, I can't see all the conf except being root or priv level 15 user.
Could you send me the rest of configuration, just if you want?
Anyway, thanks again. I suppose it will run but not in my case.
What version of code are you running? I tested this in my 3560 switch and a 1921 router and I definitely have the "all" option:
NS-1921(config)#privilege exec ?
  all    All suboption will be set to the samelevel
  level  Set privilege level of command
  reset  Reset privilege level of command
The "all" keyword is needed so that the sub-option commands will be set to the same privilege level.
Here is what I did to test this:
aaa new-model > > > This is a mandatory command for aaa related commands
username level3 privilege 3 password level3  > > > This is my priv-level-3 test account
privilege exec all level 3 show running-config > > > Needed for the "level3" user to be able to execute the "show run view full"
Finally to test with the user:
NS-3560c-01#show privilege
Current privilege level is 3
^ Shows my privilege level
NS-3560c-01#config t
% Invalid input detected at '^' marker.
^ Confirms that I cannot get to the "Global Configuration Mode"
NS-3560c-01#sh run view full
Building configuration...
Current configuration : 8191 bytes
! Last configuration change at 14:59:26 PST Fri Nov 28 2014 by admin
! NVRAM config last updated at 14:54:44 PST Fri Nov 28 2014 by admin
version 15.0
no service pad
service password-encryption
hostname NS-3560c-01
boot-start-marker
boot-end-marker
logging buffered informational
logging console warnings
username admin privilege 15 secret 5 *****
username level3 privilege 3 password 7 060A0A3749425A
no aaa new-model
clock timezone PST -8 0
clock summer-time PST recurring
system mtu routing 1500
no ip source-route
ip routing
ip dhcp excluded-address ******
ip dhcp pool 30
 network 192.168.30.0 255.255.255.0
 default-router 192.168.30.1
 dns-server ***** 4.2.2.2 8.8.8.8
 lease 7
ip dhcp pool 1
 network 192.168.0.0 255.255.255.0
 default-router 192.168.0.1
 dns-server 8.8.8.8 4.2.2.2
ip dhcp pool 40
 network 192.168.40.0 255.255.255.0
 default-router 192.168.40.1
^ Confirms that I can run the "show run view full" command (Some output was cut out)
What does your config look like? Follow my steps above and paste the output.
Hello Neno,
I had not seen your answer before, sorry. My version is 12.1(22)EA11, with crypto features. The thing is I can't execute:
Planta5_5(config)#privilege exec all level3 show running-config
The rest, creating a new user for level3 or any level, ok, with aaa activated, but not possible to execute "all".
That is my issue, and so I can't see all the conf.
Planta5_5#sh privi
Planta5_5#sh run
Current configuration : 83 bytes
! Last configuration change at 09:18:59 UTC Wed Dec 3 2014 by admin
end
Thank you anyway!!! I will try in future equipment with other versions.
No worries. I would definitely start with upgrading the code. I have tested with both 12.2.x and 15.x
davebaker87
 I have the same issue in IOS 15.x - tried the below but no joy. Also tried adding priv interface level 5 interface  commands.
Privilege exec level 5 show running-config view full
Can't seem to display any running config under the priv level
config below
privilege interface level 5 ip address
privilege interface all level 5 ip
privilege interface all level 5 description
privilege configure level 5 interface
privilege exec level 5 traceroute
privilege exec level 5 ping
privilege exec level 5 undebug isdn q931
privilege exec level 5 terminal monitor
privilege exec level 5 show isdn status
privilege exec level 5 show version
privilege exec level 5 show logging
privilege exec level 5 show running-config view full
privilege exec level 5 no debug isdn q931
privilege exec level 5 debug isdn q931
I think you need to type:
to see the config...
Typo in my post*
I had written show running-config view full
No joy!
what I mean is, after entering the privileges, you have to type:
Router#show running-config view full
to actually see the config...
Try adding this command on global config.
file privilege 5
Hope it helps.
I face the same problem lots of times practicing with Packet Tracer as well as in the CCNA exam 200-125. I complained about the problem with Cisco and they replied everything was right. They told me  I have to work more on it where I am lacking, but I am not satisfied with the answer.
