problem after reset password
hii,
my new cisco router 2800 series problem after i try to reset password. please help men, this picture after reset password.
Ivan Shirshin
Hi Reza,
This usually happens when the console settings are not correct in the terminal connected to the router. Check if those are matching the default or expected and try some changes, e.g. different speed.
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
