Problem cisco ASR-1004
iliaklimov
Hi, all.
There is a problem with cisco ASR 1004
Apr  6 21:02:45.784: %ASR1000_OIR-6-OFFLINECARD: Card (fp) offline in slot F0
Apr  6 21:02:45.784: %ASR1000_RP_ALARM-6-INFO: ASSERT MAJOR module F0 Unknown state
Apr  6 21:02:45.784: %ASR1000_RP_ALARM-6-INFO: ASSERT CRITICAL module R0 No Working ESP
Apr  6 21:03:06.991: %CPPHA-3-FAULT: F0: cpp_ha:  CPP:0 desc:CPP Client process failed: cpp_cp det:HA class:CLIENT_SW sev:FATAL id:1 cppstate:RUNNING res:UNKNOWN flags:0x0 cdmflags:0x0
Apr  6 21:03:06.992: %IOSXE-6-PLATFORM: F0: cpp_ha: Shutting down CPP MDM while client(s) still connected
Apr  6 21:03:07.016: %PMAN-3-PROCHOLDDOWN: F0: pman.sh:  The process cpp_cp_svr has been helddown (rc 134)
Apr  6 21:03:07.044: %PMAN-0-PROCFAILCRIT: F0: pvp.sh:  A critical process cpp_cp_svr has failed (rc 134)
Apr  6 21:03:07.146: %PMAN-3-PROCHOLDDOWN: F0: pman.sh:  The process cpp_ha_top_level_server has been helddown (rc 69)
Apr  6 21:03:08.319: %CPPOSLIB-3-ERROR_NOTIFY: F0: /tmp/sw/fp/0/0/fpx86/mount/usr/cpp/bin/cpp_driver[6403]:  cpp_driver-0 encountered an error -Traceback= 1#a00f6e53e69011fd6ce8a24064a6fc2c   errmsg:7F95F21FE000+1175 cpp_common_os:7F95F51A9000+D1E5 cpp_common_os:7F95F51A9000+D12E cpp_common_os:7F95F51A9000+18FEE :400000+104C0 cpp_drv_cmn:7F95F6037000+B98A4 cpp_drv_cmn:7F95F6037000+AED19 evlib:7F95F3DB5000+B379 evlib:7F95F3DB5000+DCD0 :400000+8121 :400000+77C8 c:7F95EDA23000+1E514 :400000+72B9
Apr  6 21:03:21.586: %ASR1000_RP_ALARM-6-INFO: CLEAR MAJOR module F0 Unknown state
Apr  6 21:03:21.586: %ASR1000_RP_ALARM-6-INFO: ASSERT MAJOR module F0 Disabled
Apr  6 21:04:06.355: %ASR1000_RP_ALARM-6-INFO: CLEAR MAJOR module F0 Disabled
Apr  6 21:04:06.356: %ASR1000_RP_ALARM-6-INFO: ASSERT MAJOR module F0 Boot state
Apr  6 21:04:22.622: %RADIUS-4-RADIUS_DEAD: RADIUS server 10.12.48.100:1812,1813 is not responding.
Apr  6 21:04:41.334: %RADIUS-3-ALLDEADSERVER: Group TMK_PPP: No active radius servers found. Id 179.
Apr  6 21:05:13.095: %CPPHA-7-START: F0: cpp_ha:  CPP 0 preparing image /tmp/sw/fp/0/0/fpx86/mount/usr/cpp/bin/qfp-ucode-esp40
Apr  6 21:05:13.593: %CPPHA-7-START: F0: cpp_ha:  CPP 0 startup init image /tmp/sw/fp/0/0/fpx86/mount/usr/cpp/bin/qfp-ucode-esp40
Apr  6 21:05:13.997: %ASR1000_OIR-6-ONLINECARD: Card (fp) online in slot F0
Apr  6 21:05:13.997: %ASR1000_RP_ALARM-6-INFO: CLEAR CRITICAL module R0 No Working ESP
Apr  6 21:05:13.998: %ASR1000_RP_ALARM-6-INFO: CLEAR MAJOR module F0 Boot state
Apr  6 21:05:18.952: %CPPHA-7-START: F0: cpp_ha:  CPP 0 running init image /tmp/sw/fp/0/0/fpx86/mount/usr/cpp/bin/qfp-ucode-esp40
Apr  6 21:05:19.168: %CPPHA-7-READY: F0: cpp_ha:  CPP 0 loading and initialization complete
Apr  6 21:05:19.296: %IOSXE-6-PLATFORM: F0: cpp_cp: Process CPP_PFILTER_EA_EVENT__API_CALL__REGISTER
ASR-1004#show ver
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-ADVIPSERVICES-M), Version 15.1(3)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 22:44 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2011 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
ASR-1004 uptime is 2 weeks, 2 days, 19 hours, 30 minutes
Uptime for this control processor is 2 weeks, 2 days, 19 hours, 31 minutes
System returned to ROM by reload at 15:32:12 Moscow Wed Mar 21 2012
System restarted at 15:35:51 Moscow Wed Mar 21 2012
System image file is "bootflash:/asr1000rp2-advipservices.03.04.00.S.151-3.S.bin"
Last reload reason: Reload Command
cisco ASR1004 (RP2) processor with 10016539K/6147K bytes of memory.
3 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
16777216K bytes of physical memory.
1925119K bytes of eUSB flash at bootflash:.
78085207K bytes of SATA hard disk at harddisk:.
Leo Laohoo
The SIP is dead.  Contact TAC to get the appliance RMA-ed.
Maybe the problem in software? It may help to upgrade IOS ???
What is the most stable version?
Slot 0 is your SIP.  This controllers your Ethernet port.  The logs you've posted shows the router is dead.  Contact Cisco TAC and get the chassis RMA-ed.  There's a chance the appliance is still under warranty.
