Problem configuring SPA122
Alzuaak12
Hello from Spain. I've got an Adapter Cisco Spa122 and all the thins are ok fine,so when i try to connect remotely via openVPN a SSL message log display on the log file...i paste this message log here :
Aug 17 10:46:46 SPA122 daemon.err system[159]: SSL accept error
OpenVPN windows shows me a TLS negotiation fail....
Fri Aug 17 12:10:38 2018 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Aug 17 12:10:38 2018 TLS Error: TLS handshake failed
Which could be the problem??? i've opened port 1194 in the router and when i try to connect via 4Gmobile the connection is OK.
Hello and thanks. These issues has been revised and i think are
well-configurated. When i try to connect via 4g, the connection is good and
this problem not exits
I PASTE ALL THE LOG INFORMATION.....
------------------------------------- router Cisco SPA122
10:09:03 SPA122 kern.warning [17219534.316000] -----------> CY_CHECK_DNAT_MARK_AND_DO_MASQUERADE_SUPPORTAug 17 10:09:03 SPA122 kern.err [17222064.900000] i2c-adapter i2c-0: Master timed out. stat = 6ac0, cntrl = 0000. Resetting master...Aug 17 10:09:03 SPA122 kern.warning [17222358.272000] cy_convert_lan_idx buffer=, len=1Aug 17 10:09:04 SPA122 kern.warning [17222358.284000] LAN idx = [ ]Aug 17 10:09:04 SPA122 kern.warning [17222358.332000] ### conntrack_flushAug 17 10:09:04 SPA122 kern.warning [17222358.336000] ### conntrack_flush doneAug 17 10:09:04 SPA122 kern.warning [17222361.632000] ### conntrack_flushAug 17 10:09:04 SPA122 kern.warning [17222361.636000] ### conntrack_flush doneAug 17 10:09:04 SPA122 kern.warning [17222366.284000] cy_convert_lan_idx buffer=br1;, len=4Aug 17 10:09:04 SPA122 kern.warning [17222366.316000] LAN idx = [ 4 ]Aug 17 10:09:04 SPA122 kern.warning [17222366.376000] ### conntrack_flushAug 17 10:09:04 SPA122 kern.warning [17222366.388000] ### conntrack_flush doneAug 17 10:09:04 SPA122 kern.warning [17222368.968000] ### conntrack_flushAug 17 10:09:04 SPA122 kern.warning [17222368.976000] ### conntrack_flush doneAug 17 10:11:21 SPA122 daemon.err system[159]: SSL accept errorAug 17 10:11:29 SPA122 syslog.notice syslog-ng[794]: syslog-ng version 1.6.12 going downAug 17 10:11:40 SPA122 syslog.notice syslog-ng[810]: syslog-ng version 1.6.12 starting
----------------------------- OpenVPN GUI client.
LOG OpenVPN
Fri Aug 17 10:11:58 2018 SIGUSR1[soft,tls-error] received, process restarting
Fri Aug 17 10:12:03 2018 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Fri Aug 17 10:12:03 2018 TCP/UDP: Preserving recently used remote address: [AF_INET]47.61.177.214:1194
Fri Aug 17 10:12:03 2018 UDP link local (bound): [AF_INET][undef]:1194
Fri Aug 17 10:12:03 2018 UDP link remote: [AF_INET]47.61.177.214:1194
Fri Aug 17 10:12:18 2018 SIGHUP[hard,] received, process restarting
Fri Aug 17 10:12:18 2018 OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 26 2018
Fri Aug 17 10:12:18 2018 Windows version 6.1 (Windows 7) 64bit
Fri Aug 17 10:12:18 2018 library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10
Fri Aug 17 10:12:20 2018 SIGHUP[hard,init_instance] received, process restarting
Fri Aug 17 10:12:20 2018 OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 26 2018
Fri Aug 17 10:12:20 2018 Windows version 6.1 (Windows 7) 64bit
Fri Aug 17 10:12:20 2018 library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10
Fri Aug 17 10:12:25 2018 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Fri Aug 17 10:12:25 2018 TCP/UDP: Preserving recently used remote address: [AF_INET]47.61.177.214:1194
Fri Aug 17 10:12:25 2018 UDP link local (bound): [AF_INET][undef]:1194
Fri Aug 17 10:12:25 2018 UDP link remote: [AF_INET]47.61.177.214:1194
Fri Aug 17 10:13:26 2018 TLS Error: TLS key negotiation failed to occu
